Question about Cerwin Vega LS-15 Speaker
V-35 Cerwin Vega
Help i blew the compression driver for my horn in these monsters and need to replace..please help with model number..of compression driver to use..Cerwin Vega V-35 C...
  • turbo37 Mar 04, 2009
    I have the same problem with a pair of Cerwin Vega V-35s. The mid-range horn does not seen to be working on either speaker. The CV schematic shows the horn as part number MP-40 (1512) 16 ohm. I'm not optimistic that CV has replacement parts but surely there are replacenet drivers out there somewhere. Any suggestions? I'll check the ohms first.
Turbo 37: Did you ever root cause your V35's? I just ran across this post. I own a pair and have done some amateur / professional speaker building. Let me know if you still want to repair. tro
Posted on Apr 02, 2011
My Cerwin vega xls 15s doesn`t work!
Blown circuit. The question is; was it the power supply that blew out or was it the amp? check for fuses and see if they are ok. If they are not, replace them. IF they are then you are going to have to get new amp and or power supply.
Apr 26, 2013 | Cerwin Vega Audio Players & Recorders
I have a set of cerwin vega AT15's my dog decided to put his paw through the one surround and puntured the paper cone I need total 15" woofer replacements or repair. or I need replacements I can buy and...
Ebay sell Cerwin Vega Surround (rubber bit) replacements. If he has ripped the cone too, appart from replacing his back legs with wheels (joke!), contact Cerwin Vega directly and they will send you out a new "driver". These are easily fitted at home by any one with a screwdriver
Sep 02, 2010 | Audio Players & Recorders
Hi, am looking for a replacement of the tweeter horn model KSN 1165A for my V152 cerwin vega
djsusan56,
If you are looking to get an exact replacement, use the link below. CV considers themselves as a high end company so they are always looking to help there customers as a high end company should do. Opt to send the driver back to CV as they could very well just send you another new driver for free or at least sell you a replacement.
http://www.cerwinvega.com/service-procedures.html
-Chris
Aug 18, 2010 | Cerwin Vega V-152 Main / Stereo Speaker
What is the best amplifier to use to drive the cerwin vega cls 215 speakers?
optix422000,
Use a "real" amp, not a receiver as your CV's need real power to perform the best. Check the following links for some choices. I use the first as it's a monster for low-end.
http://www.adcom.com/prod/shopdisplayproducts.asp?prodid=1322
http://www.crownaudio.com/amps.htm
http://www.us.onkyo.com/model.cfm?m=A-9555&class=Amplifier&p=i
Remember to shop online wisely and only purchase from a authorized dealer.
-Chris
Aug 15, 2010 | Cerwin Vega CLS-215 Main / Stereo Speaker
Specifications of cerwin vega pro stax scoop sub
http://www.cerwinvega.com/pro-audio/portable-sound-system/int-118.html
You can always contact Cerwin-Vega and tell them the model number to get the exact info you need even on older models.
-Chris
May 25, 2010 | Cerwin Vega Pro Stax 12" 2 Way Stage...
When playing on high volume the treble dissapear. I have a 2.6kw Cerwin amp. And Clsc 215 speakers. No bi- wire on my speakers. When I lower the volume the treble returnes. What is wrong???
Sounds like your overpowering the horns and the circuit breaker is tripping to prevent them from blowing. You are running more power then they can handle. You can turn down the volume or will have to purchase higher wattage horns...
Mar 24, 2010 | Cerwin Vega Cerwin-Vega CLSC-215 3-Way...
Need to find a cerwin vega 6 1//2 mid range woofer model number v-6f but i would like just the speaker only not the whole floor stand
muz782,
Replacement drivers for home speakers are only sold directly from Cerwin Vega. If you can find one online, it will not be authentic CV.
http://www.cerwinvega.com/contact_us.php
-Chris
Feb 11, 2010 | Cerwin Vega V-6F 6 1/2" 2-way...
I have a blown LW12 Cerwin Vega Speaker. Can
You have several ranges of options.
1) Contact Cerwin-Vega customer service: http://www.cerwin-vega.com/
2) Do a google search on "cerwin vega speaker replacement". You will find companies both that offer repair or repair kits (e.g., www.simplyspeakers.com) or sell replacements. Contact them - they have the expertise to tell you which of their products are most suitable for your model.
Nov 01, 2009 | Cerwin Vega LW12 Subwoofer
Cerwin Vega V-35 Horns Drivers Model TMH-1
first you need a multimeter set to OHM , check on the back of the horn , remove the leads and do some reading , it should read 4 , 8 , 16 ohms depending of the brand , if you get no reading its means that need to be replaced , some horns you can detach the back (magnet w/the coil ) so you can replace it without buying the whole unit . good luck
Apr 19, 2008 | Cerwin Vega LS-15 Speaker
Cerwin Vega LS-15 Speaker Logo
1,145 people viewed this question
Top Cerwin Vega Audio Players & Recorders Experts
 Grubhead
Grubhead
Joe Lamb
Joe Lamb
Steve
Are you a Cerwin Vega Audio Player and Recorder Expert? Answer questions, earn points and help others
