Question about Toshiba 57H82 57" Rear Projection Television
Replacement Lamps for Toshiba 57H82
Please send maintenance/repair manual
  • Anonymous Aug 22, 2008
    What part of the rear panel do I remove to replace this lamp ?
4 Suggested Answers
SOURCE: 57H82 Service Manual?
Can you please email me a service manual for 57H82 Toshiba if you please sir. I am also in need of the service manual.
Thanks in advance
Posted on Oct 14, 2008
  • 10594 Answers
SOURCE: looking for a service manual for a 57h82
I have Toshiba 50H81 manual and can email you, if you need that.
Posted on Apr 12, 2009
  • 85 Answers
SOURCE: Toshiba 57H82 convergence problems. TouchFocus
See my solution <>.
You need to get to the service menu--it's been 4 years so go to to turn off the different guns and get the better pattern.
At your risk: To get into Service mode:
1. Turn your TV on. 2. For X81 or earlier series: Press MUTE on your remote and release. 2. For H80/H81/HX81 series: Press MUTE on your remote and release two times ("Mute" on-screen) 3. Press down MUTE on your remote again and hold. While holding, press the MENU button on your TV set's front panel. 4. Release both buttons. 5. An "S" should appear on your screen. Press MENU again on your TV. 6. Now you're in service mode. Channel Up/Dn - Scrolls through Parameters and Volume Up/Dn - Changes Parameter Value
To get into convergence mode:
Get into Service mode, then Hit '7' to bring up the convergence grid. Buttons 100, 0, and ENT control which gun you want to turn off (if you want to align the red to the green without seeing the blue gun and other variations). 2=up, 8=down, 4=left, 6=right, 3=change gun to converge, 5=converge that point. To exit convergence mode you press 7 once and your screen should look like it's imploding then return to normal and then you press 7 to get back into regular service mode.
I have more info found on the board. -Ken
Posted on Aug 18, 2009
Toshiba 57h82 has sound but no picture. Power light comes on and does not blink. I believe the TV was left on for a long period of time. What should I check for?
1)Make sure the ventilation slots are clear of dust and debris.
2)listen for odd sounds from within the housing. snaps,crackles and pops are not good sounds.
3)Make sure the fans are running
4)Remove the lamp,following the instructions in your manual. Do not touch any part of the glass lamp!!!!!!!
One sign of a bad lamp is a blackened base of the arc chamber(the tube inside the lamp.)
There is really no way to test arc lamps except send it to the mfr.
Good luck! let me know if you figure it out.
Aug 30, 2011 | Toshiba 57H82 57" Rear Projection...
The colors are not matching up it will not allow auto focus or manual, the red line is not straight? Toshiba 57H82 rear projection t.v.
The convergence circuit has failed in the tv. These are the big STK chips on the circuit board. It typically costs $300 to fix at a TV service center. Requires replacement of two STK chips, some resistors, some fuses and then re-alignment of the CRTs within the service menu.
If you have proper soldering tools and can download the service manual, it is possible to do the repair yourself.
If you do not have any electronic background whatsoever, I do not recommend a person to attempt it.
Feb 15, 2011 | Toshiba 57H82 57" Rear Projection...
The picture on my Toshiba 57H82 model went out. What Type of bulb do I buy and how do I change it?
if you type in "toshiba 57h82" in a google search, the page should show you a list of lamps of veriuos stores with variuos prices. Now to change it, can have a great resource of information about how to change the lamps. In youtube, just type in DLP lamp replacement. You may not find one on your set, but after whatching a few of the videos, you should have a working knowledge how to change it yourself. Just remember not to touch the front part of the lamp with bare hands. the oils in your body can cause premature damage to the lamp. Use rubber gloves. Cheap ones for a dolor store will work fine.
Aug 09, 2010 | Toshiba 57H82 57" Rear Projection...
Service Manual for Toshiba 57H82
By the red being "off" I suspect you have a convergence problem and adjusting will bnot likely fix the problem. The convergence amps need to be replaced but if you email me I can send you the servoce manual... Just provide me with enough info in your mail, model number, because I get nearly 3000 emails a day and I won't likely remember what manual you're looking for...
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
Dec 18, 2008 | Toshiba 57H82 57" Rear Projection...
Service manual for Toshiba 57H82
I found an owners manual and other info on your TV but not a maintenance/service manual. I would suggest contacting Customer support, See below:
Dec 17, 2008 | Toshiba 57H82 57" Rear Projection...
Copy of service manual for toshiba 57h82
Am sending it now via Pando.. If you don't already have Pando you will need to go to their site and download it first to open the link. It's a free download..
Nov 02, 2008 | Toshiba 57H82 57" Rear Projection...
Service Manual
Will send it out post haste... But be VERY careful inside the hyper module you can easily lift the traces when trying to remove the smd caps and ruin the module beyond repair...
Just send me a private mail and I'll return with the service manual.
Oct 14, 2008 | Toshiba 57H82 57" Rear Projection...
Emailed and sent via Pando...
May 13, 2008 | Toshiba 57H82 57" Rear Projection...
Same Prolem with Toshiba 57H82 57
Just sent the manual via Pando - If you don't already have Pando you will need to download it first. It's a free download..
Apr 13, 2008 | Toshiba 57H82 57" Rear Projection...
57h82 toshiba
Send me your email and I'll send you a Pando link to download it.
Feb 17, 2008 | Televison & Video
Toshiba 57H82 57" Rear Projection Television Logo
226 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
