Question about Maytag Washing Machines
Maytag model A512 is spinning slowly. I believe it is from 1987 question is repair or replace? All other functions are working well. Thanking you in advance for your comments.
  • Maytag Master
  • 8,220 Answers
Here is a nice video which shows what is entailed in fixing this wonderful machine:
Posted on Jan 03, 2011
Maytag A512. Screeching noise smokes. Belts replaced, water pumps fine, spins. It does not agitate but the agitator is fine. Not stripped. What other problems? Transmission? parts to fix it?
The agitator shaft, not the agitator, is corroded and does not move freely.Smoke is the overheated belts, you need a transmission overhaul, boot seal and tub bearing as well as replacing the agitator shaft, again, NOT the agitator.
Jun 06, 2017 | Maytag Washing Machines
Screeching sound; smell of burned rubber
What is the model number of the unit?
Oct 31, 2012 | Washing Machines
I have a washer Maytag Model A512 It was moved to install a new floor. The machine is level when put back. It now shakes a lot, on the spin cycle especially on the gentle cycle.
Pull the machine out and tilt it back and check that the shock absorbers are still connected, these are the 2 bars, 1 at each side that connect the drum to the frame. Also take the lid off and check that the springs are still connected and the counterweights are still in place (these look like concrete blocks)
Feb 22, 2011 | Washing Machines
Motor seems to run but won't agitate or spin.
Dont take it apart you dont know enough to do that safeky!
It could be the pressure switch and or hose. Put that to a local techo and see what he offers to charge to fix it.
Oct 20, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Does not agitate, will fill and spin out water. How to diagnose?
take top control panel off and check your lid switch odds are its the problem
May 26, 2009 | Maytag Washing Machines
Steps to disassemble Maytag washer's transmission mod LAT9704AAE
I had an outside service tech. to repair it . He replaced seals and bearings .
Apr 01, 2009 | Maytag Washing Machines
Older Maytag fills with water, but doesn't run.
I have a 20 year old A512 & replaced only a very few items on it (fill valves, belts & air gap).
I would troubleshoot it & repair myself....can you use a voltmeter & are you comfortable exposing the timer / wiring.
My guess is motor (or timer, but less likely since its dead in all cycles). but you've got to get a solid diagnosis so you can order parts.
I suggest oyu find a guy on Craigslsit to repair..
cheers
Bob
Feb 05, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Maytag A512 screeching
Well ofcorese you will require those tools..
Apr 08, 2008 | Washing Machines
Maytag A512 Leaks out airgap when draining/spinning out
Check pump. I would say it is the most likely cause for the water leak, especially if itdoes it while filling and on spin as the pump holds some residual water in it . That is normal.
Feb 10, 2008 | Washing Machines
Washing Machines Logo
186 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
