Question about Samsung UN55C8000 55 in 3D HDTVReady LCD TV
Is there any way to change the UN55C8000 to accept 220V instead of 110V, like changing out the AC-DC converter within the LED TV?
2 Suggested Answers
  • 98 Answers
SOURCE: Taking US Samsung TV and DVD player to India?
You need to get a transformer( 110 to 220).
Posted on Feb 06, 2009
Hello what kind of voltage use the power adapater?
The power adaptor has normally two voltages.
One is primary (Input) which is 110V AC in USA. 220V in UK and others.There are now a days Adaptors which accept both 220V and 110V. However the Adaptor pin will differ. It will be Flat pins for 110V and Round pins for 220V.
The other voltage is the Output which is fed to the Equipment and is Equipment specific. It can be 18V to 5.2 Volt DC. It varies equipment to equipment.. If a wrong Adaptor with output Voltage not matching with equipment requirement is selected, it may damage the equipment. Be careful.
May 21, 2015 | Sport & Outdoor - Others
How do I use this adapter in the US with 220 voltage
is it an 220volt ac - dc adapter you could buy a 110V AC to DC adapter with the same DC Voltage and current rating
or you could buy a 110V to 220 Volt adapter
http://www.banggood.com/110V-to-220V-and-220V-to-110V-Voltage-Transformer-Converter-100W-p-938645.html?currency=AUD&refreshTmp=1&utm_source=google&utm_medium=shopping&utm_content=lola&utm_campaign=Beauty-AU&gclid=CIG68_Gl2cICFVcJvAod7GgArw
be careful with switch settings
http://www.ebay.com/bhp/transformer-110v-to-220v
please be aware if timing is required or electrical motors this could be a problem as usa is 60Hz and your appliciance may be designed to run at 50 Hz frequency
there are devices that can convert freq from 60hz to 50 hz
https://www.youtube.com/watch?v=RV3hEKLNm74
http://www.frequencyinverter.org/
Dec 22, 2014 | Photography
I have a 4 prong tanning bed 220v and my appliance outlet at home only accepts the 3 prong plus such as the ones you see on a dryer. How can i get this converted to a 3 prong so that i can plug it in? Or...
It is because you tanning bed requires L1 and L2 (240V) and a seperate neutral, and a ground. You need an electrician to install a proper outlet. A dryer (years ago) was installed without a neautral. However per NEC electrical code even new dryers have to have 4 wires. Do not attempt to use on 3 wires !
Oct 02, 2013 | Coleman Powermate Premium Plus 6250W...
Bought from usa to australia changed to recomended fuse, fuse blows as soon as turned on the unit was brand new any ideas ?
hi,
You have to check the working voltage of the adapter of you device. If it purchased from US then it will be 110V. I think the Line voltage in Australia is 220V.Also You have to check is there is any input voltage selector in the in its adaptor . If it there you have to change it to 220V. If there is no such selector then you have to buy a 220v to 110v converter .Then connect the out put of that converter to to your device. You can by this converter at any electronic spare part shope near to you. Or you have to by a new 9V 1.3Amps AC adaptor. When you going to by the converter or a new adaptor take the device. If so they will explain you how to connect the converter or adaptor . By changing a fuse you can't change the operating voltage. If The adapter is designed to use in 110V then the fuse will blow. If you change the fuse and make more experiment with it it will make the full system useless.
ok
Aug 05, 2011 | Lexicon MX200 Multi-Effects Processor
Would like to change power supply to 12 VDC On Samsung LE37C580 37" LCD TV
The only way to do that is to buy a DC to AC converter...that is if you want to run your tv off of 12Volts DC. The converter converts the DC to AC so you can just plug up your set to the converter. The higher the ampage the better the results. Match your ampage of your tv to the converter ampage output. Just do a google search for "DC to AC converter". There are many availiable and many different prices. It is not practical to change the TV to receive DC voltage.
Jun 16, 2011 | Samsung Televison & Video
Power conversion
Ram,
Good day mate, no problem you can plug your dvd direct to your outlet since it indicates 100 - 240V it only means your player is capable of having either 110V 0r 220V.
note: also try to check 1st if you will see a voltage selector at the back of your dvd player. it's either a slide switch indicating 110 or 220V. if no sign of this selector no problem you can plug your player straight to your socket.
cheers
mark
Jan 29, 2009 | Durabrand DVD-1002 DVD Player
Change 120v chager to run on 240v
all you needs is a step tranformer from 110v to 220v ac
Nov 13, 2007 | Dewalt 7.2-18.0 Volt One Hour Charger
Samsung UN55C8000 55 in 3D HDTVReady LCD TV Logo
66 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
