Question about GE WBSR3140DW Top Load Washer
Water not fill up and cycle button blink - GE WBSR3140DW Top Load Washer
  • GE Master
  • 43,501 Answers
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Posted on Jan 03, 2011
My dishwasher(samsung DW7933LRABB) wont fill, it will drain if i put water in the tub. supply is on.
You either have a bad water valve, or a bad case-brake assembly (in which case you should have an error code or blinking light on your console).
Mar 06, 2015 | Samsung Appliance DW7933LRABB 24" Tall Tub...
Samsung dishwasher flashing heavy light
Had a look in the user manual for your dishwasher.http://downloadcenter.samsung.com/content/UM/201211/20121101114232459/DW7933LRASR-00141A-02.pdf
Page 26 shows blinking Heavy light means there is leakage in the dishwasher. Most likely there is water in the base under the drain sump which could cause the flood switch to trip. Turn mains power to dishwasher off. Pull it out from under kitchen bench without breaking the hoses. Put some towels on the floor and turn dishwasher back and forth on incline to get water out. Wait a little and turn on. If no difference then you need to dry the base and find the source of the leak. More likely the door seal.
Apr 03, 2014 | Samsung DW7933LRAWW 24" Tall Tub Built-In...
New pot that will not go through 1st cycle
Hope you did fill the plastic canister on the back, with water
because what you write there is what it does when there is no water in it
Feb 05, 2014 | Philips Senseo HD7832 Coffee Maker
White Magic 650H. Why is error code PE displayed and water reuse LED blinking?
In my research, the PE error relates to the fill level of the washing machine. The fill level sensor is a pressure operated device. There is a sealed air line that goes from the bottom of the tub to an air pressure sensor. As the tub fills, it compresses the air in this air pressure sensor. When the tub is filled to the level selected on the dial, the sensor stops the fill cycle.
This air line can be plugged or the sensor itself can be faulty. This air pressure sensor is usually located near the top of the tub just under the top cover. If you can locate it, disconnect the air line from the pressure sensor and blow through it - it may be blocked by lint and soap from several washing cycles. There may be a filter in this line to help prevent this blockage. But the filter may have become blocked itself.
Sep 29, 2013 | Whirlpool Washing Machines
After working well for six months, my washer now expels water at random points during the wash and rinse cycles.
Check inside the fill hose for debris. There is a screen designed to block debris from getting inside the machine valve. If the screen builds up with debris the water slows down. Sounds like the water is filling too slow. Also the unit and/or the load may not be balanced causing it to stop and drain out. If it's okay then see what lights are blinking when these events occur and post here.
Jun 06, 2013 | Haier HLP21E Top Load Washer
Fills up with water, wont wash, drum motors works
Sounds as if this computer is trying to display an error code. If switching cycles manually makes it work, then it is most likely a bad circuit board. Try doing a google search for "Kenmore washer lights blinking" or something to that effect.
Jan 30, 2013 | Kenmore 3.5 cu. ft. Front Load Electric...
KENMORE DISHWASHER CLEAN LIGHT BLINKS SEVEN TIMES M#665.17029403
The thermistor beneath the accumulator inside the sump detects the water temperature as it begins the first 8 minutes of the main wash cycle. During this time, the controller expects the thermistor to detect the 2-4 degrees rise in the water temperature when the first 8 minutes is completed. If the expected temperature rise is not met, the controller will not be satisfied. It will shut the dishwasher down and blink the clean light 7 times. Press the heated dry then normal wash buttons in the same sequence two times. The unit will enter diagnostics mode, but can be stopped by pressing the cancel button. It will clear the fault and makes the dishwasher run normal but the fault will appear again if you have problem in either of the following:
  1. Heater and its circuitry
  2. Water filling
  3. Pumping motor
If the heater is not working, the water temperature will not rise then controller will shutdown the machine.
If there's no water entering the machine, no water will be heated and there's no way the controller through the thermistor can detect any rise in temperature.
If the pumping motor is not working, the water cannot circulate over the heater and be heated. Again, the controller will not be satisfied.
You can bypass this fault detection feature by filling the machine either with extremely cold or extremely hot water. Water colder than 62 or hotter than 160 degrees Fahrenheit will make the controller not to check for a temperature rise but rather continue on the next cycle.
Please let me know if the problem still bother you.
Dec 03, 2009 | Refrigerators
Washer fills slow only in the rinse cycle
Need a model # to get exact part you will need at rinse most washer go straight cold so I would say water inlet valve if humming sound is present
Apr 28, 2017 | GE WBSR3140DW Top Load Washer
GE WBSR3140DW Top Load Washer Logo
41 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
