The volume control on my t.v adjusts itself its a 42 "phillips plasma
  • 70 Answers
Micro is corrupted, you definitely need to get the micro reset.
Posted on Jul 09, 2008
Phillips Plasma TV picture is dark
Try ur contrast button some times this adjusted to much also if ur color adjuster is out this will cause same probs
Sep 28, 2012 | Philips 42FD9935/17 42 in. Plasma...
I have a phillips 42 inch plasma televison and i cannot get any remote control to work on it, i broke the origial control a hwhile ago and replaced with a univeral control which set up fine, after a few...
it may have a problem within the tv itself not on the remote control. its problem maybe in the system control i.c that control the infrared remote receiver
Feb 04, 2011 | Philips Televison & Video
TV turns on for a few seconds and displays "NO SIGNAL" then shuts itself off. Can't change channels or adjust volume or accept any other command.
You are not the only one I can tell you that. I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Dec 09, 2010 | Vizio L42HDTV 42 in. LCD Television
Pillips Plasma - Screen is not centered.
Hi jasonlambert,
You can use the remote control to center the picture on screen. Press to the right of the round pad around the OK button until your image is centered. (I had the same problem once)
-Jordan
Jan 14, 2009 | Philips 42PF9630A 42 in. Plasma Television
Power Supply needed for Phillips 42PW99 6217
Email me at dbailey_2000@yahoo.com, I have the original box for this tv. My tv is not working correctly, but the box works fine! All the functions of the box work, although my tv is damaged. Make me an offer and the box is yours!
Jan 01, 2009 | Televison & Video
Phillips plasma tv MDL 42PF9966 Black Line across screen
The ribbon cable to the drive has either came loose of the drive itself went bad. You can open up the back if you are confident and see if adjusting the cable gets the line back. If not you will need to replace the Upper Y Drive.
Thanks
Josh
Sep 27, 2008 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Volume
Check the software and if it is not BX23U-1.5.0.0_03531 download the correct version onto a USB stick.
Jun 21, 2008 | Philips 42PF9630A 42 in. Plasma Television
TV volume increases by itself and doesn't decrease or respond to the remote control
I have a new Philips tv that did the same thing on me I left it off for a couple of minutes and that seems to work
Dec 27, 2007 | Philips 42FD9954 42 in. Plasma HDTV
Televison & Video Logo
Top Televison & Video Experts
