Question about Whirlpool 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice & Water - Satina Stainless-Look
Fridge isn't getting cold enough - Whirlpool 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice & Water - Satina Stainless-Look
    Brigadier General:
  • 3,917 Answers
Hi
Please check the bellow link to troubleshoot your problem and to have a detailed knowledge as to why your refrigerator is not cooling enough:-
http://www.acmehowto.com/howto/appliance/refrigerator/diagrefrigerator.php
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Jan 03, 2011
My GE model GSH25JFTCBB side by side is not cooling in the fridge side. Freezer seems to be doing fine. What could be wrong
you could have a defrost problem,a bad damper,bad computer board.first thing,open the freezer door,do you hear the fan blowing in there?you should,if not the evap fan motor is bad,if it's blowing touch the back inside wall of the freezer to see if any frost or like snow is on it,from the bottom up in the freezer remove the second bin of food and touch the back inside wall with your hand,if it has frost or snow you have a defrost problem,bad defrost thermostat,heater,sensor or board,if there isn't anything on the wall then you have a bad damper,all that happens is the evaporator coil in the freezer gets cold,then the evaporator fan in the freezer blows the cold air over into the fridge section,you have a damper in your machine that opens and closes when it's cold enough or when it needs to get colder,the door on the damper isn't opening to let the cold air in when it calls for cold air.if you can write back and let me know what you find and hopefully we can get it fixed.
Sep 15, 2012 | GE Refrigerators
Nt side by side fridge freezer not freezing
If the machine is running all the time a few things could be happening, The defrost timer could be bad, but if that is the case then you should see a build up of ice forming on the wall that covers the evaporator coils. Another situation is that your machine is low on freon and not reaching a temperature cold enough for the temperature control to shut the machine off. Third and last the temperature control itself could be bad and thinks the machine isn't cold enough. in that situation you would notice ice build up as well. Hopefully this helps.
May 22, 2012 | Hotpoint Refrigerators
Hi, I have a Samsung refrigerator and the top part isn't cold enough and the freezer is working perfectly fine. I need help fixing the fan.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 03, 2011 | Samsung Refrigerators
Freezer and fridge cooling but freezer not freezing and fridge not cold enough
Their are a couple things that could be causing that.
The conderser coils under the kickplate below the doors is clogged with dust. Remove the kickplate and check/clean using a refrigerator coil brush that could be purchased from your local hardware store (Lowe's HomeDepot Ace hardware)
The condenser fan motor behind the refrig., behind the lower service plate directly next to the compressor isn't running and needs to be replaced.
Good luck,i hope this helps you to get your refrig back to cold,
Gene
Aug 13, 2011 | Amana ARS266ZB Side by Side Refrigerator
Hotpoint (GE)CTX18GJB not cold enough. Just had serviced - tech replaced defrost timer and defrost terminator. The top located freezer gets cold and can hear the fan running - but still not cold enough...
I agree with the tech. if the refriderator isn't frosting it isn't working,their is only 1fan and its in the freezer,The tech could have missed some frost build up that is blocking the air flow into the fresh food section,if he removed all the frost it could take up to 24 hours to get cold ,it should slowly geta bit colder throughout the day,if by tomorrow its still not working have the tech come back and check for frost build up on the vents for air flow into fresh food compartment.
To reiderate their is two types of refrigerators,one that you have to manually defrost and a automatic defrost type where the defrost system which is comprised of the defrost heater,timer&termination t-stat will automatically melt the frost
Jul 28, 2011 | Refrigerators
Frigidaire refrigerator model # frs6r5emb8 wont get cold and freezer wont freeze. I replaced the filter and cleaned any and all dust out from the rear bottom of the refrigerator. Freeze wont get cold...
first off the freezer is cold but not cold enough?if the freezer isn't working right then the fridge is gonna be warm too,all it does is get cold in the freezer and the evap fan blows cold air into the fridge,that's it.i need you to do a few checks for me,open the freezer door,do you hear the fan blowing around,if not you could have a bad evap fan motor,next from the bottom up remove the second bin from the bottom and touch the back wall,do you feel any ice or snow on the back wall.if so you have a defrost problem,possible computer board,defrost thermostat or heater.let me know what you find.one more thing did this happen after you cleaned it or did you clean it to try to see if it would help?
May 15, 2011 | Refrigerators
Whirlpool 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice & Water - Satina Stainless-Look Logo
55 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
