Question about Boating
I have a Johnson 140 four stroke. After the first service I checked the oil and it was dark brown. The mechanic showed me how the proper oil is that colour in the tin. At the second service the oil was clear and the oil level is much too high. Should the new oil be brown and what is the danger of the oil being overfilled by nearly 1 inch?
  • 4,350 Answers
The color is less important than the correct grade of oil. Overfilling can blow seals, drain down to the correct level.
Posted on Mar 13, 2011
Carbies on 50hp Johnson outboard fill with oil when left standing for extended times
2 stroke , excessive oil in mix and it is settling out after the fuel evaporates off
4 strokes the unit should be left in the drive position when not used
Dec 16, 2017 | Johnson Boating
Is a 1978 Johnson 115hp outboard a two or four stroke
for that year of manufacture 4 strokes were not the normal thing in outboards
if it doesn't have rocker covers and rocker gear it is a 2 stroke
Jun 24, 2017 | Johnson Boating
What is the gap setting for a champion 910 spark plug for a johnson 6hp four stroke outboard motor
if the plug is a standard plug as used in a car , it is the wrong plug
the plug to use is a multi point plug or anti foil plug and the gap is preset
single point plugs such as used in cars motor mowers etc , foul up from the oil / fuel mixture that deposits carbon across the gap so the use of a multi point anti foul plug is recommended in outboard engines
if you persist , for an conventional magneto /coil operation .025" and a later electronic ignition .050"
Sep 30, 2016 | Boating
Do I use reg gas or a gas mix?
Matt, If engine is two stroke and not oil injected then yes you must mix 2 stroke oil and fuel. 4 stroke engine have a crank case which is filled to proper level with 4 stroke engine oil. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Decide Between Two or Four Stroke Outboard Boat Engine
4 Stroke Outboard Motor vs 2 Stroke Outboards
2 stroke outboard Vrs 4 stroke outboard
http://www.cottagetips.com/tips/boat-motor-gas-to-oil-ratios
Apr 15, 2016 | Boating
I have a 140 Suzuki 4 stroke and a small oil leak.. where are the coolant lines in the engine please
go google and type in--- workshop manual for suzuki 140 hp 4 stroke outboard and there are manuals that are available on different site
the manuals will show where the lines are
one site --servicemanualspro.info--- has a pdf down load link
Dec 02, 2015 | Boating
I have a 1998 model E25RMECA I NEED TO KNOW WHAT TYPE GAS TO USE IN IT. AND IF IT IS 2 CYCLE OR 4CYCLE.
I found a mixture of sites for the information
one owner of a 1998 25 hp evinrude says that it is a 2 stroke with a fuel mix ratio of 50:1 as 25:1 is a bit smokey
another site says that the recommended octane fuel rating is 87 although it might run better on 91
best advice is to find an evinrude service dealer and get the right information as the later 25 hp units are etec engine which will be 4 strokes
Oct 23, 2015 | Clymer Evinrude/Johnson 5-70 Hp...
Have just bought a 1993 90hp v4 johnson and would like to know what type of oil to use in the oil resevior
Any tcw3 two stroke oil . I am a marine mechanic and I would recommend disconnecting the vro which is the oil injection. Just disconnect the oil line and then mix the oil in the gas 50 to 1. The vro is known for going out and taking your motor with it
Dec 03, 2012 | Boating
Johnson 235HP Outboard - oil leaking from bottom leg - dark black so picking it is the two stroke oil
most 2 stroke motors will not burn all the oil in the mix and that unburned oil coats the exhaust leg and leaks out the thru hub exhaust and parting line of the lower to the housing. so keep some windex handy and clean it up.
Oct 09, 2012 | Clymer EvinrudeJohnson Outboard Shop...
Tilt trim go up wont go down 2003 johnson 140 hp 4 stroke
You may want to check service bulletin #2002-052. Some of these motors supply too much voltage to the trim switch at the throttle lever and that trim switch stops working. There is an add-on harness #586806 that fixes this. If you can still tilt and trim the motor at the trim switch that is built into the motor housing this is likely the problem.
Jan 30, 2012 | Boating
Johnson 4 stroke 115 hp will not start. fuel
Sounds like and injector problem to me. If it was a 2 stroke I'd tell you to pull the carbs and clean them ,but EFI is a whole different story. Most certaintly a fuel problem, most likely injector related, you'll most likely need to go see a marine mechanic with the proper equipment to analyze, rather than start replacing parts you may not need.
Jun 20, 2009 | Boating
Boating Logo
95 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
