Question about Waterway 5HP Executive 56 Frame Spa Pump PF502N22C
Need to change the seal on a PF-50-2N22C - Waterway 5HP Executive 56 Frame Spa Pump PF502N22C
    President:
  • Waterway Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
In general the process is the same for any brand...Disassemble the motor from the pump, lock the motor shaft at the end opposite the pump, spin off the impeller (which may be covered by what is called a diffuser), replace both halves of the seal (one is pressed into the pump housing and the other rides against or on the back of the impeller) and assemble in reverse order. If you need more specific directions, please add a comment with your question(s) or contact me using our web site at www.arrowpools.net.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Jan 12, 2011
Why isn't it working?
Model# not coming up WM2688H need Right number.
you say your getting a PF code
sound like loose connection somewhere.
getting a glitch in the power at power up Need more details on what first symptoms were B4 any parts changed and list of parts changed
will PF cancel on controls takes a few seconds then flashes PF?
Send us a bit more on symptoms from first plugging in washer what it dose.We then can give you more detailed answers
Thanks . for posting
Feb 04, 2014 | LG WM2688H Front Load Washer
PF Pro printing pale blue instead of black
you are printing composite black instead of pure black.
Still problem is the print head not getting all inks (may be air, or you didn't remove some seals on the inks/print head.
Nov 07, 2013 | MicroBoards Office Equipment & Supplies
Need to change seal on pf-40 waterway pump
can change but water leaking into motor it will start to squeal bad bearing just change whole pump
Dec 26, 2012 | Waterway 5HP Executive 56 Frame Spa Pump...
Fatal code 0x50
Hi, Hope this helps,I downloaded & manually Translated it from a Russian Website (I speak Fluent Russian)!!
fatal error code 10x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 20xF1 PF PID excess load error. Possible causes : PF Motor failure, PF drive mechanism overload (paper jam, foreign object, insufficient grease, deformation of the Main Frame), Tooth skip of the PF Timing Belt, Improper tension of the PF Timing Belt, Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 30x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 40x0A CR load position excess load error. Possible causes : CR Motor failure, CR Unit drive mechanism overload (paper jam, foreign object, Change Lever failure), Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 50x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Oct 10, 2010 | Epson PictureMate 500 InkJet Photo Printer
I have a Waterly Executive Pump PF-40-2N22C\r\nI
Waterway did change the wet ends slightly (the difference is only minute and you wouldn't realise without meausring) and if yours is the older version you may need to change the entire wet end.
I'd advise you to take the pump to someone who can advise you and perhaps consider changing the entire wet end so that you have a new mechanical seal too.
If you're in the UK I can possibly help but I suspect that you're in the US...
http://hottub.synthasite.com
Regards,
Ian.
Jun 04, 2010 | Waterway Spa Pump Executive 56 Frame 4hp...
I have a solis crema sl-70 whose portafilter leaks and actually flies off if I don't hold it in place as I pull a shot. Is this is small repair problem, or should I replace my machine?
You may just need a new grouphead gasket. This is a rubber ring that fits in the space between the outside of the grouphead and the interior area that houses the dispersion screen. If it's worn or dried out, the pf may not be sealing properly (which would cause the leaking and instability)
The portafilter (pf) handle should line up with a pre-printed indicator line on the group head when it's "locked" in. If you're looking at the machine straight on, and the far side is "12" on a clock face, the handle should be at 6 or 5 o' clock. The pf should "ease" in to the grouphead, not stop with a hard feeling.
The problem might be with the portafilter "ears", or the metal tines that wedge into the grouphead. If they're excessively worn, the pf might not be secured snugly enough to make a seal. A new pf will solve this.
So, first, try a new gasket. Then a new portafilter. Then a new machine :)
Dec 15, 2009 | Solis Crema SL-70 Espresso Machine
I would like to replace the seal between pump and motor on model# pf-30-2n2c waterway spa pump how do you separate them
Pull the pump's front cover, lock the opposite end of the motor shaft, unthread the impeller, loosen the 4 motor thru-bolts then you can pull the seal plate.
Oct 26, 2009 | Pool & Spa
Alignment
You can try adjusting the top side and left side numbers within the printer driver. After changing the numbers, and you still have alignment issues, then you will need to get the printer professionally cleaned in order to get the sensors back to factory spec. PF-1 and PF-2 cleanings run $200 - $350 depending on how much ink needs to be removed from the vital sensors, gears and motors.
Dec 29, 2007 | MicroBoards PF-2 InkJet Printer
Waterway 5HP Executive 56 Frame Spa Pump PF502N22C Logo
585 people viewed this question
Top Waterway Pool & Spa Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Ian Kime
Ian Kime
Are you a Waterway Pool and Spa Expert? Answer questions, earn points and help others
