Question about Monroe 7140 Calculator
ON BOTH OUR 7140'S AND 7130'S ONLY THE RED PRINTS AFTER A TIME. WE CHANGE THE RIBBION CARTRIDGE EVERY 3 ROLLS OF TAPE. ANY QUICK FIXES FOR THIS PROBLEM?
B210a printer
Hi, it prints ok for a short while 2-3 pages then no black print the vent hole of the cartridge is plugged. You may have filled cartridge and forgot to take tape off the vent hole. Hope this helps this drove me crazy for a long time.
Mr Chirpy
Mar 21, 2014 | HP Photosmart C3180 All-In-One InkJet...
Unable to print or delete a document
  • 1
    Remove the cartridges from the F380 printer.
  • 2
    Position the cartridges so they are right side up and the gold leads are facing you.
  • 3
    Place a small piece of tape over the gold contact in the top left corner of each cartridge.
  • 4
    Place the cartridge back in the F380 printer. The printer automatically prints an alignment page.
  • 5
    Remove the cartridges. Place a piece of tape over the gold contact in the top right corner of each cartridge.
  • 6
    Place the cartridges back into the F380 printer. The F380 prints another alignment page.
  • 7
    Remove the cartridges from the printer. Remove both pieces of tape from each cartridge.
  • 8
    Insert the cartridges into the F380 printer. The printer prints a cartridge alignment page. Each cartridge is now recognized as a full ink cartridge.
  • Jun 16, 2011 | HP DeskJet F380 All-In-One Printer
    I don't know how to install the cartridgre on my new printer J 3680 Could you please tell me how? Thanks,
    Follow the instructions below to install the print cartridges for the first time. Installing print cartridges Step one: Install the print cartridges Follow these steps to install the cartridges.
    1. Open the cartridge door. The carriage moves to the far right side of the product. Figure 1: Open the cartridge doorc01133347.jpg
    2. Remove the new cartridge from its packaging and, being careful to touch onlythe black plastic, gently remove the plastic tape by using the pink pull tab. Figure 2: Remove tape from cartridgec01107115.jpg 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections.Do not remove the copper strips. They are required electrical contacts. Figure 3: Do not touch the ink nozzles or copper contacts.c01107116.jpg
    3. Slide each new cartridge forward into the empty slot. Then gently push theupper part of the cartridge forward until it clicks into place.
      • Insert the tri-color cartridge into the left slot.
      • Insert the black cartridge into the right slot.
      Figure 4: Insert the cartridgec01107117.jpg
    4. Close the cartridge door.
    Step two: : Align the print cartridge The product prompts you to align cartridges every time you install a cartridge. You can also align the cartridges at any time from the control panel, or byusing the software you install with the product. Aligning the cartridgesensures high quality output.
    1. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
    2. Press OK. The product prints an alignment page.
    3. Place the alignment page print-side down on the scanner glass.
    4. Press OK to scan the alignment page. When the scan finishes, the alignment is complete.
    NOTE: If you have colored paper loaded in the input tray when you align the cartridges, the alignment will fail. Load unused plain white paper into the inputtray, and then try the alignment again.
    Sep 13, 2010 | Office Equipment & Supplies
    My black ink is printing green and when I select red it prints yellow?
    most likely the black cartridge is either empty or dried up and its printing from the color cartridge within the printer, by the sounds of it the color one is also on its way out.
    i would use any options the printer provides to clean the cartridges to see if this fixes it, if its been sitting for a long time not used i would also consider replacing the cartridges as there probably no good any more.
    Jul 28, 2010 | Dell A940 All-In-One InkJet Printer
    My ps 1100 label maker prints only on black side of tape
    This depends on the TAPE CARTRIDGE you have in your label printer. Apparenlty, you have a TRANSPARENT TAPE on it, and the printer prints in BLACK only.
    Just replace the tape cartridge
    Apr 01, 2010 | Brother P-Touch (PT1100SBVP) Label...
    I need step by step instructions as far as how to change cartridges in hp deskjet 5440 printer
    [This is from HP.com]
    Introduction This document explains the basics of installing or replacing the print cartridges. It is for a 5940 which is the same printer design, yours may look a bit different but I copied this from HP at the section for your printer so follow the instructions and you should be okay.
    Insert the print cartridges
    NOTE: The printer shown below is the HP Deskjet 5940 series printer. Your printer might look slightly different.
    1. Turn the printer on. The cartridge cradle will not move if the power is not on.
    2. Open the printer cover. Figure 1: Open the cover c00393707.gif
    3. Wait until the print cartridge cradle moves to the right side of the printer and is idle and quiet.
    4. If you are replacing a print cartridge, press down on the print cartridge to be replaced, and then slide it out of the print cartridge cradle. If you are installing print cartridges for the first time, go to the next step.
    5. Remove the new print cartridge from its packaging and carefully remove the plastic tape. Hold the print cartridge so that the copper strips are on the bottom and facing toward the printer. Figure 2: Remove tape c00393708.gif 1 - Protective tape CAUTION: Do not touch the print cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections. Do not remove the copper strips. They are required electrical contacts.
    6. Slide the print cartridge at a slight upward angle into the cradle until the cartridge snaps into place. Figure 3: Install the print cartridge c00393709.gif
    7. Repeat steps 3-4 for the remaining print cartridge.
    8. Close the printer cover. The printer automatically prints a calibration page.
    Original Page here:
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00411520&lc=en&dlc=en&cc=us&product=445441&os=228&rule=27868&lang=en
    Regards,
    Worldvet
    Dec 01, 2008 | HP Deskjet 5440 InkJet Photo Printer
    Brother typewriter GX6750
    When you put the correction tape in make sure it is in the guides on both sides and also between the two metal fingers and the metal cardholder. Also make sure the ribbon goes in the same place.. The dull side of the corr. tape should be towards the platen or it won't correct.
    Aug 27, 2008 | Brother GX-6750 Typewriter
    I keep getting cartridge error or it prints a blank page. There is no tape on the cartridge and they are installed properly. It prints sometimes but not all the time Printer keeps saying cartridge error
    This has been just happening with me aswell - I just changed the colour cartridge with the black cartridge ran out but i kept it in as it told me to place one in. Trying to print out but black ink wont come - just blank pages - surely the colour cartridge can make black? However, if you have the colour cartridge and are on microsoft word or similar, change the colour of the writing to dark navy and it will print out documents.
    Aug 26, 2008 | Lexmark P6250 All-In-One InkJet Photo...
    Printing problem
    it is a new original cartridge?
    or u don't use it for a long time?
    try to use a tissue press on the nozzle to see whether there r 3 colours on the tissue if there r means that u cartridge is spoil need to change a new cartridge.
    if only can see red colour means that ur cartridge nozzle block maybe not use it for a long period, u may use a bit of warm water to clear it.
    put some warm water in a container just 3-5cm high make sure the water do not higher than the circuit board on the cartridge, put the cartridge in for 5 to 10 min, use a tissue to clean up the nozzle and check the colour. most of the cases can be solve by using this way.
    Mar 02, 2008 | Canon PIXMA iP1600 Printer
    Monroe 7140 Calculator Logo
    22 people viewed this question
    Top Monroe Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you a Monroe Office Equipment and Supply Expert? Answer questions, earn points and help others
