Question about Sony Playstation 3 (PS3) Console
My playtstation 3 turns on for about a minaute then turns of, with just the red light on solid when it does
    Guru:
  • 91 Answers
Solid red light means that it is in sleep mode which is caused by hold ing down the red light try to press the read light for around 3 secs to turn on good luck :)
Posted on Jan 03, 2011
No sound or picture. red timer light on. wd60735
This model as 3 LED indicator lights:
1) Power/Timer 2) Status 3) Lamp
If "STATUS" LED is blinking RED:
1) Internal Fan has stopped. These tv's require fans, to prevent overheating and causing damage.
If "STATUS" LED is solid RED:
1) Circuit failure (short)
2) Disconnected DVI cable, chassis to engine
3) No LAMP-EN signal from Engine to turn the lamp On.
4) Ballast UART communication problem.
If "LAMP" LED is solid RED:
1) Lamp Failure - Lamp failed to turn On.
2) Lamp is broken (e.g. burst or blown)
3) Lamp turns Off during P-ON
There is no data relating to TIMER LED being solid RED.
Hope this helps.
Cheers,
Scott
Feb 01, 2013 | Mitsubishi Televison & Video
I NEED T.V CODES FOR A ADMIRAL T.V AND NEED STEPS ON HOW TO SET UP CODE FOR A INNOVAGE REMOTE
Hello
Code for Admiral TV with Innovage remote control are:
001,173
CODE INPUT SETTING:
You will need the list of codes to manually select and input the correct codes to your
specific device.
1. Turn on the device that you want to set.
2. Look for the brand name under the specific device listing provided.
3. Aim the remote control at the device and press down and hold CODE SEARCH button for
at least 3 seconds until the red LED lights up solid red.
4. Press the device button for the item you wish to program, e.g. TV, DVD, VCR, etc. and the
LED light will blink once and then remain solid red.
5. Using the number keys, enter the 1 st set of 3-digit codes from the list. You will notice
that each number that you press, the LED will blink once. After you have entered the
3rd digit, the red LED will turn off indicating that the code was recognized for the device.
(NOTE: If the code entered was not compatible, the red LED will flash several times.
You will then need to repeat Step 3. You have 30 seconds to enter a code.)
6. After the red LED light has turned off. Press the ON/OFF key. If the device you are trying
to program powers off, then you have found the correct code. If the device does not
power off, then you will need to repeat the process again from Step 3, using another
3-digit code.
7. Make a note of the 3-digit code for future use.
CODE SEARCH SETTING:
This is an alternative method to programming your device without using the code list. The
remote control will scroll through the list of codes to identify the correct code for your
device.
2. Aim the remote control at the device and press and hold down the CODE SEARCH button
for at least 3 seconds until the red LED lights up solid red.
3. Press the device button for the item you wish to program, e.g. TV, DVD, VCR, etc. and the
4. Press ON/OFF button on remote slowly and repeatedly until the device you are trying to
program shuts off. (Note LED will blink once each time you press ON/OFF button)
5. Once this occurs, press ENTER button to store the code and the LED light will turn off
Mar 27, 2011 | Innovage Jumbo Remote Control
My playstation 3 stays in the "standby mode" and does not turn on
its a power failure inside the ps3!!! You have to call sony to replace the system it will cost u 150.00 dollars unless ur still under warrenty goodluck because i had to get 3 systems from sony before i got one that worked just right
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
Solid red light, flashes green when i turn it on then it dies.
Pretty much the only thing worth trying is starting the PS3 without the hard drive.
If it doesn't work it's more than likely a GPU problem that only Sony can fix.
Either way check out my guide here for tips and details.
http://rescuetechla.blogspot.com/
Please feel free to email me any other questions and please don't forget to rate!
Thanks!
RescueTechLA
Feb 28, 2009 | Sony Playstation 3 (PS3) Console
3 solid red lights no lights help
Hi i've got the same problem. There is nothing YOU can do about it. You need to send it back to the shop and say whats the problem. They may send it back for you or you have to do it yourself.
Dec 14, 2008 | Microsoft Xbox 360 Console
Toner light stay on
1. Power Unit off
2. Open front cover
3. Press and hold GO and turn power on
4. When all 3 lights lit release and press GO twice
5. All lights turn solid
6. With all solid, press GO 5 times
7. Ready light GOes red
8. Close door and you're all set
Jul 29, 2008 | Brother HL-2040 Laser Printer
Beep 3 times turns green yellow then blinks red then turns to a solid red wont turn on wont give me game
3 Solid Red lights usually means that a cable is unplugged. Check all cables (unplug and plug back in)...you may need to replace power cable if issue is still ocurring. If it is 3 Flashing red lights, this is known as the Red Rings of Death, i.e. your XBOX is dead and needs to be completely replaced.
http://www.xbox360forum.com/forum/xbox-360-console/64180-what-do-three-solid-red-lights-mean.html
Jun 16, 2008 | Video Game Consoles & Games
All lights blinking
Try:
1. Power Unit off
2. Open front cover
May 05, 2008 | Brother HL-2040 Laser Printer
Sony Playstation 3 (PS3) Console Logo
229 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
