Question about Whirlpool Refrigerators
Can you remove the kick plate at the bottom of ref, Model # SXS REF ED2LH? dmueller@austin.rr.com
  • 4,070 Answers
Yes. Open both door all the way and it should pull off.
Posted on Jan 03, 2011
Whirlpool ref. panel light will not stay on. how do I make it stay on
Sounds like a machine operating ok. Buy a nightlight or contact the manufacturer for a user manual.
Jun 01, 2015 | Whirlpool ED5FHEXVS - Ref Sxs 25 - Sxs...
Where is the defrost heater located in my GE Profile model TCS18?
defrost heater is located inside of ref. freezer take out shefs and racks.should be screws on back plate remove plate and derost heateris is normally mounter at bottom of coils .ge still uses glase heaters.google model no. for correct part
Apr 10, 2013 | Refrigerators
My LG fridge freezer has a problem with temperature control. Essentially, it seems that the thermostat is not working. If I switch it off and on at the plug then the cooling kicks in until the fridge...
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Sep 04, 2011 | LG LRB-P1031 Bottom Freezer Refrigerator
Top & bottom are not cold enough.
Check to see if there is any ice buildup in the back of the freezer. You may have a defrost problem. If no ice is found, you may have a Freon leak. Also, what is the make and model number of the unit?
Jul 20, 2011 | Amana Refrigerators
How to remove defrost timer
need complete model # to give correct help but most kenmore sxs ref / the defrost timer is located in the control panel . two screws to remove an un plug it .. reverse to install .. some older models are locaded behind the toe grill . same two screws.. mm
Oct 23, 2010 | Kenmore 52282 / 52284 Side by Side...
Where is the filter at on a one year old Whirlpool Gold side by side
Either under the front kick plate under ref or inside ref top right back
Aug 30, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer part works fine, but the refrid won't cool?
The freezer is the only place that has cooling coils (condensor) the ref side steals air by way of a fan and duct from the fzr side. But in my experience the fzr i the last to go when an ref is low on freon. Also make sure the external coils are clean and the fan is running on the external side (if equip) coils are usually under the ref if it has a fan and is accessed on the bottom back by removing a cardboard access usually black. This cardboard looks flimsy but it is very important to reinstall it. It directs the air flow across the coils. after removing this you can plug your ref up to make sure the external fan kicks on with the compressor if not the fan is bad and needs to be replaced. always be careful with electricity...
Aug 08, 2010 | Hotpoint Refrigerators
DOOR HANDLE LOOSE MODEL#gs5shaxnq00 Whirlpool sxs Ref side
Ther is nothong wrong with the ice Dispensing unit the screws in the door handle are loose and we can not figure how to tighten them.
the model# is GS5SHAXNQ00
Aug 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Always running
depending on the model of ref that you have, coils are accessible front bottom by removing the kick plate, (either screws or clips into place) or its available by removing the bottom plate (metal or cardboard) located on the bottom of the back of the outside of the unit. If the coils are really dirty, clean them and this should resolve the problem, if they are clean, check for excessive frost build up in the freezer section on the back panel indicative of a possible defrost problem, or broken door seal. If defrost problem is present, check defrost thermostat for continuity, if open replace, check heater for same, if open replace. Check defrost timer for proper operation, if faulty, replace as needed. Testing procedures will vary with model. Consult your schematic for proper testing procedures, or call a service tech if you don't feel comfortable with do-it-yourself repair. If the door seal is bad, replace as needed.
May 12, 2009 | GE GSS20IEP Side by Side Refrigerator
Refrigerators Logo
47 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
