The heat pump is not working properly. i think the problem is in the switch mechanism. when the heat is on and the thermostat is turned up it blows cold air. sometimes the compressor turns on and off. if you turn the other switch to the off position, then turn the thermostat up then turn it back to heat. it will blow hot air. if you then turn the thermostat down, wait till it turns off, then turn it back up, it will blow room temp air and sometimes the compressor will turn on.
  • 43,501 Answers
The problem may be the switch, but it sounds more likely that the contactor in the outdoor unit is bad and is not making all of the time...then the compressor will not always run...
To figure it out you will need to catch it at a time when it does not owrk and then follow the electric back till you find out why there is no power...
It would be best to have an electrical meter and have this done by an experience person so that you do not get shocked...
heatman101
Posted on Jan 03, 2011
Heat Pump - blows heat to set temp, then off, then kicks on to blow cold
Heat pumps defrost which is the AC mode, if the heat strip isnt working during a defrost, the air will be cold, A heat pump only feels warm if the heat strips are on too! the refrigeration cycles heat output is much less sensible to our 98F skin. heat pumps that satisfy a room setpoint are working at least, all heat pumps feel drafty to most.
Oct 28, 2012 | Honeywell Programmable Thermostat Heater
I have a new Rheem heat pump. The cooling works fine but won't blow hot air in HEAT setting. I have reset the breakers for heat pump and air handler, changed filters and pulled batteries and reset the...
if this is indeed a heat pump you rthermostat should also have a emergency heat setting does it work on that setting... a heat pump on heat wuns the outside unit and has a recersing valve that changes the refigerant flow ..is the outside runnignduring heat mode... if you turn the thermostat in emergency heat the outside should shut down and indoor heat should come on...of this is not happening you have a wiring issue if both are not working... braeburn thermostats usually have behind the cover dip switches... i am not exactly sure what model this is but if indeed a heat pump the thermostat should have a r,w2,y,e,g,c,o,and b terminal... rheem wiring should be as follows
red to r white to w2 , g=green , yellow to y terminal there should be a wire hooked to the b terminal usually brown sometimes orange on the b terminal that is your reversing valve terminal.
you are going to have to make sure the thermostat is configured to energize the b termianl and will have to go into the installer setup to do this...hopefully you still have the paper work on thermostat... most heat pumps use the o terminal for reversing valve but rheem uses the b terminal
hope this helps out some repost with anymore probs...also make sure the switches are set to electric or gas whatever you have heat pump or not etc. inside thermostat
Jan 05, 2011 | Heating & Cooling
I have two Friedrich PDE15KSB-C units. When trying to turn on the heat neither will kick into the heat mode. They both blow cold air only. When they are first turned on the air blows, and there is a...
Keep +10 degree from your room temp and also thermostat in "heat" . And then check. But in your case, I think RV not energized. If no proper voltage in RV in heat mode, check the wiring to RV. If voltage in means RV not working properly. You have to change RV. Thanks.
Dec 14, 2010 | Friedrich PDE15K3SB Portable Air...
I am getting hot air instead of cool air from my heat pump when it is in the cooling mode.
The problem is in the thermostat wiring. Y1 on an air conditioner, brings on the cooling. On a heat pump, it brings on the compressor, which generally fails to heat mode. The O wire operates the reversing valve, which brings on cooling. If these wires are reversed, or not hooked up, you will not get cooling.
Jul 12, 2010 | Goodman CLQ36AR49 Air Conditioner
My nissan max continues to over heat. i replaced the radiator. but the mechanic did not replace the thermostat properly. do you think the over heating is due to needing a new thermostat?
not at all times can thermostat contol your cooling system, check for water leaks, water pump, radiator fans(check for speed) if all your cooling systems are good , replace your cylinder head gasket,
Jun 25, 2010 | 1995 Nissan Maxima
Energy Knight heat pump refuses to blow!
Does this problem happen when the temperature is below 30 degrees? When it gets about that cold outside, the air outside is too cold for the heat pump to "steal" heat from. On the thermostat you'll find a switch labeled aux or emergency heat. Turning this switch on will operate a traditional coil heater inside the system, providing you with heat. The only downfall to this is that it uses more energy to heat this way. Try turning the fan switch from "auto" to "on". If the fan comes on, then we can rule that out. If the aux heat switch is NOT on, set the thermostat such that the system will try to heat. If the outside unit is running, the problem is either it being too cold like I said earlier, or there's a problem with the heat pump's mechanical system that needs to be serviced by a professional. If the outside unit doesn't run but it should be, check it's breakers at the panel, the breaker inside the electrical box that feeds it, and look to see if there's a reset button on the unit itself. Finally, check the air handler (part of the system inside with the fan in it) to see if there's any circuit breakers or fuses on this unit. Make sure they're not tripped/blown. If none of this helps, you definitely want to get a pro to work on your system.
Feb 27, 2010 | Heating & Cooling
MY HEATER BLOWS HOT AIR THEN BLOWS COLD THEN HOT THEN COLD,ICHANGED THE MOTHER BOARD, RELAY SWITCH, AND THERMOSTAT, IT IS RUN FROM A HEAT PUMP WITCH I HAD CHECKED AND IT WORKS FINE
I have a lux electric thermostat my furnace will blow out heat for about one hour to maybe three then it will start blowing cooler air,I then cut it off for thirty seconds or longer once I do that it will start blowing out heat again then it will repeat it self again what could be the problem.
Jan 07, 2010 | Heating & Cooling
WHY DOES MY RHEEM RBHC-14J11SFD BLOW ONLY COLD AIR? THE AIRCONDITIONER WORKS, HOWEVER THE HEAT DOES NOT TURN ON. THE THERMOSTAT IS SET TO ON AND TO THE HEAT POSITION.
Heat pumps tend to blow a much lower temperature outlet air than a gas fired unit would. Is this your first year with this furnace?  Depending on your outside temps, an auxiliary heat strip may not be operating properly.
Jan 05, 2010 | Heating & Cooling
Blowing out warm air
Turn thermostat switch to 'cool' setting. It's a 'heat pump' and is in the heat mode.
Nov 05, 2009 | Coffee Makers & Espresso Machines
Heat pump that just blows cool air
is the condenser operating? what is the outdoor temperature? A heat pump is a cooling system with a reverse gear, most reversing valves which make this possible fail to the heat mode so it is not likely to be the problem. You should have either gas or electric back-up heat. If you switch to emergency heat do you get warm air? Really need to find out more to make an informed guess at your problem, the simple stupid would be is the circuit breaker to the condensing unit possibly tripped or shut off?
Dec 18, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
50 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
