SOURCE: Sharp Aquos LC-32D40U-picture goes off at random times
The bad news,your set needs a new inverter board installed.With persistence to sharp,you might be able to get them to pay for the parts.
SOURCE: TV turns itself on, keeps changing it's own channel
the problem is with the control panel of your tv...make sure your remote doesnt have any part in this...just remove and the batteries and check if the channels still are changing.....see if the onboard switch for channel changing is stuck ?..if stuck u can use homemade tools to pull it back......if your tv is within your gurantee period...just giv a call to customer care....if not u can take it to a local repair shop...there is nothin that u can urself do to make it right ...sorry....for further info contact at
SOURCE: Samsung LE37A659A Black Screen and White stripe
Get in touch with the retailer straight away, and have them fix it under warranty.That is why they give yoyu a warranty, so taht if anything DOESgo wrong, they can fix it for you.
SOURCE: Samsung 204B random blank screen
I too have a dual monitor Samsung SyncMaster 204 setup. My monitors started flickering, then a week later had turn on problems like your describe. I found a fix on this fixya website and followed the fairly techie suggestion. It worked. I wrote up a .pdf set of instructions so others might also benefit. Hope this helps. Doug
