Question about Dell Ethernet Card Network Adapter
I use to use a netgear wireless network adapter on my Dell Dimension 3000 which i no longer use. I plug the LAN wire from my netgear router (which is working with multiple other appliances) and it doesn't even acknowledge it. I do not have my factory restore disc either please help!
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
somewhere along the line you turned off the on-board network card. you should goto the network settings and remove the netgear wireless as you network connection, and run connection manager again.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 03, 2011
How do i access wireless internet on a dell dimension 4500s computer to a actiontec m1000 router
To RESET the Netgear, power up the Netgear then press and hold the RESET button at the back of the router until all the LEDs flash. Connect a LAN cable from the Netgear to the LAN port on your computer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password You can now change the default admin password and configure the wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Oct 03, 2012 | NetGear WGR614 Wireless Router
My netgear wireless-N 300 modem router dgn2200
IF YOU WANT TO USE NETGEAR AS A ROUTER YOU PLUG THE ETH-CABLE TO IT AND START LOOK IN THE PC FOR WIRELESS NETWORK.ON THE OTHER YOU CAN CONNECT YOU DSL CABLE DIRECTLY TO YOUR PC.
Apr 11, 2012 | NetGear Computers & Internet
Ialso have suddenlink
How to Set Up a Netgear WGR614 V5 Wireless Router
Netgear routers--like all wireless routers--give you the opportunity to access the Internet with your laptop or wireless-adapted computer from virtually anywhere in your house within range of the router's WiFi signal. Though slightly different in appearance from other router models by Netgear, the WGR614 V5 acts similar in its setup process as others such as the WGT624 or WNR1000 series routers.
Things You'll Need:
Netgear WGR615 V5 routerNetgear resource CDEthernet wireBlue network wireModemComputer
1 Prepare to install the Netgear router. Log off and shut down your computer system. Turn your Internet modem off and/or disconnect its power supply from the electrical outlet. Take out the contents of the Netgear router box and verify that all the essentials are present: the resource CD, the yellow wire and the router itself.
2 Connect the Internet modem to the Netgear WGR614 v5 router. Locate the yellow Ethernet wire running from one end of the Internet modem to the computer's Ethernet port. Unhook the computer-end of the Ethernet wire and insert this end into the port on the router labeled "Internet." After inserting, confirm that the wire runs from the modem to the router.
3 Connect the Netgear router to the computer. Grab the blue cable supplied with the router. Securely insert one end of the blue cable into one of the four "LAN" ports on the router (the "LAN" ports are labeled with numbers from 1 to 4). Insert the other end of the blue wire into your computer's Ethernet port.
4 Start your network devices. Turn on or connect your Internet modem to an electrical outlet. Wait for at least two minutes to allow the modem to fully boot. Plug the Netgear router into the wall or electrical outlet as well, and wait one to two minutes. Turn on your computer.
5 Look at the Netgear router to verify that all lights are on. The "power," "Internet" and "wireless" icon symbols on the front of the router should be solidly lit. One of the four "LAN" ports should also be lit with either a green or amber color.
6 Insert the resource CD that came with your Netgear router to launch the "welcome" screen. Select "Router Setup" from the menu to begin the "Smart Wizard" setup application. Read and follow the setup steps, including naming your SSID (secure set identifier) or "network name" and setting a level of wireless security. Finish the setup process, ending with the registration of your Netgear router.
7 Verify that your Netgear router has been set up correctly. Open an Internet browser from both the computer that is connected to the router and on a computer that has a wireless card or adapter. Surf to your favorite Internet sites to verify your connection is working. Open your "network connections" utility on your operating system and make sure it shows that you're connected to your own wireless network.
Jan 09, 2012 | NetGear WGR614 Wireless Router
Im on a dell dimension 3200c desktop,which is connected to an eircom wireless router which is connected to a landline... i would like to connect another pc using the signal from this.. i have a netgear...
first install the software that came with your wireless adapter after youve done that insert the adapter. open the network program have it seach for wireless signal if your router is useing wep enter the password click on conect you should be in
Feb 20, 2010 | Dell Dimension 3100 PC Desktop
Wireless router with dimension 3000
It seems that you have Dell Desktop computer, unless you requested a wireless card to be put into the computer, it would not come with one. Just like stang_1 mentioned, you should check your network adapters to see if your wireless card is listed. Also since it is a desktop, you can check the back of it to see if you have an Antenna sticking out of it. That would indicate that you have a wireless card on the PCI slot. And if that is the case and you do not see it listed in the network connections, check the Device Manager and make sure that the drivers are installed properly.
Apr 14, 2009 | Dell Dimension 3000 PC Desktop
Adding Dell Dimension 4600 to existing wireless network?...
Go to Staples and purchase a Linksys USB wireless-G (only G needed - the new "N" protocol is overkill) adapter (~$60.00). Insert the Linksys CD and follow the instructions. When prompted, plug the USB adapter into the Dell (frt or back) doesn't matter. If his "roomies" have security enabled on their router, you'll need to know the level, password/passphrase, and the network name that they assigned.
Good luck.
gurutim
Mar 21, 2009 | Dell Dimension 4600 PC Desktop
Intel 82562V-2 10/100 ethernet adapter does not turn back on from vista sleep mode
If you're using your system as the Host for the other systems, turn off your sleep mode. The Host should be active at ALL times.
Dec 09, 2008 | Intel Ethernet 10/100 Network Adapter
My laptop cannot connect to my local network (LAN)
Assuming you initially set up the router using the wired lan adapter and lead, enabled DHCP in the settings. First stand right next to your router; Dells wireless is a little tempremental, go to control panel and in there should be Dell wireless monitor, open this up refresh it and see if it finds any wireless networks, if so try to connect. Dissable your wired network lan adapter. Go to the properties of your wireless card and on the TCP/IP line click properties again and ensure that obtain an ip address automatically is selected, press ok and restart the pc.
Sep 20, 2007 | Dell 1470 (W9284) 802.11a/g/b Wireless...
Dell Ethernet Card Network Adapter Logo
42 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
