Question about Briggs Stratton 020273 Elite Series Portable Gas Pressure Washer
Oil blows out exhaust and air cleaner while engine is running. This a 6.5 hp Briggs & Stratton that is the muscle for my 2550 elite pressure washer
  • Bradd Sherr
    Bradd Sherr Sep 10, 2015
    But what causes it to do that. to much oil?
    Top Expert:
  • Briggs Master
  • 13,761 Answers
Damaged valves =machine not level --to much oil --burnt piston rings
Posted on Jul 24, 2016
    Habit-Forming:
  • 80 Answers
This sound like you have to much oil in the motor. check the level of oil in the motor
2 Suggested Answers
  • 1267 Answers
SOURCE: The 6.5 hp Briggs & Stratton engine that
It most likely is a ring problem as the gasket only keeps the combustion gases in and would leak around the head as a loud noise. Of course it could be the valves, but I doubt it as most of these engines are splash fed instead of pressure, so the only explanation is the compression ring is letting oil blow past.
Posted on Jan 03, 2011
Cub cadet 30 inch 1450 briggs and stratton
About 625 results (0.89 seconds) Search Results
    Why wont my engine start - Briggs & Stratton
    www.briggsandstratton.com/.../why-wont-my-engine-st...
    Briggs & StrattonThe most common reason an engine will not start is due to an interruption in fuel ...(such as Briggs & Stratton carburetor cleaner to clean carburetor parts and body. ...gasoline be purchased in small quantities, not more than a 30 day supply. ... that canflood the engine, or cut the air supply enough that engine will not run.Missing: inch ‎major
    Information about the Carter, Kohler and Walbro Carburetors
    gardentractorpullingtips.com/carbfuel.htm
    Information about the Kohler Carburetor, Various Fuels and Fuel Systems. ... (Updated 5/23/15); Repairing Various Older Briggs & Stratton Carburetors. ... If used on a smaller engine, due to the larger venturi, the engine will not receive the ... which converts to 1.181 inches (30 ÷ 25.4 = 1.181"), but actually measures 1.200".
    Notes on the Troubleshooting and Repair of small Gasoline ...
    www.repairfaq.org/sam/lmfaq.htm
    May 19, 2015 - Timing; Lawn mower will not start after the blade hit an obstruction; Flywheel ... on Briggs and Stratton repair; Experience with Briggs & Stratton carburetor .... NEVER attempt to run a gasoline engine indoors. ..... For 2 stroke engines, special oil (not the usual 10W-30/40 type motor oil, nor WD40 or 3-In-One!) ...
    Briggs & Stratton - YouTube
Jan 21, 2016 | Garden
18 hp Briggs blowing oil into the air filter
Sounds like your valves are sticking, possibly bent w/piston damage.
Dec 14, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Started by Craftsman 2700 PSI , 2.3 GPM Briggs & Stratton Powered Pressure Washer for first time in 9 months. Added new oil, and gas. started but is smoking from muffler and is dripping what appears to...
The first thing I would check would be the oil level, to make sure you didn't put in too much oil. If the oil level is correct, it could be a stuck piston ring, letting oil blow by the piston, and out the exhaust. If this is the case, you are going to have to tear down the engine.
Hope this helps!
May 09, 2011 | Craftsman 2700 PSI,2.3 GPM Briggs &...
16 h v-tech briggs-stratton is blowing oil into carburator, what could cause this problem and possable solutions
see if the oils coming out of the rubber hose by the air cleaner ,if it is it could be the pcv valve the rubber hose is connected to. order could be too much oil in the engine, sometimes the carburetor will flood the crankcase with gas , you have to rebuild the carburetor and change the oil.
Feb 18, 2011 | Briggs & Stratton Briggs Stratton Vanguard...
The 6.5 hp Briggs & Stratton engine that powers my 2550 elite pressure washer is blowing oil out the exhaust and air filter while it is running. Do you think this is a gasket problem or a piston ring...
Jan 03, 2011 | Briggs Stratton 020273 Elite Series...
Need to know where oil drain plug is on 6.75 hp Briggs & Stratton engine on 2550 psi troy bilt pressure washer!!
I have the same model...... it should be just underneath the unit.... it will look like a square head recessed. I used the ratchet set extension and it fit just right. I literally had to tilt the darn thing upside down to find it. Then once it was loosen a bit, I put the machine upright on the wheels again, and slip a plastic pan underneath as I finished unscrewing the oil plug, Out came the black goo.
Aug 07, 2010 | Briggs Stratton 020273 Elite Series...
Oil appearing at exhaust, smokey, briggs and stratton lawm mower.
You will need to replace or clean the air filter, and probably the spark plug. Do not operate the mower for some hours to allow the oil drain (inside the engine). Check oil level and fill it if necessary. Some oil remaining in the exhaust should be burnt next time the lawnmower operates.You will see smoke at the beginning, that will be normal (burnt oil). Hope this helps!
May 25, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Oil in air cleaner
Run it minus an air filter until all the oil is off your piston head, you can also try keeping the plug out and ejecting the oil via that access by pulling the cord. It seems like you've already solved the problem, now you're just cleaning up.
Apr 21, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I have a briggs and stratton ride on lawn mower 14hp model 287707. engine pumping oil through breather into carburettor when running, its working but burning oil.
The float is getting stuck open which will cause the engine/sump to fill with oil and thats why you see oil comming out carby/air filter clean ya plug drain your sump turn motor over with plug out a few time to clean out check float/needle and seat in carby refil oil clean ya spark plug and off you go it will blow heaps of white smoke don't worry it is just buring th oil out if the exhaust/engine hope this helps some one
Mar 26, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Craftsman riding mower 2003 DLT 3000 ,Blowing oil out of the fuel
Head gasket is blowed .Its building pressure in the crankcase seen it twice. Remove the head and check for a blowed out spot between piston and the valve side
Jul 29, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs Stratton 020273 Elite Series Portable Gas Pressure Washer Logo
464 people viewed this question
Top Briggs Garden Experts
Mike
Renee Knafel-Bullock
Are you a Briggs Garden Expert? Answer questions, earn points and help others
