Question about Hitachi 50V500 50 in. HD-Ready LCD Television
I have same problem as listed. Got a new lamp with housing to make it easy but, no matter how many times I check to make sure it is installed correctly with the plugs fitted into their slots and the screws to the housing and the door to the housing firmly screwed in, the three lights come on and then the lamp led light blinks.
  • 441 Answers
If you still have the housing from the first bulb, use that housing with the new bulb. When they try to make a "one bulb for all tvs" bulb it does not always work.
Posted on Jan 03, 2011
Do I need to order the housing with the lamp after burn-out?
you can order just the bulb then install that in your housing. Being careful not to touch the new bulb with your bare hands as the oils from your finger tips will cause the lamp to fail prematurely.
Feb 07, 2012 | Mitsubishi WD-60735 Projection Television
How do I change my projection lamp for my Sony Wega KDF 50E2000.
Hello.
You have to get lamp fully assembled for easy replacement. That mean lamp should be purchased already installed in black plastic housing.
If you stand behind of your TV set on the left hand side (actual side) of your TV you will locate lamp door cover with latch on the top of it. Just push the latch down and remove cover. Deeper inside you will locate black plastic lamp door with handle that you have to rotate 1/8 of the turn counter-clockwise to open it up ( like a submarine style thing). Pull it out and next thing that you will discover - lamp assembly itself. Put your index finger inside of the ring-looking latch, pull it up and out. You have lamp removed now. Extremely carefully install new lamp in same order making sure that new lamp is ALL WAY IN (there is safety switch that sense if lamp is not properly in) and install the door making sure it is ALL WAY IN and LOCKED (there is another safety switch that sense it). If any of the switches will not sense proper installation TV WILL NOT turn on.
You can turn TV on to check if it is working. Last thing to do - reinstall lamp door cover.
Russ.
Dec 01, 2010 | Sony KDF-50E2000 50" HDTV
How do I install the samsung HLR4667WX/XAA lamp...are there instructions that come with that part or do i need a professional to install
The manual for the TV usually has the instructions. You can find many Samsung manuals on their website (samsung.com). The bulb replacement is easy enough to do it yourself. You need a Phillips screw driver and a lint free cloth to handle the new lamp. Turn off and unplug the TV. Wait ~30 minutes after turning off the TV before starting.
Usually you need to remove one Phillips screw to take off the lamp cover. Then loosen two additional screws and pull the lamp housing out by the handle. If your new lamp came with the housing, just swap. Otherwise (some OEM lamps), you need to remove 6 more screws to exchange the lamps (these have nuts that are only hand tight). Make sure not to mix up the old and new lamps and store the old one in a safe place until you can dispose of it.
Then reverse the steps. If the cover is not properly secured the TV will not come on.
I hope this helps.
Aug 22, 2010 | Televison & Video
How do I install a new lamp? It's a 62HM95.
Its relly easy to replace Lamp Look on your TV for a small Panel that you can remove without having to take the whole back off but if you have to just remove the whole back Lamps most of the time have 2 screws holding them to chassis once you know the location of Lamp and have small handle you can pull out if you are ording Lamp with out housing make sure you wear rubber gloves you do not want your fringer prints on new lamp what so ever! you can burn prints into Lamp once it gets hot Once you have new lamp install make sure back is on before turnig on.
Nov 19, 2009 | Toshiba 62HM95 62" DLP HDTV
I have a 2007 Sony 60AKDS3000 rear projection. It
You can by the lamp online from various outlets. They usually run around $150 to $200 and are pretty easy to install at the back of the television. Make sure the TV is unplugged and use a screwdriver to remove the outer cover and loosen the lamp housing. Disconnect the connector and install the new lamp. Re-install the screws. take special care not to touch the lamp because your skin oils can cause the lamp to fail. Make sure you go into the menu for the televison when your done and rest the lamp timer.
Here is a link to a web-site that sells lamps. Definently shop around prices can very greatly.
http://www.dlplampsource.com/?gclid=COi-7Lie45wCFRgbawodlFdUmg
Sep 08, 2009 | Sony Televison & Video
Tv turns off at differing intervals.
It's probably time to buy a new lamp. They can be very expensive to buy, sometimes up to 400 or 500 dollars. If you think the lamp might be failing prematurely, contact LG's support or warranty department to see what your options are. If you must buy a new lamp, you should check into relamping the existing housing for the bulb. Some bulbs are easy to change the bulb and leave the reflector, saving you money, however, most of them are not easy to change. you'll have to check online.
Aug 31, 2009 | LG 62SX4D 62" Television
How To change Sony XL-5100 Projector Lamp with housing
  • Installation is Quick and Easy:
    In most cases, replacing your projection lamp is quick and easy. However, it is recommended that you consult your owner's manual for more detailed instructions:
  • Unplug your TV from your power outlet
  • Allow the lamp to cool for at least one (1) hour before replacing it
  • Remove the Lamp unit cover (Usually located at the rear of the television)
  • Unscrew the lamp housing unit
  • Remove the old lamp housing unit and discard
  • Screw in the new lamp housing unit
  • Place the cover back onto your TV unit Caution: Do NOT touch the bulb directly with your fingers.
  • Jun 15, 2009 | Sony XL-5100 Projector Lamp for Grand WEGA...
    KDF-55WF655 Sony TV red lite flashes6 times
    The thermal fuse has opened. Unfortunately, its likely that the ventilation system of the TV has been blocked by dust or other foreign matter. The cyclone fan mounted above the lamp housing is prone to this type of accumulation. Check for evidence of overheating in the lamp, lamp housing, and especcially the red wires going to the lamp socket. If they appear scorched, its a safe bet it got very, very hot.
    To bring this TV back to life a new fuse needs to be installed, all the fans need to be cleaned, the lamp ballast board may need to be replaced as well if the wires appear to be damaged. Also, if your lamp is not new, it should be replaced too. Botton line here is cost. If you call a service company out, expect to spend a minimum of $300 and as much as a $1000 or more.
    Keep your eye out for class-action lawsuits being filed on these TVs. I've seen a few of these actually melt the plastic lamp cavity to the point where it may catch fire.
    Feb 19, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
    Xl-2100u
  • Unplug your Projector from your power outlet
  • Place the cover back onto your unit Caution: Do NOT touch the bulb directly with your fingers.
  • Oct 19, 2008 | Sony XL-2100U Projector Lamp for...
    Lamp light
    Check the lamp switch that is located inside the door. Place the lamp in, and stick a flathead screwdriver in the slot (just make sure it moves) hold it there, and turn on the Tv. If that doesn't work check the new lamp, is it a generic lamp, if so they dont always work. If you still have your old orig lamp, take the old lamp out of that housing, and out the new lamp in the old housing. This should fix the problem.
    Jan 18, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
    Hitachi 50V500 50 in. HD-Ready LCD Television Logo
    21 people viewed this question
    Top Hitachi Televison & Video Experts
    Jaime Hernandez
    matt martin
    matt martin
    Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
