Question about Canon LV-S3 Multimedia Projector
My light projecting out of the projector turned green. Any ideas why?
Epson 84+ green light blinks no light
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
May 21, 2012 | Epson Corporati PROJECTOR, EPSON,...
Benq w1000 project not turning on
Look at the manual page 34, for the indicator messages. I suspect it's the same problem I have (which I haven't had formally diagnosed yet!), which I believe is a defective fan. My projector had been making a really loud noise on startup, which varied in length and volume. Recently the projector has taken to turning itself off after being on for about a minute, and the power light flashes green, with the temp and lamp lights flashing red.
Jan 27, 2012 | BenQ W10000 Projector
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
Projecting in green.
lamp may be on it's way out. if the mercury vapor burns at a different temperature than it's designed to, you will get a different color. also check the lamp for bulges, black spots or fogging. if it has any of those, replace it. if the lamp is ok, replace the ballast.
Dec 16, 2009 | NEC NP100 Projector
Yellow/green hue on projection
the light filter on the blue lcd panel is fried due to excessive dust and heat. unfortunately, you'll have to replace the entire optical engine.
Jun 02, 2009 | Toshiba TLP T50MU Multimedia Projector
Horizontal Green Lines!
Hi Tim
I've seen this many times. Only way to get rid of it is to replace the Mainboard.
This will get worse as time goes by.
Jan 17, 2007 | Sony VPL CS1 Multimedia Projector
Canon LV-S3 Multimedia Projector Logo
162 people viewed this question
old marine
old marine
