Question about Nintendo Wii Console
The unit does not power on. I've plugged it into 2 different electrical outlets, but it still does not have an power. There are no kinked cords that could have shorted out. It did this same thing about a year ago, but my daughter started messing around with it, and it came on. No clue what she did,
    Guru:
  • 91 Answers
You could have a short in your cable you should see if someone you know has a wii cable you could borrow and test if it works on yours or test your cable on their wii. which ever works you should replace that part good luck
Posted on Jan 03, 2011
My Remington Keratin Therapy Flat Iron Doesn't Turn On.
see thi steps and fix it.God bless you
If the iron doesn't heat, make sure 1) power is on to the outlet, 2) check the electrical cord and 3) check the thermostat and replace if necessary. Use the VOM.
Oct 15, 2012 | Remington Style Therapy: Keratin Therapy...
LG LDS5811BB power cord is good, however the dishwasher is not getting any power. No lights no nothing.
There is a fuse on power unit, that should be tested first, check also a different outlet.
Aug 09, 2008 | LG Dishwashers
Hp PSC1210 All-In-One not turning on
HP makes a couple of different power cords for the PSC 1210 and their other printers. First make sure you are using the correct power cord (Amperage and voltage). Unplug the power cord (from the wall and the printer and from a power module if you have one). Leave all of the sections unplugged for at least 15 seconds to reset the power module/printer.
Next connect the power cord to the wall outlet and to the power module if present and check if the LED (if present lights up). If it doesn't try another outlet. In either case, check what the outlet voltage/amperage is at the end of the power cord with a multimeter (before you plug it into the printer). If you have a power module, then check the Amperage (it will be a DC current out).
If you are not getting the correct voltage and amperage out or the LED doesn't light (with a known good outlet), try a different power cord/module.
You can order these from HP.
If you have the correct power at the cord, plug the power cord into the printer and attempt to turn it on. (Press and release the power button.) If the printer still doesn't come on, the unit needs service. Contact HP if the printer is under warranty. Decide if it is worth fixing if it is out of warranty.
I hope this helps.
(I've had to use the HP Repair/Replacement service after a unit was in a home that was hit by lightning. Due to printer availability, an HP gift card was provided to buy a new printer.)
Dec 11, 2011 | HP PSC 1210 All-In-One InkJet Printer
I have 3 red lights on my x-box 360 RROD .Can this be fixed
  • Turn off your console.
  • Disconnect the power cord from the back of your console. Unplug the power cord from the electrical outlet and the power supply unit.
  • Reconnect the power cord to the console. Then plug the power cord back into the electrical outlet and the power supply unit.
  • Turn your console back on.
  • Jun 26, 2011 | Video Game Consoles & Games
    When we switch on the garbage disposal, there's no sound at all..dead. Switched power cord to another outlet, plugged it in and automatically the motor turns on but the blades don't move. It doesn't...
    If you plug it into the original outlet under the sink and flip the switch, nothing happens? No motor sound? And when you plug it into a different outlet, you can hear the motor, but the blades don't turn?
    If this is the situation, I would guess that there's a problem with the insinkerator. Something stuck in it, or it's otherwise jammed. This could have tripped a breaker.
    If the breaker failed or the circuit wasn't wired properly, this jammed condition could also have resulted in the wire at the switch or under-sink receptacle burning off of the terminals.
    Turn off the circuit at the panel, double check that it's off, and remove the switch and the receptacle to see if the wires are still connected. If they've burned off, do not re-connect them. You should consult a licensed electrician to correct a hazardous situation.
    Mar 17, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
    Printer will not power up
    1) Verify the power cord is plugged into both the printer and an electrical outlet.
    2) Try a known working electrical outlet.
    3) Try a different power cord if available.
    If none of the above work then you may have a bad printer that needs replaced.
    Mar 14, 2011 | Computers & Internet
    What does it mean when it says scanner failure?
    Hello it means that the scanner bulb temperature is too low or there is some internal or external electrical malfunction.Try these solutions.
    1.Check the scanner light.Make a color copy of any document by pressing the Start, Copy, Color button on the product control panel.While the product is making the copy, lift the scanner lid slightly to see if the scanner light is visible.
    2.Make sure that the room temperature is suitable for your device
    3.Perform a Power Cycle on the unit by following the steps below:
    1.Turn the unit off.
    2.Unplug the power cord from the unit.
    3.Wait 30 seconds, and then re-connect the power cord to the unit.
    4.Turn the unit on.
    5.Make a color copy by pressing the Start Copy Color button on the control panel.
    4.Check the power connections.Disconnect the power cord from any power strips or surge suppressors and then plug it directly into a wall outlet.Try making a color copy by pressing the Start Copy Color button on the product control panel.If the error message displays again, temporarily move the product to a different room, or plug the power cord into a different wall outlet.
    5.Perform a partial reset
    1.Disconnect the power cord from the product.
    2.Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
    3.Try making a color copy by pressing the Start Copy Color button on the product control panel.
    6.Perform a semi-full reset(Performing a semi-full reset deletes any saved phone numbers on the product).
    2.Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
    If nothing of these works and you still see the error you should take your printer to support service for repairing the parts.
    Feb 08, 2010 | HP OfficeJet d145 InkJet Printer
    I also have HP 6310xi all in one printer with power reset message
    1. Please make sure that the power adapter is working properly. Also connect the unit to a different power outlet and verify.
    If the issue persists, please perform the following steps:
    Step 1: Power Reset:
    1. Disconnect the unit from the computer. Verify that the unit is switched ‘on’. Unplug the power cord from the back of the unit.
    2. Wait 30 seconds.
    3. Plug-in only the ‘power cord’.
    4. Repeat steps 2-4 two more times.
    5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
    If the issue persists, perform the following steps:
    1. Take the cartridges out of the unit. Unplug the power cord from the unit.
    2. Press and hold # and 3 buttons together while plugging in the power cord back to the unit.
    3. Turn on the unit and insert the cartridges.
    This will solve the problem...
    Jun 23, 2009 | HP Officejet 6310 All-In-One InkJet...
    Nintendo Wii Console Logo
    19 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Bee Santiago
    Raj Patel
    phil
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
