Question about Goodman B1859005 Induced Draft Blower Motor
I have a Rheem 90 Plus furnace that is making a loud humming at startup. The ignitor lights and the burners come on but the loud noise doesn't go away. It sounds like it is coming from the induced draft blower.
SOURCE: I have a Goodman GMS9/GCS9 Gas-Fired Warm Air furnace and it's no
For anyone who finds this question in the future - It's the condensate drain hose for the heat exchanger.
Get a bucket and some towels handy and unplug the lowermost flexible rubber hose - if you do this right after the furnace has stopped, water will come gushing out. Mine was continually plugging up causing my furnace to stop, like yours - the L shaped plastic tube that dips into the drain trap on the outside of the unit (the thing filled with water) was too close to the bottom of the trap. I took it out, shortened it by 1/2 an inch (keep the same bevel that's on there!) and I haven't had a problem since. Blowing out the line would only hold things off for a few weeks before it started acting up again.
Cost me $90 for a service call the first time since visually it looks fine and I checked the upper hoses that go to the pressure switch :)
Learn from my service call!
Posted on Aug 09, 2009
  • 118 Answers
SOURCE: the draft inducer makes a vibrating noise at the
Check screws holding motor to housing and lint on blades making out of balance, too
Posted on Oct 22, 2009
heatman101
  • 43501 Answers
SOURCE: Burner ignites and goes out (Goodman Gas-fired furnace)
The problem you have is water in the exhaust pipe.
Check to see if the pipe has sagged anywhere or if there is a trap in the line.
If you hear gurgling then it is definetly water....
Some times can be hard to find, even a pipe 1/4 full will cause problems. They are very sensitive to flue problems.
Make sure that the flue pipe either runs back to the furnace or out to the outside, a continuos slope either way witha high spot in the middle.
Also check the bottom drain of the blower if it has one, have had them plug and trap water also..
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Dec 24, 2009
heatman101
  • 43501 Answers
SOURCE: constant high pitched noise emitting from furnace
This is probably a dry bearing in the vent motor. Those motors run at high RPM's and can make a deafening high pitched squeal if they become dry and need oiling.
Some of the motors have oil cups on them for dripping oil into and others;s are much more difficult as you need to guess where the bearing is and try to drip oil down into them or run the oil to them.
Any light weight small motor oil ike a sewr machine oil will work.
Many hardwares have small oil bottles with extending spouts made just for oiling motors for just a couple of bucks...
The other thing that can cause this is if the blower wheel is coming loose and has moved to the side and is hitting the side of the blower housing. Take the bottom cover off and check for play or movement side to side in the blower wheel. Spinning it with the power off by hand may give you a clue as you will hear it scraping the side of the housing.
Heatman101
Posted on Dec 29, 2009
  • 3600 Answers
SOURCE: I have a Goodman GMT070-3 furnace. When I turn it
if it is a fuel furnace the pump may have air in the system. here is a web site that will give you the information you will need to to help you fix the problem, there is a manual that will take you step by step to resove the problem, if you need more help understanding the troubleshooting of the system post to this e-mial you will get.
http://www.aircondition-units.com/pc-72-25-gms90703bxa-gas-furnace.aspx
Posted on Mar 15, 2010
There is no ignitor so dont know how t light
Steps outlined for getting gas fireplace pilot light going
www.knoxnews.com/.../steps-outlined-for-gettin...
Knoxville News SentinelDec 29, 2008 - The steps to light the pilot on a gas fireplace may vary some between ... valve that must be turned so the flat valve is in line with the pipe to be on. ... A little trick to know if the gas is on: The gas valve has two holes that line up to ... Most modern gas logs have an igniter button which will be a little red button.
Gas Stove Ignitor and Burner Not Lighting - YouTube
? 1:10
https://www.youtube.com/watch?v=1ZXz8_Md8hI
Nov 20, 2011 - Uploaded by Mike Klimek
Here is an easy fix if you hear the ignitor "clicking" but not lighting the burner. ... We don't hear a clicking sound either. ...after purchase so no warrantee. the sponge dropped crud in thereand the back ... As soon as I release the knob it dies, is this problem then within the know and if so what do I do to fix?
