My wireless Nikkai digital media player keep loseing it single, but my computors on the same wireless net work do not
  • 10 more comments
  • rickjeffe111 Jul 09, 2008
    moveing the wireless player didn't have any effect, it still crashes out
    make is a Nikkai & model is A44HQ
    it just stops due a movie and says connection lost, then if you click on OK it goes back to the start to finding net work and geting address, then it's fine until next time
    media player needs wireless support for 802.11g networks with WEP or WPA security.
    Access point suports
    wireless standard (IEEE 802.11b/g)
    Speed up to 54 Mbps
    Wireless security ( WPA2, WPA, WEP-128, WEP-64
    have changed wireless router to G only same as wireless media player.
    Problem is still there
  • rickjeffe111 Jul 10, 2008
    yes my media player can be set to a static IP address.
    Not sure what to do
    this is the socond player I've tried.
    I took the first one back because of the same problem
    I've reset all the setting and it's still the same. it always seems to last for about the same amount of time before it crashes out, it's like a power saver but i can't find anythnig that's says it is useing a power saver
  • rickjeffe111 Jul 14, 2008
    Still not working right, can someone help
    at max there will only be 2 computer + thwireless media player.
    the router is a Philips 802.11g ADSL2/2+
    starter kit
    CKA2720
    i'm on sky T.V
  • rickjeffe111 Jul 15, 2008
    how is that ment to help
    how do i update the firmware
  • 4,472 Answers
Http://www.maplin.co.uk/media/A44HQ_upgrade.rar
go there to update it to the latest software. That should help you.
Thanks,
Lee
Posted on Jul 15, 2008
  • Lee A.
    Lee A. Jul 15, 2008
    and if you have a moment after you have finished updating the software I would greatly appreciate if you could accept and rate the solution accordingly as I strive to provide fast and accurate service.
    Thanks and let me know if you need any further assistance,
    Lee
    Genius:
  • 1,665 Answers
    Genius:
  • 1,011 Answers
Sir,
If there is any interference between the transmitter and the receiver then you could loose the signal. or if the TV's are not on the right channel. ( the Tv picking up the signal ) or the transmitter and receiver are not on the same channel. ( some have a few channels to choose from if you had a couple sets or someone near by had one )
Could also be the Receiving TV is not set to Air and is on Cable ( or visa versa )??
Thanks
Don't forget to rate the solution
Posted on Jul 10, 2008
  • 6,487 Answers
Try changing the wireless settings of your router like the Wireless channel use channel 11, and can you also tell me how many wireless computer do you have working with the router and what's the model of your router??
Hope that helps.......
  • Mark Gil
    Mark Gil Jul 14, 2008
    If you can update the firmware of this unit try updating it.....
  • Mark Gil
    If your 2 wireless computer are working fine wirelessly we shoudl really concentrate on your media player, so if you haven't update the firmware of this unit update it...
  • 105 Answers
Reset the settings and keep them very close and try
  • 813 Answers
Reset your wireless Nikkai digital media player all the setting & reconfiger it again your problem will solves
  • sandip panchal
    sandip panchal Jul 10, 2008
    if your router has been not spports then it will be happen or port must be locked
  • 19,396 Answers
The most common case is when you get an IP conflict within the device (media player) and other units on the network, check on the media player manual if you can set the device ip to static.
  • 13,433 Answers
You may have a faulty device in your hands, do you warranty on it? you could have it checked and or replaced to see if that would solve the issue, If not then its a problem with the wireless.
Posted on Jul 09, 2008
  • Ekse Jul 09, 2008
    and I mean the media player.
    Champion:
  • 217 Answers
Does your digital media player operate on 802.11 B or G? Example: If your wireless router is transmitting mixed(or both) B/G, and your digital media player uses G, then you'll want to change your wireless router setting to G only. (not mixed or both G/B) Hopefully your computers use G as well.
    Sergeant:
  • 233 Answers
.if your digital media player was working fine before this problem happened on the same access point . then you should check the following :
1- the device antenna it could be broken form inside the plastic shield
2- the place; the digital media player should be far from electromagnetic attenuation.
3- the Heat ; it may be over heated for some reason
if your digital media player Newly installed and tries to connect to the access point. check the compatibility of Wi-Fi protocole .
on both access point and your media player .it may use an incopatable protocole for example 802.11a does not talk with 802.11b and 802.11g can talk to both 11a and 11b
    Brigadier General:
  • 3,614 Answers
Can you please also provide us here, what is the model/maker of the unit that you have there...
and kindly provide us more info regarding on the problem that you have...
thank you
micro
    Master:
  • 788 Answers
There must be something causing interference nearby the media player. Try moving it away from your TV and any other electronics as far possible.
WHERE CAN I GET REPLACEMENT REMOTE CONTROL FOR NIKKAI A09JQ
Search the internet for suppliers of replacement OEM remote controls.
Jul 07, 2016 | Televison & Video
Can I log onto the internet with my Apple Ipod through my home computor, my home computor is not wireless.
the only way you can log on the web on your ipod is if you are connected to a WiFi network, then you can access the web and it accesses it as if you are using a mobile WEB...
Aug 07, 2010 | Apple iPod touch
My computor does not reconise my zen it tells me to put installation disc in that i do not have where can i get free download of this
You Can Download Free MP3 From Youtube By This Site : video2mp3.net
If you didn't found Your Favorite Music In Youtube Try These Sites : Beemp3.com or 4shared.com
Jan 23, 2010 | Creative Labs Zen Touch MP3 Player
Laptop keeps losing wireless connection
make sure the wep key you apply it is correct.just reconfgure the wireless connection.
Dec 31, 2009 | Dell Inspiron 6000 Notebook
Keep losing wireless connection
probably not your computer problem
probably its the net
does it happen every where' or in singal net?
Oct 01, 2009 | IBM ThinkPad R52 Notebook
It wont download musics anymore and it keeps losing profiles when i trun it on plz help me!!
I copied music from my cd to the media player, than to my mp705. However, I keep getting a may be displayed message.
Please advise.
Aug 15, 2009 | Coby MP-705 Digital Media Player
Constant Freezing
sell it it has done this on every single archos and every single one of my mates and me has had these problems
Jul 26, 2009 | Archos Internet Media Tablet MP3 Player
Yp-T10 digital media player
make sure you have media player 10 or 11 version
Oct 27, 2008 | Samsung YP-T10 Digital Media Player
Computor with usb wireless 802.11b/g not concecting with net on other comp
for wireless connection you make use of a 'hot spot'.since the sinal is coming fine,get authentication from your provider(a kind of acess)
Apr 14, 2008 | Computers & Internet
Televison & Video Logo
518 people viewed this question
Top Televison & Video Experts
