Question about Fuji Cameras
Protected card, no functions - Fuji Cameras
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Fuji Master
  • 102,366 Answers
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Posted on Jan 03, 2011
My memory card is not working in my Nikon S4100 camera. It keeps giving me the message "this card cannot be read". I What can I do about this?
1) Make sure that the write protect slider on the edge of the SD card is not in the protected position.
2) Make sure that the SD card has been formatted in the camera; not on your computer. The format function is in your camera's menu functions.
3) Try a different SD card that has been formatted in your camera. That will tell you if you have a bad card.
Jan 09, 2016 | Nikon Cameras
Write protected card
Look carefully at the SD card. On one side you will find a "lock" switch. The card in question has this switch in the lock position. You can not delete an existing video because the delete function actually requires the ability to update the card which is a writing function. Flip the switch and your problem should be resolved.
Dan
Apr 08, 2008 | Video Cameras
The disk is write protected
You only can use Memory Stick Duo. There is a write protection switch on the memory card, you only can switch with a sharp point. Ball point or something like that. Have a close look on the card.
"Memory Stick Duo", "MagicGate Memory Stick Duo" and "Memory Stick PRO Duo" are equipped with MagicGate functions.
MagicGate is copyright protection technology that uses encryption technology. Data recording/playback that requires MagicGate
functions cannot be performed with this camera.
So if you have a MagicGate one it does not work and could give this error.
Nov 06, 2013 | Sony Cyber-shot DSC-W50 Digital Camera
Memory card is write protected
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 17, 2012 | Nikon COOLPIX S6300 16MP 10x Opt Zoom 2.7...
How can we remove write protection in sony dscw320 digital camera
I'm going to assume you mean the "protect" function in the camera, rather than the whole-card "lock" function. I don't think there's a single manufacturer that makes this clear. But let me tell you their little secret... whatever you did to protect it - do it again. It's a toggle function! They wouldn't want to put "protect/unprotect" in the menu system instead of just "protect", it might look 'cluttered'. Of course, it might be more useful too. I just dug out my own Sony camera, and it's easy enough to find; be in playback mode on the picture in question, press 'menu' and scroll to the 'protect' function.
Feb 23, 2011 | Sony DSCW320 Digital Camera
When i insert my memory card into the camera it states 'card write protected' and the camera is not functional..it cannot be formatted also.. pls guide me in order to remove the protection
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Nov 02, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Remove write protection from micro-sd card
  1. Remove the Sandisk SD card from your portable electronic device. Ensure that the SD card can be safely ejected before removing.
  2. Locate the write protect lock. The write protect lock should be on the side opposite the cut-off corner of the SD Card.
  3. Disengage the write protect lock. To do this, gently slide the small switch upward, toward the top of the SD Card. The card should now have write protection disabled.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Mar 03, 2010 | SanDisk 2GB microSD Memory Card
Coolpix p1500 says ''memory card is write protected''
Is there a slide switch on the side of the card? Move it to "unlocked" position.
Aug 23, 2009 | Cameras
Card errow can i format the card or buy a new one
Be careful!
• This operation will destroy all data in the card. If you have already used the card, be sure that you are not about to destroy important image data.
• Some cards come equipped with special built-in functions. Formatting such cards may in some cases cause them to loose their functionality. Before formatting a specialty card, please read the documentation included with the card.
• You cannot format a card that is protected by a write-protect seal.You must remove the seal before formatting. Please discard used seals; write-protect seals should not be reused.
Go to Menu and select the trashcan. Select the symbol that looks like a hammer. Select Yes or No.
CAUTION
• You cannot cancel formatting once the camera has begun executing the format. After selecting YES and pressing the OK button, you must allow formatting to proceed.
• Do not open the card compartment cover, remove the batteries, or disconnect the AC adapter while formatting is in progress (while the lamp is blinking), as doing so may damage the card.
May 09, 2009 | Olympus Camedia C-211 Zoom Digital Camera
Cameras Logo
18 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
