Whenever i hit my brakes, slow down or start up at a traffic light, I hear creaking noises at the front end of the minivan. Sometimes I hear it when I turn my steering wheel.
For safety reasons please have the brakes inspected as soon as possible. Honestly there is more cause for creaking and may or may not have been there before the repairs. I am a full-time mechanic and from time to time have a customer complaint about a noise that wasn't there before the work was performed. Don't get me wrong though, you may be right. If you are then it may be bolts or nuts that was not properly torqued, a surface that wasn't properly cleaned before reassembly or human error. The technician may have missed something or for a necessary step. A faulty caliper with piston issues, a caliper mounting bracket with damaged sliders and or improperly cleaned surfaces where the shims and brake pads slide could all be suspect. The pistons, sliders and brake pads should all move and slide freely, without play. The mechanic may test drive the vehicle to confirm your complaint, inspect all the brake components located behind the wheels and report their findings. If nothing is found they will need to look elsewhere. Hope this helps. Please let me know if there is anything else. Good luck.
The exact nature of the creaking is important, and you have not provided enough info to narrow down the problem. The only "creaking" noise I have ever heard like that was coming from the front wheel. If it is going "creak -creak-creak" and changes as the car changes speed, I would check that.
Sounds like the brake pad wear indicator tab on the inner brake pad as the pads sometimes wear out unevenly due to stiky brake calliper slides. You would have to remove the wheel to inspect it.
This is due to worn hardened rubber bushings in the suspension of the car. The most noise comes from the front and rear anti sway bars so replace those rubber bushings first.
check to see if theres something hitting the wheel, or if there something in the tire, most of the time its a plastic cover that hits the tire, check for any loose or hanging plastic.
