Question about Samsung Televison & Video
I have a Samsung LNT4665FX/XAA TV which takes several cycles to turn on. It cycles on and off until warm and then has some bad pixels showing on the screen. I turn it off and on and once warm functions normally. What is wrong?
  • 3 Answers
Your start-up problem is in the power supply , open the set up look for capacitors that have a bulge in the top replace them and its fixed
Posted on Mar 03, 2011
TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
Samsung DLP TV Repair - No Picture - Replacing ...
? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Samsung DLP problems - Help! - ecoustics.com
www.ecoustics.com > ... > Home Video Forum > Projection TV Forum
Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
Apr 10, 2009
Archive through October 26, 2009 - Samsung DLP problems ...
Apr 8, 2009
Samsung DLP Flashing Standby light
Jul 1, 2006
More results from www.ecoustics.com
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
I get the nf halfway through the cycle. ALWAYS with 26 minutes remaining after opening and shutting the door several times and can get it to resume the cycle.
SAMSUNG WF331ANW/XAA TROUBLE SHOOTING GUIDE ...
www.manualslib.com > ... > Washer > WF331ANW/XAA
View and Download Samsung WF331ANW/XAA Trouble Shooting Guide technical information online. 3.7 cu. ft. High Efficiency VRT Steam Front Load Washer (Neat White). ... DC68-02834A-03_EN. 2011-09-28. 4:00:29. Previous page ... SamsungWF337AAG · Samsung WF338AAB · Samsung WF331ANR/XAA · Samsung ...
Support - Washers WF431ABP/XAA ' Samsung Washers ...
www.samsung.com > ... > Washers
Samsung Electronics
Dec 08, 2015 | Samsung WF338AAB 4.0 cu. ft. Front Load...
LNT4665FX/XAA has a cracked internal screen
go to a repair shop and see if it can be replaced and the cost? or buy a new tv if it is not worth it.
May 23, 2011 | Samsung LN-T4665F 46 in. LCD Television
I have a samsung flat screen model # LNT4665FX/XAA that is about three years old, when I turn it on it clicks about 6 times before coming on. What could be the issue? It also seems to flash pixels...
Your TV most likely has faulty capacitors in the power supply section of the TV. This is a failry common problem.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
2c07611.png The number one cause for the symptoms above are faulty capacitors within your Plasma or LCD TV. The number one reason that these parts fail is that TV manufacturers often times use lower grade capacitors in their efforts to reduce costs. After several years these lower grade parts will tend to fail first. To insure that these parts will not fail again its imperative that they are replaced with high temp, high quality, low-ESR caps. You can find the parts online from sources like Digikey or you can get complete reair kits incuding the parts, repair instructions, and support from www.TvRepairKits.com
Dec 15, 2010 | Samsung LN-T4671F 46 in. LCD Television
Samsung lnt 4665fx/xaa lcd wont turnon just makes clicking sound
Sounds like the power supply board has failed, VERY common problem. You can call 1-800-samsung for the nearest service center.
Jan 22, 2010 | Televison & Video
Samsung hdtv, purple pixels and trouble turning on
probably the power supply is going out.common problem.
Oct 27, 2009 | Televison & Video
SAMSUNG TV WONT TURN ON JUST CLICKS
I just fixed this very same problem. The capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Sep 24, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
LCD TV vertical line
If the line is vertical and "One Pixel Wide" (Pinstripe) then the LCD Panel is bad and needs to be replaced. Contact 1-800-SAMSUNG to set up service.
Jul 14, 2009 | Televison & Video
Samsung lnt4042hx/xaa 40in lcd tv wont turn on
I concur with Lightnbaby.... had same problem... my TV LNT4042HX/XAA took 10 min to start sometimes... the capacitors on the power supply board had bubbles on top 4 of them all 10/1000Uf. Samsung wanted to charge $220+ to have a guy come out and fix. J&J parts (samsung vendor) wanted $108 for a new board. I replaced the 4 capacitors for $4.68 and the TV works fine now!!!!!
Apr 14, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
Samsung HPT4254X/XAA plasma turns off and on by itself, clicking.
had the same problem, same tv... bad connection on a transistor....
Jan 07, 2009 | Samsung HP-R4262 42 in. Plasma Television
Televison & Video Logo
542 people viewed this question
Jerry Greenberg
Jerry Greenberg
