Question about Emerson Microwave Ovens
The paint on the inside of my microwave is peeling off What can be done about this? Every thing else is doing fine, but it sure looks terrible when you open the door. Betty Wrenn Day
fridgetech
  • 473 Answers
SOURCE: peeling interior
The problem you may have is arcing (sparks) inside while cooking.  If you see this then it's time to replace the microwave.  It will depend what material is under the paint.  Just keep an eye on it while cooking and if you don't see any sparks then it should be ok.
Posted on Oct 16, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: peeling paint
You need to thoroughly clean it, then sand it smooth to removew all the loose paint.
Once it's squeaky clean and dry, you can apply high-temperature appliance paint, which is available in brush-on or spray-on form at big box stores like Wal-Mart, home improvement centers like Lowe's and appliance parts stores.
Posted on Nov 05, 2007
sharcnet
  • 2130 Answers
SOURCE: paint peeling inside microwave
If the unit has been operating properly for some time with no issues, I would say it is fine to continue to use. The issue I would have would be with the possibility with the paint falling into the food.
It would be interesting for you to call the manufacturers' support line and ask why this is happening. Maybe they will offer you a replacement if it was a manufacturing process defect. Mention that the paint may have fallen into the food.
Please let me know if I can be of further assistance to you.
- Jim
Posted on Feb 13, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: inside finish is peeling off
No, if the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Otherwise, you can have rust and arcing, which can be messy.
Posted on Nov 23, 2008
  • 4 Answers
SOURCE: PEELING PAINT INSIDE MICROWAVE/TOASTER OVEN
I do have the same problem, but I know they make microwave paint if you can get it from an appliance store or you can order through the web - BUT 2 sites I just looked at said a gloss enamel paint, such as that used to paint "model" toys works just as well. In either case: Smooth the old stuff off, sand lightly (you want no metal dust left -or- damaging any coating on the metal) just sand enough to make sure there's no flakes & it's smooth, then use a gloss enamel paint rather it's approved for microwaves or the Testor's kind.
NEXT -Make sure you DRY with Hairdryer to set the paint, and keep the heat to med or low, don't bubble or scorch your work!) and do not use the microwave for 24 hours!! Leave the door open while drying for several days afterwards if you can. Any fume smells can be absorbed by using -used- coffee grounds and leaving overnight. Google groups was one source the other was a repair listing forum.
Posted on Apr 03, 2009
Panasonic Inverter microwave, paint starting to flake under the ring.What can be done?
dont ever in future buy a microwave with a painted interior as it will always peel.......better to buy a stainless steel one.i don't know if there is a special paint you can buy but if you look on the internet you will find one.
Oct 24, 2017 | Panasonic Microwave Ovens
The metal is showing inside. The white coating is pealing. Is this dangerous?
The peeling of the white coating inside of the microwave oven is dangerous in terms of creating a fire hazard and potentially contaminating the food you cook within it. This can be prevented by cleaning up all splatters and spills immediately before using the microwave oven again. You can fix the peeling by replacing the microwave oven or repairing it. To repair it, you will have to remove the peeling coating and then repaint the interior of the microwave with paint that is designed for microwaves in general. Though, if you do this, you will have to let the paint dry up for at least 24 hours. I hope this helps you!
Feb 10, 2012 | GE Microwave Ovens
Inside of microwave top peeling and blistering
If it's paint peeling, then once that paint is gone, rust will set in, which can cause arcing and disintegration of the chassis, when ruins the oven.
This peeling is usually the result of excess moisture accumulating in the oven due to blocked air vents or poor fan circulation.
Once those two issues have been ruled out or dealt with, then always be sure to dry out or leave the microwave open after use.
The peeling paint will need to be removed, then the area should be sanded.
We're
Nov 28, 2011 | Morphy Richards AM925EF Microwave Oven
Paint inside microwave oven bottom is peeling
The oven cavity will probably start to rust where the paint is gone. If you're up to it, sand it and paint it with a color that matches the interior color. Other then colors, there is nothing special about paint inside a microwave.
Jun 20, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
White bottom panel inside the microwave is peeling in two spots. What can be done if anything?
affected area would need to be sanded and re-painted with microwave paint. repairclinic.com sells the paint
Feb 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Paint peeling
The paint you need is called microwave cavity paint. If they don't have it at your local hardware store, you may get it at www.appliance411.com/data.php?rc=277
Be sure to sand the area first with some emory cloth to remove any loose paint flakes.
May 07, 2009 | Rival MT660 Microwave Oven
Inside finish is peeling off
Nov 21, 2008 | Microwave Ovens
Aug 30, 2008 | Microwave Ovens
Peeling paint
Here is a link to buy the paint.
If the microwave is not creating a spark inside when in use, It's OK to use.
Mar 09, 2008 | Rival MT660 Microwave Oven
Paint peeling inside microwave
- Jim
Feb 13, 2008 | Sharp R-820B Convection/Microwave Oven
Microwave Ovens Logo
76 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
