I have loaded 2 films onto my 4gb card when i go to delete them it says they are write protected and will not delete them
  • 731 Answers
Try right clicking the file and select "Properties"
At the bottom of the new window in the area labeled "Attributes" insure that the box "READ ONLY" is not checked
Posted on Jan 03, 2011
How do i remove write protection from a memory card 4GB cant delete files or move files,if i want to format it says remove the write protection
+look if your lock switch on the memory card is in ON position generally this is the case if it is ON then switch it OFF and try moving the files to or from the memory card
if you are happy with my solution please rate me high and vote for me
Mar 28, 2011 | PNY 4GB Secure Digital High Capacity...
I have a Telefunken TMP-444B, 4GB MP3/4 player. The setup soft ware disc does not load to any of my computors. Where can I download it. Cannot load music onto the player
Hopefully you got a solution already, but here goes mine: I also had a Telefunken TMP-444B, 4GB MP3/4 and i found you don't need a cd (my cd also didn't work). Try connecting it to your pc via usb-cable and access it on your PC. Simply copy your Mp3 or mp4 files onto it and see it should work. Mine did. Hope yours will.
(Just take care when deleting files, because i don't know if important files are protected on your mp3/4 player). Take care anyway ;-)
Cheers
Feb 05, 2011 | Audio Players & Recorders
Genx usb flash 128 Mg is write protect how i can remove write protect
1.Look for a switch or button on the side of the micro SD card or adapter. It might have a lock/unlock symbol on it. 2.Move the switch to the "Unlocked" position to remove write protection. This position may also be labeled "R/W" for read/write. If you have no switch, continue to Step 3. 3.Download and install Sony EzRecover (see Resources for link) and attempt to use it to format the card (this will erase all content). If this doesn't work, try Step 4. 4.Delete and repartition the micro SD card using Windows XP. Select "Control Panel" > "Administrative Tools" > "Disk Management." Select the micro SD drive and click "Delete." Right-click on empty drive and select "New Partition."
Dec 27, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
When i inserted 4GB pendrive in the pc when i open the pendrive it doesn't open and shows write protection and it can't be formatted at this situation.
Dec 27, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Write protected memory stick
1.Look for a switch or button on the side of the micro SD card or adapter. It might have a lock/unlock symbol on it. 2.Move the switch to the "Unlocked" position to remove write protection. This position may also be labeled "R/W" for read/write. If you have no switch, continue to Step 3. 3.Download and install Sony EzRecover and attempt to use it to format the card (this will erase all content). If this doesn't work, try Step 4. 4.Delete and repartition the micro SD card using Windows XP. Select "Control Panel" > "Administrative Tools" > "Disk Management." Select the micro SD drive and click "Delete." Right-click on empty drive and select "New Partition."
Dec 20, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
My sandisk 4gb microSDHC card has write protection on it, i right clicked it to turn it off, but i don't see an option to do that, how do i do that? i have a windows vista
SOLUTION 1 - Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
SOLUTION 2 - Toggle the lock switch.
If the lock switch is not on lock:
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to transfer files into the device.
Aug 09, 2009 | SanDisk 4GB microSDHC Memory Card
How to protect pictures so they do not get deleted
Best way is to only delete them 1 by one. Another is to transfer files (pictures) to your computer delete the ones you don't want, format your card and then put the ones you want to keep on your camera back. You can't delete just a few pictures. I carry 3 memory cards. one just has the pictures I want to show people. I load that card from my computer. The other 2 are like great big rolls of film that let me take lots and lots of pictures without the worry of running out of film. I transfer the pictures I want to show people on my camera to the third one and keep the other 2 erased. Most of my pictures are only on my computer and backed up on DVD's.
May 11, 2009 | Nikon Coolpix S550 10 Megapixel Digital...
Cannot remove write protection on sandisk cruzer usb pen.
The memory cards also have a write protection switch to protect data from being deleted or overwritten, just like a floppy disk
Dec 03, 2008 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
How 2 delete u3 programs on flash drive
i have the same flash drive it just depends on how much gb u have and yes u should be able to just instull it directy from ur computer to ur flash drive just mess around with it try samller things onto ur flash drive
Nov 30, 2008 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Does not read from adapter
then it must be password protected.Delete the password of micro SD from your cell and then try.........it must work........
Apr 16, 2008 | SanDisk 4GB microSD High Capacity Memory...
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