Furnace Ignitor Won't Light! No Heat! HELP!!! ' DIY Forums
www.diyforums.net/furnace-ignitor-wont-light-no-heat-help-6256636.ht...
The ignitor doesn't light up and no clicking noises. ... Depending on what type of furnace you have 80 or 90% there may still be a problem. A fouled secondary on a 90%, gas pressure could be too high, and so on.. you should have a .... When you see an answer you don't know if it is for your question or one of the others.
Jan 13, 2016 | Cars & Trucks
Burner on Bryant 90 PLUS won't turn on and it only blows cold air. I usually can see blue flame in the inspection window when the furnace was functioning properly. Is there a switch that I can reset to...
This system will not have a pilot light, instead it will have an electronic ignition or hot surface ignitor. The problem can be a number of things. You can check to see the operation of the unit by having someone turn the thermostat on while you are at the unit and go from there. The order of operation will be:
Inducer draft motor starts (small motor in heat compartment), after the motor runs and pulls the pressure switch in, telling the furnace that its safe, it then starts the ignitor. This will either sound like a clicking noise until the pilot lights or there will be a orange glow by the burners, after a few seconds, the gas valve calls and the burners should ignite.
By doing this, you can get more information to what the problem actually is. If your unit fails to start the inducer draft motor, fails to call for ignitor, fails to call at gas valve, fails to stay on after ignition. Your system should have a control board with LED trouble lights also. If you can see blinking lights, count the number of times they blink, then look for a trouble code chart, usually on the back of a panel. Hope this helps!
Dec 08, 2013 | Heating & Cooling
Ruud 90 plus will not blow hot air
My Ruud is a different model, so this may not work. Remove the cover to the burners. Look on the left side for a small rubber hose going to a metal cylinder. Remove the hose and blow through it to remove any moisture. Replace the hose and see if the burners start up.
Feb 23, 2013 | Ruud Rheem Rgfe09ezcms Gas Furnace
My rheem 90 plus, has a humming noise any time the power switch is turned on even with thermosat unplugged. i shut the switch off and it stops. do i have a short some where?
Hello, typically a humming noise comes from the transformer located in the blower section of the Furnace. Sometimes it is caused by the transformer being loose, and others it can be a sign of the transformer going bad. i would make sure that it is secure first and see if that helps.
Oct 28, 2011 | Heating & Cooling
I have a 90 plus Ruud furnace that will work when I light the furnce with a match when the furnace is calling for heat
Sounds like the ignitor. Your unit most likely has a hot surface ignitor. The hot surface ignitor is located in front of your burners and usually has two white wires leading you to it. It is a wear-and-tear item that can be expected to need to be replaced every couple of years or so. It would not hurt to keep a spare near your unit at all times.
How to test a hot surface ignitor
Mar 29, 2010 | Heating & Cooling
I have a Lenox furnace. Before this igniter kicks off, there is a loud noise comes from furnace. Where is that noise from? Thanks.
This is what we call a "delayed ignition",(gas is not being ignited right away), gas builds up in the chamber and then lights causing a boom. The cause of this problem could be from having dirty burners or ignitor not position to ignite the gas right away or your ignitor may not being glowing enough to ignite the gas being released, check all, Good luck.
Jan 08, 2010 | Goodman GMS90703BXA Heater
Gas furnace, main burner ignites the other 2 don't. then shutdn.
Between the burners is a small rail in the pressed steel where the flame runs across to light the other burners and it sounds like there is dirt or debris in the step over rails causing the problem. You will need to use some compressed air on those rails to clear them out. Once the rails are clear the other two burners should ignite right away.
Dec 21, 2009 | Heating & Cooling
Loud humming noise
when was last time furnace was serviced --air filter change burner area cleaned vacuumed the hum can be a few reasons ---fan bearing need service [ oiled ] fan bracket bushings damaged or loose --burner out of adjustment burning improper etc these are a few
Jun 03, 2017 | Heating & Cooling
Goodman B1859005 Induced Draft Blower Motor Logo
348 people viewed this question
Top Goodman Garden Experts
lnbn1975
Craig Hill
JonSnell Electronic
JonSnell Electronic
Are you a Goodman Garden Expert? Answer questions, earn points and help others
