Question about Dishwashers
Homark DW010H E4 error message - Dishwashers
4 Suggested Answers
SOURCE: e4 error message
I have the same problem. Want to buy a new one, but would like to know if this can be fixed.
Posted on Jun 09, 2009
  • 11 Answers
SOURCE: error message e4 54040990
It may mean that the disk is no longer usable due to scratches or other over-use reasons. If a new disk, it may mean you're using the wrong brand. This machine works on recommended brands, and the brand of DVD+RW that has proven to be workable on this device, and that I use with no problems, is VERBATIM. Hope this helps you solve what's wrong.
Posted on Mar 27, 2010
Macmarkus
  • 2605 Answers
SOURCE: Error message: E4....What means? I can't open the
Hello, Welcome to FixYa.
Hopefully the info below will supply you with the assistance to get the door open for now at least...and a little more with some luck. The E4 error indicates a door kock error, however the door typically locks as a result of the unit failing to drain, so....
1. **Unplug the washer from the wall or turn off the breaker before attempting any repairs**
2. Locate the round door on the front of the machine (about 6" in diameter, lower right corner)try a drill bit or small screwdriver that fits in the hole in the round door.
3. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free. (the edges are very sharp so be careful).
4. Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand or with the aid of pliers.
**NOTE - you should also see a ring attached, if you pull this the door should unlatch, but getting the water out first if present is usually a good plan
Once the door is open, unplug the washer for 20minutes or so and then plug it in again, to see if the control "resets". Good luck !
Let me know if you require further assistance and if not and this solves your problem, please rate the solution I provided accordingly. (Sorry about the post, I'm still adapting to this "htc" windows 7 phone after having an iphone for 2years...very tricky lol )
Thank you for choosing to "FixYa".
Regards,
Macmarkus :)
Posted on Jul 16, 2011
I just received my pressure cooker and it keeps giving me an error message E4. why?
Generally, the E4 error code means that the sensor in the pc is faulty and needs to be replaced. Contact the place where you bought it immediately (if it's still under warranty) or contact the manufacturer to ask for a replacement.
Good Luck!
Nov 01, 2014 | Home
Logik dishwasher E4 error message
I am having difficulty with my logik slimline dishwasher. E4 message about 30 minutes into cycle. Where the salt goes is always full of water. Please can someone help me
Nov 17, 2012 | Dishwashers
My dishwasher says E4
The error code E4 means selector switch pads is stuck.
First try a hard reset. Unplug the unit for 10 minutes and then switch on the dishwasher. Most cases you won't get the error message.
If you still get the error message then you need to take to service center to get it repaired. Mostly, the inner connectivity between the pad and circuit board is loose/bad.
Hope this helps.
Shane
Feb 27, 2011 | Kenwood KDW243A Builtin Dishwasher
E4 error message
Apr 04, 2009 | Uniden TRU9485 Cordless Phone
Error message E4
All sewing machines are 'picky' about being threaded correctly. As you seem to understand. There is no shame in asking the seller for help.
Jan 23, 2018 | Singer CE350
E4 Error
york hvac unit e4 error code Troubleshooting
Aug 05, 2008 | DeLonghi CF210 Portable Air Conditioner
F3 E4 Err
E4 error complaint whirlpool ac
Jun 03, 2008 | Whirlpool RF262LXS Kitchen Range
Hi there ,purchased an EZISET dishwasher privately through trademe, he said it was new. have installed it and each cycle pulls in water ,sprays, emptys and stops. can you please help us. their is a number...
This might mean you have a leak, in your dishwasher. the rings that stop the water from seaping might be broken, or it may be hat your motor is not in good condition. Anyway, i know that that dishwasher is a low quality dishwasher, for it has a reputation all over the internet that it is bad.
I hope you get it fixed!!!
Mar 30, 2008 | Dishwashers
Error Message E4 54037380
call manufactor and see if your serial number qualifies for a firmware upgrade.
Dec 28, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Dishwashers Logo
141 people viewed this question
Top Dishwashers Experts
