Question about Sansui Audio Players & Recorders
I just purchased a HDLCDVD320A 32" TFT LCD Digital TV with DVD Player. I want to hook up my Headphones that let me listen to the TV thru them without disturbing others around me, But I don't see a headphone connection. On the back, where I have my VCR hooked up there is one hole left open, but my headphone is to large to fit in there. I have tried all the holes in the left side of the TV and none of them work either. Is it possible to hook up my headphones?
  • Sansui Master
  • 520 Answers
Sorry. No.
Posted on Oct 24, 2008
How do i hook up wireless headphones?
In the menu of the tv under audio there should be a position for turning off the internal speakers. Meanwhile, the transmitter for the headphones must be hooked up to the tv's audio output.
Aug 20, 2015 | Magnavox 32MF301B/F7 32 in. LCD TV
I don't know what channel to go to to be able to play my dvd player
where did you hooked up the connector wire coming from the dvd player, in the component input or at the RF jack of the tuner of the tv?. if you plug at the component input of the tv you will select AV1 or AV2 etc. in the settings. but if you hooked up into the RF jack you can select channel 3 in the tv but at this time you need to have manual tuned in the tv to get the signal coming from the dvd player or xbox.
Oct 13, 2012 | Emerson LC320EM9 32 in. LCD HDTV
My television does not have an audio output so i connected the rs 110 to my cable box and it works fine...however i also have a dvd player connected to the tv video input and for some reason i cannot hear...
Are you using AV cables from your DVD player to your TV? (the yellow,red and white ones) If you are the is a way to do this, since you have no other outputs at all is you will have to make one. With the purchase of a couple adapters and an additional av (audio only cord which is red and white) you can do this. The first adapter you need looks like this. http://www.globalgrabber.com/product/4507930-5mm-stereo-plug-2-rca-plugs-jacks/ You will remove the red and white AV cords from the back of your TV that run from the DVD player and insert them in the adapter to their respective colors on the adapter. Then you need to purchase a double female AV adapter that looks like this .http://www.google.com/products/catalog?q=double+female+av+adaptor&hl=en&prmd=ivns&biw=1600&bih=799&bav=on.2,or.&um=1&ie=UTF-8&cid=14119505288159192113&sa=X&ei=S-V1TZPDJIKglAexv-ybCA&ved=0CI0BEPMCMAU# Then you need to put that adapter on the one you just installed so you can add the new AV cord onto it and run the new cord to the TV.That completes the sound of the DVD's back to your TV. Now for your headphones. You will need a double female 3.5mm jack input to put between your headphones and the remaining jack on the adapter. It looks like this http://www.buy.com/prod/3-5mm-female-to-female-stereo-audio-cable-coupler/q/sellerid/23962916/loc/101/216778563.html Play a movie and enjoy. This is the only way to do what you want with the current setup you have. These adapters and wires can all be purchased for less than $10 off of E-bay. If your not using AV cords then the only other way to do it with the current setup you have is --
You can purchase a reasonably priced receiver and hook your DVD, cable, and TV to it as well as your headphones. With no outputs on your TV there will be no way to hear your DVD's through your headphones. You can also purchase a very reasonably priced shelf speaker stereo. Many made in recent years have some audio inputs and of course inputs for your headphones.
Mar 08, 2011 | Sennheiser RS 110 Consumer Headphones
The tv is hooked up to our dvd player. We get a
hi,
Plz see to it that if all of jacks of dvd player are correctly and firmly inserted into the respectively coloured mating jacks of ur TV. If u still dont get a sound, it will be better if u purchase a new set of jacks.
Jun 02, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Need wiring diagram for DVD PLAYER ASSY DL-06LS-M1
i'm trying to hook up a dvd player to my lcd tv.i can play a movie through the tv but i cant record tv on to the dvd player.i only have antenna tv can you please solve this problem for me.
Jan 15, 2010 | Akai LCT3201TD 32 in. LCD Television
How can I make my DVD audio into my car audio system
just hook up your system to your deck and try all the rca wires until dvd plays through the system
Dec 26, 2009 | ACCELEVISION 14.1" TFT LCD FLIPDOWN TV...
No signal from my dvd player
Can you tell me how to connect my dvd player to my 42 inch proscan hdtv ? There are no yellow,its blue and there are two rows of the same colors.
Feb 03, 2009 | Proscan 32LA25Q 32 in. LCD TV
Sound hook up
if u have a pair of rca connectors, connect audio out of your dvd dvd receiver to audio in of your tv. they are usually red and white,, for right and left speaker.
Nov 05, 2008 | Kenwood HTB-204 System
Hi! name's wesley. anyways, here's the problem. i just bought a new samsung 32' lcd tv and everything is great except for one thing: when i connect my ps2 to the "av 2" input, the sound comes out...
There is a problem with the AV2 input. Since this is a new set, return it for repair or exchange. DO NOT open it up as that would void the warranty.
Dan
Jun 05, 2008 | Samsung Televison & Video
Top Sansui Audio Players & Recorders Experts
Jaime Hernandez
ashburton
Josh Whitehead
Josh Whitehead
Are you a Sansui Audio Player and Recorder Expert? Answer questions, earn points and help others
