Question about HP Compaq nc6000 Notebook
Whenever i plug in the ac adapter, after some time the cursor goes crazy!!!! any help please!!!
    President:
  • 3,278 Answers
Hello.
Your A/C adapter is faulty and needs to be replaced, since the problem doesn't occur with just the battery.. You can purchase it through HP or online from another site. Check the specifications, such as Voltage and be certain that your specific HP model can work with the new adapter.
Hope this helps.
Posted on Jan 03, 2011
I have a compaq presario cq50-107nr and i plug my charger in the front light is on but when i press the power button to start up the light goes off and nothing happens help? It happen several times and i...
Please 1. unplug the ac adapter, detach the main battery, press the power button for 15 seconds, plug in the ac adapter, and restart your laptop. If the problem persist: 2.unplug the ac adapter, detach the main battery, press the power button for 15 seconds, take out the hard drive, plug in the ac adapter, and restart your laptop. If the problem persist, then it means that the laptop motherboard is dying. Please read your laptop's service manual before you open the laptop's case/body.
Mar 01, 2014 | Computers & Internet
Tip
AC adapter connectors
<a>HP, Compaq, Toshiba a</a>nd some others have problems with their AC adapter connectors on the motherboard. This is because they are not secured to the motherboard very well. They are just soldered to the board by the adapter leads. This puts stress on the leads whenever the plug is bumped or from plugging and unplugging the adapter. The adapter connector will, over time, become loose. The adapter will then not charge the battery, and when the battery becomes weak, the system will not power on. Some times, the unit will power on, but will shut off if the adapter plug is wiggled. If you continue to operate your system in this state, heat will build up from arcing at the ac connector and will burn the motherboard. If not repaired, the system board and CPU could be damaged beyond repair. Replacing the motherboard is then the only option<span> This could cost $350 and up. So the word is </span><span>GET IT REPAIRED EARLY</span>
on Apr 25, 2011 | Computers & Internet
HP screen goes black 5 seconds after ac adapter is plugged in or out
This may not be the ac adapter itself. the metal prongs on the side of your HP Laptop to connect to the wire of your ac adapter may be bent or shortciruited. try to get a replacement which may be hard depending on what type of HP Laptop you own. or you may just have to send it back if you dont know how, in order to avoid breaking the warranty policy by mistakenly damaging it.
Apr 18, 2013 | Computers & Internet
My toshiba satellite U505 turns off suddenly when i turn it on. What might be the problem
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
http://www.chargerbuy.com/replacement-toshiba-satellite-u505-ac-adapter-19v-3-42a.html
Nov 22, 2012 | Toshiba Satellite U505-S2940 Notebook
When i plug my ac adapter the screen flickers a couples of time then i goes black
Hi grice2000,
The easiest way to fix this problem is to perform a power drain. Please follow the instructions below.
1. Turn off the system completely.
2. Unplug the AC adapter from the power outlet.
3. Remove the battery from the unit.
4. Now, press and hold down the power button for about 15-20 seconds.
5. Put back the battery in and plug the AC adapter.
6. Reboot and observe the system.
Hope it helps.
Thank you for using FixYa.
Jan 09, 2011 | Dell Inspiron E1505 Notebook
Inspiron 1318 but when I connect the ac adapter cpu 100%
It is a possible AC adapter problem. However please try to download the BIOS firmware update from Dell's website and see if problem exists. If it does, then try using another AC adapter (preferably the same model and make) and see if the same problem occurs. Please reply if same issue occurs.
Aug 10, 2009 | Dell Inspiron 6400 Notebook
Cursor going Crazy!!!!
unplug the ac adaptor and see if the cursor is still going wild on you.
Jan 29, 2009 | HP Compaq nc6000 Notebook
Laptop / AC Adapter Problem
It maybe the problem of your laptop ac adapter,find a new universal laptop ac adapter to have a try.
Sep 14, 2005 | Fujitsu Siemens Loox 710 Pocket PC
HP Compaq nc6000 Notebook Logo
23 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
