Question about Magic Chef CMV1000B Microwave Oven
We were defrosting meat yesterday and the microwave powered off & has yet to come back on. Is there a fuse somewhere on it or maybe a reset button? We tried unplugging it & resetting the breaker...neither worked.
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
Their are fuses and other issues, that can cause your issue's
Microwaves must be serviced by technicians due to the inherent dangers involved in repairing these appliances. Internal capacitors can retain a lethal electrical charge even though the unit is completely unplugged. A microwave radiation leakage test must be performed on the unit following any internal component repair.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 03, 2011
How do I defrost a package of frozen hamburger meat (2.25 lbs)on the Sharp Carousel R405JFK microwave ? The instructions on the front of the microwave are sort of confusing...
try defrost = 2.3 enter/start I use my sharp (not a R405) all the time to defrost meat and that's how mine works , I know its a bit confusing as defrost goes by weight not time like the cook mode does
Sep 29, 2016 | Sharp Microwave Ovens
How do i defrost in a prestige 3de microwave
If you don't know how to program defrost or if the unit does not have variable power settings, you can put a cup of water in next to the package you want to defrost and run the microwave for 30 seconds at a time. I don't advise defrosting meat in a microwave but I guess sometimes you have to.
Jan 30, 2015 | In Microwave Ovens
How long can I defrost stake for in the microwave
My personal opinion is to avoid putting any meat in a microwave if at all possible. However, if you must, put a cup {at least 8 oz} of cold water in with the frozen package of meat (if you can set it on top without spilling it, that is the best way). Run the microwave on high for 1 minute per pound. Check after every minute. Eventually, the edges of the meat will start to cook. This is unavoidable.
Good luck....
Oct 10, 2013 | Microwave Ovens
Kenmore microwave 721.63653300 buttons not working properly
follow this steps and fix it. God bless you
  1. Controller is confusedA power surge or random non-reproducible action of the universe may have resulted in the controller's program ending up in an infinite loop. Pull the plug for a minute or two to reset it.
  2. Defective Interlock switchesThis can result in the controller thinking the door is open and ignoring you.
  3. CleaningCleaning solutions (spray cleaner) may have gotten inside and shorted out the touchpad or controller. If this happens remove the touchpad, let it air dry for a few days, and then attach it back on the microwave.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#4#ixzz2ZYTO5cC9
Jul 19, 2013 | Kenmore Microwave Ovens
My Panasonic NN-GD560M microwave when switched on cause the fuse at the circuit box to trip. It will reset and appear to be OK but as soon as I attempt to use the microwave it trips again
The rest in the fuse panel can wear out especially if its been kicked off several times or is quite old so I'd suggest checking it and maybe it's on a line with too many things attached to the circuit causing too much amp draw when microwave is being used.If you know the house amp input to the fuse box and add up the fuses or reset amperage you maybe able to up the amperage by 5amp tops but try a brand new same amperage reset first off.
Dec 18, 2011 | Microwave Ovens
I have a Goldstar Multiwave and have lost the manual. Can you defrost by time rather than weight such an a frozen breakfast sandwich?
You can defrost items by time but not with the Q-Defrost or Auto-Defrost functions. (I've found it best to defrost ground beef with timed intervals at power 1. Auto Defrost by weight usually starts cooking the meat. You will need to try it a few times to see how long and what power to use.)
Manage My Life has the manual here: http://www.managemylife.com/mmh/owner_manuals/52491/GOLDSTAR-Countertop-Microwave-L1005548?brand_name_search=MA1011W . Sears Parts Direct may have a copy that you can order. (I didn't see it listed but didn't check the entire set of parts lists.)
I hope this helps.
Jul 10, 2011 | Goldstar MA-1011 Microwave Oven
On our new microwave there is 2 buttons for defrost. what is the difference? it does not mention defrost in the booklet we got with the unit.the mdl.# is GMH5205XVB
Using the Auto Defrost feature on my microwave oven
How do I use the Auto Defrost feature on my microwave oven?
To use the Auto Defrost feature on your microwave oven, please do the following:
  1. Unwrap food, place on the turntable, and close the door.
  2. Touch Defrost.
  3. Select food by entering 1 for Meat, 2 for Poultry or 3 for Fish, or touch Defrost repeatedly to scroll through the food selections.
  4. Enter the weight in pounds:
    Meats and Poultry can be set from 0.2 to 6.6 lb (90 g to 3 kg).
    Fish can be set from 0.2 to 4.4 lb (90 g to 2 kg).
    Doneness may be adjusted at this time by touching Cook Time.
  5. Touch Start. The display will count down the defrost time. When the cycle ends, "End" will appear in the display, and the end-of-cycle tones will sound, followed by reminder tones.
  6. Touch Cancel Off or open the door to clear the display and/or stop reminder tones.
The Defrost system has 3 categories: Meat, Poultry and Fish. It should not be used for food left outside the freezer more than 20 minutes and frozen ready-made food. Use the following chart as a guide.
Here is your owners manual:
http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/GMH5205XVQ_Use%20and%20Care_EN.pdf
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 05, 2011 | Whirlpool Microwave Ovens
KitchenAid Superba combination built-in oven (upper: microwave-convection; lower: conventional oven). Model KEMS376 TALO. Installed 12/89. The "blower" and main "power on" light (NOT...
It sounds like a stuck relay or other controller problem.
I don't have the service data on this one, but there should be a schematic or tech sheet / mini-manual either on the back side, behind the controls, or somewhere else inside.
If you or someone you know can locate them and scan and e-mail or copy & fax them to me, I can probably give you further guidance.
Please feel free to contact me directly.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jul 21, 2008 | Microwave Ovens
Magic Chef CMV1000B Microwave Oven Logo
118 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
charles
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
