Question about Gigabyte GA-VM900M Motherboard
I just bought a 2gb kingston memory pc2 5300 667 , my motherboard is Giga-Byte GA-VM900Mv.2 , it is written that , it should be compatible but when i put the ram inside , it just make blips that's all, do i need a bios update , can this be my solution ? thank you in advance
    President:
  • 1,812 Answers
*********** supports,DDR2 667/533 up to 4GB Memory
Available with 2 DIMM slots supporting up to 4GB of DDR2 667 memory, GA-VM900M (Rev 2.0) provides the highest performance platform with the high-bandwidth (4.2GB/s) DDR2 memory solution.
You also check bellow the link for details.
http://www.gigabyte.com/products/product-page.aspx?pid=2407#ov
Regard's
Shibuda
Posted on Jan 03, 2011
My mother Bord "GA-790FXTA-UD5" NO Booting
I heard that if you are using an X6 Processor you need to have the Bios Updated, From what i have read so far the only way to do that is use a X3 or X4 that is compatible with the current Bios to boot up and update the Bios. This website http://us.test.giga-byte.com/Support/Motherboard/CPUSupport_Model.aspx?ProductID=3270&ver=#anchor_os Shows which processors are compatible with which Bios. And of course here is the website for the Bios updates http://us.test.giga-byte.com/Support/Motherboard/BIOS_Model.aspx?ProductID=3270&ver=#anchor_os
Dec 23, 2010 | Computers & Internet
I ordered incorrect a 2x1024 mb RAM for my Giga-Byte GA-8VM800PMD-775 with 667 mhz(the ram).The motherboard only supports 533 max ,is it a way that i make it work ?
Sometimes you can use faster RAM because it is usually backward compatible...but not always.
If the RAM doesn't work, there is nothing you can do to make it work.
If you can, get into the BIOS and see if it is detected at all. If not, you are out of luck.
If you would like to have guaranteed memory, I would suggest going to www.kingston.com or www.crucial.com
Thanks for using Fixya.
Dec 20, 2010 | Gigabyte GA-8VM800PMD-775 Motherboard
Will gigabyte 7VM333M-RZ support 1 gb ddr2 ram ? thanks in advance for your answer
this information is from Gigabyte web site
Memory
  • DDR 333 (PC2700) / DDR 266 (PC2100) / DDR 200 (PC1600) 184pin
  • 2 x DIMM slots up to 2GB
For more information you can also visit the same http://ee.giga-byte.com/products/mb/specs/7vm333m-rz.html
good luck and do rate if got help
Dec 04, 2010 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
Where can i download lan driver for g31 es2c
Please checkout the version of your motherboard before downloading the required drivers. There are two versions available at the following locations
http://ee.giga-byte.com/products/mb/driver/ga-g31m-es2c_1x.html
http://ee.giga-byte.com/products/mb/driver/ga-g31m-es2c_2x.html
Hope it Helps!!
CreativeTECH
Nov 16, 2010 | Intel Motherboard
Gigabyte ga-81915me dual core support or not
Double check your model number. GA-8I915ME, its not the number 1 to the right of the 8. Its the letter, capitial i.
I did not find your excat model number at Gigabyte, open link below;
http://www.giga-byte.com/Search/Search_List.aspx?Keyword=GA-8I915ME&SearchType=Spec Of the three listed I picked,
GA-8I915ME-C. Than I checked the CPU supported link;
http://www.giga-byte.com/Support/Motherboard/CPUSupport_Model.aspx?ProductID=1954
The GA-8I915ME-C Motherboard supports both dual core & Core 2 Quad.
Hope you find this helpful.
Cheers!
Mike
Oct 16, 2009 | Intel Motherboard
Not enough free resources code 12 marvell yukon controller gigabyte ga-8gpnxp duo
Probably means that the hard drive is full, and that there is not enough virtual memory available (virtual memory is on the Hard Drive).
Sep 08, 2009 | Gigabyte Giga-Byte: GA-8GPNXP DUO...
Too much memory for Giga-Byte K8M800-8237
The issue of this is not too much capacity on your memory., i tell you the problem is incompatible both of them. Check again your memory and what brand are there.
Because something motherboard settings are being notify if reliable to you to use different kind of RAM you have. Read the motherboard manual to find out some settings to enable both of them are not the same brand or model.
Aug 03, 2009 | Gigabyte GA-K8VM800M Motherboard
Hai
THISH IS SATHISH BABU I LOST MY GA-81865GM-775 MOTHER DRIVER CAN U GIVE ME SOLUTION AND THIS IS MAIL ID sathish_babu1982@rediffmail.com and my contact number 9043192683
Mar 17, 2009 | Gigabyte Giga-Byte: GA-8I865GM-775...
Motherboard
Hi hamideh, your board can Supports up to 3GB PC100/133 SDR-SDRAM Dual memory module DIMM's
Here is the link to your board.
http://www.giga-byte.com/Products/Motherboard/Products_Spec.aspx?ProductID=1402
Enjoy hamideh...
& please vote for me
Mar 08, 2008 | Gigabyte GA-8ID533 Motherboard
Gigabyte GA-VM900M Motherboard Logo
187 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
