Question about Bang and Olufsen Beocenter 9300 Shelf System
I have a set of beolab penta mk1 conected via an adaptor to a beocentre 2300 but the displays wont work in both speakers,the sound clipping light comes on in the display though and thats about it. whats the problem?
  • davetruckle0 Jan 05, 2011
    the powerlink cables are new and wired individually to the beocentre 2300, because the beolab pentas mark 1 dont have the powerlink connections (only the mk 2 and 3 have) i used the proper adaptors from bang and olufsen which connect to the line input and the amp level input (4 pin din), the 4 pin din carries the display signal aswell as sound. Surely this setup is supposed to work,if the cables or adaptors were faulty,as they are wired individually one of the displays in the penta would work. Does the beocentre 2300 transmit the signal for the displays in the first place? Have you got to type in a code through the remote control to activate this function? Does the sound clipping indicator which works in the display ,has its signal fed direct from the amp at the base of the speaker and not through the powerlink cable?
    New Friend:
I think that you got it all wrong. I have the same problem with exactly the same setup. There is a jumper inside the display which need to be changed, the speakers has probably been used with a TV and must no know that it is a audio system connected.
Posted on Oct 01, 2014
  • 2,299 Answers
This sounds like a wiring problem. I would disconnect the wiring from the speakers and reconnect it. Clipping is usually cause by excessive amperage. That is usually from a positive strand of wire touching the negative.
Posted on Jan 06, 2011
    President:
  • 4,070 Answers
Hi and welcome to Fixya!
If that's the case then it has to be the speaker wires. You may have disconnected or faulty wires. If that's the case you will need to replace it. The unit is surely fine for the sound clip is ticking but faulty audio output is considerable incase the speaker wires are fine.
Hope this helps and thank you for using FixYa! Have a good one!
Posted on Jan 05, 2011
  • 944 Answers
Have you tried this set up before.?The Beocenter can't draw the energy to the beolab penta mk1.
Check out the output watts with Beocenter it is lesser than beolab.So nomally it wont work.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Jan 04, 2011
Why do I get no sound from either speakers or headphone jack?
Check that the local control is ON
It is set via the function switch
Dec 09, 2015 | Yamaha DGX 530 Keyboard, 88 Full Sized...
How I can connect my mac to beolab 2000? is it possible?
Not going to be be possible but you sure do have some nice speakers!. On top of helping people with their computer problems I also write music. Would love to hear myself through these. Anyway The 2000 MUST be connected to the main system only. Its designed to only work with the main system via a MasterLink Cable. Its really simply an extension of your master system and cannot be used for anything else. Hope these helps.
Nov 30, 2014 | Computers & Internet
No power, when i press the power button then the multi display just flash and the other leds but speaker sounds power on
1-Click and phone orders do not apply. ... Casio CTK-2300 61-Key Premium Portable Keyboard Package with Headphones, ...Yamaha PA130 120 Volt Keyboard ACPower Adaptor by Yamaha... Suite makes practicing your favorite songs more easythan ever before. ..... There's a problem loading this menu right now.
Sep 13, 2013 | Yamaha Portable Keyboard
I have upgradded my Laptop operating system to
Use the ones for Windows Vista. Vista Drivers work for 7.
Now considering these speakers plug in via headphone jack you dont need drivers for your speakers. You should be looking for sound drivers for your laptop.
Plug in headphones see if they work if they do then there is no reason why your speakers should not.
Apr 25, 2010 | Logitech Z-2300 Computer Speakers
BeoLab 8000 no sound
try moving the l/r switch, if sp still dead then its an internal sp fault.if it comes to life the fault lies in the cable or unit.
Sep 18, 2009 | Bang and Olufsen BeoSound 2 Companion MP3...
Hum from B&o active speakers
hi , i just saw ur mail although I do not have the solution to this but I am keen to know how you are using these speakers as I too have identical beolab 6000 and beolab 9000. I was thinking of connecting them to a preamp. What do u suggest ? Pls guide
Oct 01, 2008 | Bang and Olufsen Beocenter 9300 Shelf...
Logitech Speaker Help
Unfortunately, Logitech doesn't sell the wired remote controller separately. And that seems to be infamous for going out.
What worked for me (with no sound and no blue light on the remote connector) was to plug a set of earphones into the earphone port. As soon as I did that, the blue light came on and the sound was restored, even after removing the earphones. Someone else said both speakers worked properly while they had the earphones in, but not otherwise.
Mar 18, 2008 | Logitech Z-2300 Computer Speakers
Power supply.
of course yes, the purpose of the converter is to convert the power output to desired voltage.
Feb 05, 2008 | Logitech Z-2300 Computer Speakers
462 people viewed this question
Top Bang and Olufsen Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Bang and Olufsen Audio Player and Recorder Expert? Answer questions, earn points and help others
