Question about Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection
Will not heat after setting both knobs to Clean
  • Jenn-Air Master
  • 3,053 Answers
Hello, Fuzzy, The switch that triggers the cleaning is out, need replacement, Read on.
I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the recent past and farther back, It appeared that no one answered some of them, So, I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your oven, from repair to trouble shooting it. Even pictures and video's. Just scroll around and you will see tons of information to almost any question you might have on your Oven. If you go to this link and click around, I am sure you will find out so much about your oven, you will know more than the company that made it. The good thing about this link is, then you can make the decision of DIY or hiring a pro. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://home.howstuffworks.com/how-to-repair-an-oven.htm
Thanks,Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 28, 2011
GAS OVEN WILL NOT GET HOT
see this instructions and fix it. God bless you
  1. eHow
  2. Home & Garden
  3. Home Appliances
  4. Other Home Appliances
  5. How to Troubleshoot a Gas Range Oven That Won't Heat
By Kefa Olang, eHow Contributor
Although gas range oven may prove useful for cooking and baking, they may fail to ignite if they aren't properly maintained and set up. Lighting a gas range often involves simply turning a knob; however, blockages from food particles and debris caught in the burners, improper burner cap installation and gas supply are common problems that interfere with your gas range oven's performance. A few troubleshooting guidelines may solve these problems safely.
Other People Are Reading
Things You'll Need
  • Toothpick
  • Paperclip
Instructions
    • 1
      Check you have gas in your tank if your gas range oven won't heat. Contact your gas supplier if you've run out of gas.
    • 2
      Clean the burners if you have gas but your burners still won't ignite. To clean the burners, lift the burner caps 9b4f010f-be4f-4db6-8a88-4c3fd17e3339.gif
    • 3
      Inspect the small vertical holes on the side of your burners for dirt, food and debris. The gas won't ignite if they are clogged. Scrape dirt, debris and food from the vertical holes using a pointy object such as a toothpick or paperclip.
    • 4
      Reinstall the burner caps properly. If they are tilted or wobbly, the gas may not ignite. Install the caps on the right burners. Some burners are smaller than others, so match the caps to the appropriate burners.
    • 5
      Move the burner knob to the "Lite" position and wait for the gas to ignite. If it ignites, rotate the knob to your desired setting. If it doesn't ignite, contact a qualified appliance technician.
Jul 18, 2013 | Ovens
I hit the bake button on my oven and after 10 secs it says preheat and thats all that happens nothing else no heat at all
Your oven will continue to indicate that it is preheat mode until the thermostat senses the proper set temperature. If you are getting no heat then you will need to address that issue. This could be many things but the most notorious would be the heating element. Could be the control panel as well. Some ovens have a knob for preheat, bake and clean with a separate knob to adjust the temperature. Make sure both are set properly.
Regards, Tony
Apr 07, 2011 | Kenmore Ovens
I meant to set the pre-heat on my 26 year old Kenmore oven but turned the dial to the clean by mistake. Now the door is locked. What can I do to release the lock?
Set selector knob it to clean, push in and turn the Stop time ahead. Wait for the motor to complete latching the door. turn selector to "Off" and wait for motor to unlatch door. If it's stuck you can either manually unlatch it from above or rear or use a coathanger wire made into a hook to catch and release the door "hook"
Sep 21, 2010 | Ovens
How do I clean my oven? Model #RF354BXWD?
At the bottom of this is a link to the manual, it shows details starting on page 22 of how to clean.
Remove the racks and pans from the oven.
1. Move the Lock Lever to the right-the Clean position.
When the oven temperature goes above normal baking/roasting temperatures, the door cannot be opened and the Lock Lever must not be moved.
2. Set the Oven Selector and Oven Temperature Control Knob to
CLEAN.
3. Make sure the clock and Start and Stop Times all have the correct time of day.
4. Push in and turn the Stop Time Knob clockwise two or three
hours. The OVEN HEATING Indicator Light will come on. l Use two hours for light soil. l Use three hours or more for moderate to heavy soil.
NOTE: Make sure the Start Time Knob is not pushed in.
5. After the Self-Cleaning cycle is completed and the oven has
cooled enough, the Lock Lever can be moved back to the left.
DO NOT FORCE the Lock Lever. Wait until it moves easily. Turn the Oven Selector and Oven Temperature Control Knob to OFF.
6. After the oven is cool, wipe off any residue or ash with a damp cloth.
If needed, touch up spots with a soapy steel-wool pad.
Manual
Jul 30, 2010 | Whirlpool Ovens
How to self clean a 1989 model self clean GE oven How do I set?
I found that you cannot turn the CLEAN knobs both off before you release the latch on the door. You cannot unlatch the door
if the Oven Set knob is turned from Clean to Off.....it must still be on Clean to unlatch....simple, huh? Well, it was confusing
at the time!
Dec 01, 2009 | GE Ovens
Self clean doesn't start
i would pop the top up and see if there is a bad switch on the handle that locks the oven.
Feb 13, 2009 | Whirlpool RBD306PD Electric Double Oven
Jenn Aire lock for self clean in locked position
The LOCK INDICATOR light must be OFF. This can take up to one hour!!!
Do NOT force the door.
Leave the SELECTION and TEMPERATURE knob alone. The Temperature knob MUST be set to CLEAN
Indicator Light OFF, knobs set to CLEAN - OPEN the slide lever.
Lever open, set the knobs to OFF and away you go
Oct 26, 2008 | Jenn-Air Ovens
Self cleaning frigidare oven FEF368CCTD
If this stove has knobs, Make sure the clock keeps time. If it doesn't you will have to manually turn this off. (DON"T FORGET OR LEAVE WHILE CLEANING) Make sure there are no large puddles of oil or grease on the bottom of the oven.If the oven is really dirty it may stink a little. Nothing but the racks can be in the oven.Press the lock button and slide the lock lever to lock the door. Set the stop time for 3 hours and turn the knob by the clock to auto. Turn the oven knob to clean. (MAY have to push to turn all the way to clean) It should start heating up. Let it finish and then cool down. It will not let you unlock or open the door until it is completely cool. Wipe out any remaining ash with a wet rag. ALL CLEAN!
Jun 28, 2008 | Ovens
Tappan Electric Oven
I have a Tappan double oven range. An older model #316065301
How do I operate the cleaning cycle? I set the start and stop times, Locked the door and switched to clean. The clean light comes on but it doesn't heat up much at all. Never locks. I have misplaced my instructions manual.
Any help would be appreciated.
Barbara
blueznmooz@aol.com
Nov 19, 2007 | Tappan 30IN ELEC IGNa Oven
Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection Logo
35 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
