LGRZ17LZ40 television low audio problem. despite increasing volume up to maximum the audio is really quiet I have checked the speakers and they are ok, any ideas welcome, thanks Arthur
  • 70 Answers
Check the voltage supply rails to the audio output, usually between 14 and 30 volts. if low replace respective rail capacitor for being open circuit. also check the fusible resistor for high value.
ive also had later model lg sets with a crook audio detector ic crook, the one marked micronas.
Posted on Jul 09, 2008
Samsung le32r7 volume wont turn up anymore
Are you using a box of some sort for signal with this set?
Dec 18, 2012 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Sony BDVE870 Low Volume
use equalizer to increase volume
May 19, 2012 | Sony Audio Players & Recorders
Low volume
1)Make sure volume is at maximum level. check down right hand side of your desktop. 2)Make sure speakers(headphones) volume is at maximum. 3) If problem continues check your speaker( connect it to other pc), and headphone as well. 4) If problem continues try reinstalling audio driver.
Mar 28, 2011 | Computers & Internet
No audio,tried menu items and selections,nothing.The sound just went out,what do you think it might be?
There is no sound or low volume coming from the television speakers.
Solution Follow this procedure to troubleshoot when there is no sound or low volume coming from the television.
NOTE: Because each of these steps represents a possible solution to this issue, check the television status after completing each step.
Increase the volume of the television. Ensure the television audio has not been muted. Ensure no headphones are not connected to the television. If using a set-top box with a volume control, increase the volume of the set-top box.
NOTE: If the set-top box is connected using an Audio/Video (A/V) connection, ensure that the A/V cables are connected securely to the appropriate video input on the television.
Verify that the MTS settings of the television are set to MAIN or STEREO .
NOTE: If the source device is not set to stereo or is not capable of transmitting a stereo signal, sound may come from one speaker on the TV only, and the volume will sound low. In this case, adjust or replace the source device.
If the TV has a Simulated effect in the audio menu, turn it off . Ensure the televisions speakers are not set as the center speaker.
NOTE: Some televisions allow the televisions speakers to act as the center channel speaker when using a multi-channel receiver.
Verify that the speakers are set to ON in the television menu.
IMPORTANT: If the television has audio output jacks and they are connected to a stereo system, then the speakers on the television may be turned off. Some televisions require the internal speakers or the center speaker setting to be off before audio can be sent out to a stereo receiver via the audio out jacks.
Ensure all audio and video cable connections are properly connected to the television.
Test the television using another source like a VCR, DVD player or Blu-ray Disc™ (BD) player.
Reset the television to the original factory settings. To reset your TV to factory settings, turn the TV ON. Then, while pressing the UP ARROW button on the Remote Control, press the POWER button on the TV. The TV will turn itself OFF then back ON.
NOTE: If your remote control does not have a RESET button or the procedure did not reset the TV to the factory default settings, perform a power reset.
If the issue is still unresolved after completing all the troubleshooting steps suggested, service may be required.
Jan 30, 2011 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Are e71 speakers really low in volume despite being in max rngtne
This can be due to the phone speaker. It might be faulty or in need for replacement. You can try to visit a phone service center to have it check or if you are capable then you can check it yourself.
Please leave comments.
Thank you for reaching us.
Apr 10, 2010 | Nokia E71 Smartphone
How to increase speaker volume on Dell Vostro 2510? Everything is set to maximum, but volume is still low !
it might having a problem with your speakers,change it...or change audio cable pin or check it by moving it or by inserting it correctly in audio panel
Dec 12, 2009 | Dell Sound Blaster Card
Amp sends power to sub at low volume. but when volume is increased speaker loses bass and distorts REALLY BAD. Still has power but clear bass disperses. just sounds terrible at even lower volumes
are the sub speakers ok? if ok then u have a problem with the Amp and the output IC's will have to be checked there cud be a problem with the input card in the amp.
Aug 26, 2009 | Jl Audio 500/5 Car Audio Amplifier
Possible blown speakers
I have experience with that model of speakers. When they give up the ghost, the volume is VERY low. But just to be on the safe side, check the volume properties to make sure nothing is set too low. Start>Control Panel>Sounds and Audio Devices. Check the slider bars here, check in the Advanced area as well to make sure nothing is low and check the Speaker Volume as well. If all the bars are set to their maximum, it's time for some new speakers.
Thanks for using If you like my answer, please help me out and rate me accordingly.
Jan 11, 2009 | Dell A215 Computer Speakers
I have a Denon AVC 3030. In pro logic mode it makes a rumbling through my right and left speakers. During quiet parts of movies it is quite annoying. I know it's old but I really like it.
If what you mean is a low humming sound when the volume is turned down to minimum level, this is usually from power supply filtering problems. Most of the time this is from the electrolytic filter capacitors going out of spec with age and use, and or voltage retulation problems.
If the sound is quiet with the volume turned down, and the hum or buzz increases with the increase of the volume control, this is usualy due to a ground loop problem between the associated equipment connected to the amplifier, or a bad interconnect cable.
Jerry G.
Apr 26, 2008 | Audio Players & Recorders
Amilo Pro v2055 Sound very quiet
Go to control panel then sound and audio devices then speaker volume and see what level it is set on.
Nov 01, 2007 | Fujitsu AMILO Pro V1000 Notebook
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
