Question about Maytag Washing Machines
May tag model MVWB300W00 serial CY3770413 the code that popped up read Ld. Removed the clothing and tried to reset the washer. The lights come on and buzzer works. I cannot get the washer to work. Can you help?
  • 641 Answers
SOURCE: LD ERROR CODE
Check that the drain house is clear from kinked or clogged. Let me know if you will need for further assistance. Good luck!
Posted on Sep 09, 2007
  • 32 Answers
SOURCE: Kenmore elite calypso HE washer
turn mach on spin,if you hear the pump turning normally you have a blocked sump.if the pump hums,you have a jammed pump.the pump is located under mach,tilt backwards as far as possible and remove screws on ft of access plate.once plate is removed pump will be on right side either held on by 2 clips or 4 torx screws.the 4 torx screws will split the pump in half and allow you to clean it out.the 2 clip pump cannot be split in half but you can remove the 2 hose clamps and try to remove what is jamming(you have a 50/50 chance of getting item out of this kind of pump).bail out as much water as possible,this mach will still have a huge amount of water in it even after bailing it so have some buckets handy and slowly drain from pump before removing.if there is something stuck in the sump,call a technician.lot more complicated and involves special tools and removing entire basket and u-joint assy..good luck
Posted on Sep 28, 2008
duby1990
  • 367 Answers
SOURCE: Kenmore Elite LD Error
LD means long drain. First check to make sure that there is nothing stuck inside your drain hose. The next thing to check is your pump. lean the washer back and locate the pump. Next take it loose and clean out any debrit inside it. That should take care of it. If not check your lid switch.
Posted on Nov 18, 2008
tzweeb
  • 318 Answers
SOURCE: LD is on my display-nothing will clear it and washer doesnt drain
the ld code means a long drain, what you probably have is something blocking the drain pump.
you can get to the drain pump from the back of the unit and it will be the pump on the left as you face the back.
you will need to remove the hose going into the pump and be ready for water to come out. sorry but you need to check inside the hose as there will be something blocking it. like a coin or some lint or a small sock.
when you get the item out of the hose then it should work again. you do not need to reset the control. once it knows the unit is draining properly it will be ok.
Posted on Jan 30, 2009
  • 240 Answers
SOURCE: Clothes washer won't drain - digital display shows LD
looking at the tech sheet for this, it appears to be a standard whirlpool top load but with electronic controls, correct? normalling with this type a lid switch is the issue but the electronics would have a different code for this, LD is Long Drain for this model. suspect a transmission but this should help you troubleshoot. go to www.servicematters.com and click technical reference - tech library - tech sheets, enter model minus 110.prefix. this will show tech sheet with diagnostics. this book can also be found inside your console.
Posted on Mar 14, 2009
Access code for westinghouse tv model LD-2240 serial 6616121307447
You're asking about its service mode code I assumes, and posts this solution. Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. Some times, the ads attached with each posts, both at the right and bottom, might help you to find the availability of spare parts. There are more than 750 posts to different brand TVs now
Sep 14, 2012 | Televison & Video
Get alarm code ld
CI code comes on just seconds after I start the machine. The machine itself is leveled on all sides.
Dec 26, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
My washer stopped and flashed Ld. I took out the
Hi
Thanks for using FixYa. Error code LD means Long Drain. It flashes when washer takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. Press STOP/CANCEL to clear the display. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 12, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Clothes are still wet. LD code is displayed. does go thru wash cycle and rinse,butclothes remaine wet.
I had the exact same problem with code LD. I removed the bottom pan unhooked the yellow and black tubes from the gray piece with the 2 clips on it. I'm not sure if that is the pump, but any how I removed the 2 clips and the tubes look inside and seen that there was a piece of old t-shirt jamming it up. Removed it and works great. My Calypso is about 4 years old. Hope this helps.
Jul 19, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Purchased a damaged GE dryer. Model and Serial number removed.
Model tag is inside door frame or at the bottom corner on the side. It may have been removed or not replaced if the front panel was replaced, Eric
Jul 07, 2009 | GE 5.8 Cu. Ft. 2-Cycle Extra-Large...
Mar 14, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite flashing codes.
ob means out of balance and ld means lid not closed. so i would guess that you have a washer that is not draining or just needs the clothes moved around.
if you have a plugged pump it will do the same thing. make sure the pump will drain properly and then try it again. if it still goes out then try it with no clothes. that way you know its not hte clothes causing the problem.
recheck the pump and hoses. be sure it will drain the full tub or it wont work right.
Jan 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
I have a a kenmore oasis ld error cod
ld error code is long drain some thimg clogged up pump ,, first check drain hose could be too far down and siphoning,, if not repl/ or cleaned out pump.....
Dec 06, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Error code LD
I had this problem also. Ld means that it is taking too long for the tub to drain, usually something is clogged. Try taking a shop vac and sucking out the drain hose that goes into the wall drain. This should at least get you where the tub will finish the cycle you have going. I tried this and it worked for about 2 loads then "Ld" again. Finally removed the drain pump from the washer and let it empty completely. So far this has worked.
Jun 10, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Washing Machines Logo
63 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
