Question about GE JS905SKSS Stainless Steel Electric Kitchen Range
F7 in display, buttons for range don't work - GE JS905SKSS Stainless Steel Electric Kitchen Range
  • 2,299 Answers
The GE Oven F7 error is caused by poor contact on the flex circuit that connects the keypad.
To fix it, turn off the power and pull the oven out a couple of inches for access.
Remove the 3 hex head screws under the control panel and lift the panel off.
Find the connector where the flex circuit connects to the main oven control. Snap it open and remove the flex circuit.
Clean the flex circuit contacts with electrical contact cleaner and a pencil eraser.
Put it all back together and the F7 should go away.
Posted on Jan 03, 2011
Displays "F7" and a continuous
If your Maytag range displays the "F7" error code, it means that the programmed fault error 7 occurred with the range. Luckily the error is easily fixed in most cases and requires no new parts.
Identification:
Once the error appears on the range it is usually followed by seven loud beeps to represent the number. Clear the error by holding a button down for a minute. The LCD will flash and the code will disappear.
Effects:
The most common cause of the "F7" error is a stuck button on the LCD panel. Look around the range control panel and examine to see if any buttons appear pushed in, stuck or out of place.
Prevention/Solution:
Take a damp rag and light wipe around the buttons to clear out any grease, food particles or sticky substance that may have built up around the button. Attempt to use your range and see if the error appears again.
Considerations:
If the error continues to appear, there could be permanent damage to your electronic range control. Contact your Maytag dealer for warranty information and replacement parts.
Keep us updated.
May 24, 2011 | Kitchen Ranges
F7 CODE
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
F9 Program w/ door circuit Check wiring
Mar 21, 2010 | GE Built-In 24" Double Electric Wall Oven
GE range displaying codes F7 E6, unable to turn oven on.
F7 E6 shows that Function pad button stuck or Bad clock try to Unstick Button or Replace Clock also if persist then check the connections to the contol panel
Oct 18, 2009 | GE Kitchen Ranges
I am getting an F7 error message more and more frequently. When the F7 message is on the display, my kepad does not work and I get an annoying beep. When I press "Clear" the F7 and beep will stop until the...
Hi
You don't say what type of GE oven this is so I will advise the following;
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning
On the 99 Range oven F7 indicates a shorted Clear/Off Key due to membrane switch or a shorted control or connector
On the GE XL44 Self Clean Oven F7 is Stuck keypad or control relay malfunction
Hope this helps. Please remember to rate my answer. Thank you.
Jul 07, 2009 | GE Ovens
F7 Code on my GE Profile Oven
Jun 17, 2009 | GE Profile JTP18 Electric Single Oven
Constant beeping and F7 is displayed
Hi tahitian,
The error code F7 means that the Function key is shorted or stuck. To fix this error, replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Hope it helps.
Thank you for using FixYa.
Dec 16, 2008 | Magic Chef 31000 Gas Kitchen Range
The lcd scrren on my range displays F7 in red and flashes d6 in g
The code is because of bad keypad/the control panel.Have it changed.It probably non-functional and constant beeping sound is followed as you mentioned.Theres a link to explain more about this for reference.The only solution is to replace the control panel.
http://www.askgene.com/2007/06/23/oven-error-codes/ge-oven-error-code-f7-and-how-to-fix-it/
Dec 13, 2008 | GE Spectra JBP78 Electric Kitchen Range
F7 display
Good news
The problem was solved by disconnecting the power supply for three minutes and power up again and F7 diaper.
Thank you all
Aug 18, 2008 | GE Profile JB968 Electric Kitchen Range
F7 error message on all screens with beeps
F7 for a Fridgidaire Range indicates a failure with the electronic Range Control (ERC). Unfortunately when these fault codes pop up, the electronic boards must be replaced. The part number for yours is 937801 and costs about $190. Is it possible you may have gotten cleaner on the board or possibly shorted out the buttons? Is your range still covered under a warranty? Double check your paperwork and see if the electronics are covered for an extended period beyond the normal limited warranty you get when you purchase a new appliance. Post back with comments and/or questions if you wish to repair the range. I hope this helps you.
Jan 29, 2008 | Frigidaire PLEF398AC Electric Kitchen...
GE JS905SKSS Stainless Steel Electric Kitchen Range Logo
83 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
