Question about Coleman 5045A751 Heater
Where can i find a replacement screen for the burner
  • 613 Answers
Most Walmarts have a Coleman Section as well as ACE hardware.
Posted on Jan 03, 2011
How to replace thermocouple in 42v50-50f
Copy following link:
http://waterheatertimer.org/How-to-replace-thermocouple.html
Rheem 42V50-50 is ordinary atmospheric-vent gas water heater with mechanical (non-electronic) gas control valve, which says that unit has ordinary thermocouple, and not thermopile.
Buy generic thermocouple from local hardware.
To replace the thermocouple you need to remove entire burner assembly from water heater, and have replacement Burner access door gasket on hand. 1-800-268-6966
Combustion door held in place with tamper-proof screws
Since the water heater problem may be more complicated than just the thermocouple, and water heater flame arresor screen may need to be cleaned, and burner parts cleaned, door gasket replaced, and gas pressure checked, and piezo electrode checked, it might be best to have qualified service technician do the work for $300.
Jul 28, 2012 | Rheem Water Heaters
I have an old Tec Searmaster II 1 burner. The burner (screen) got a long crack line and the burner shield got some holes. When I open the grill, I heard a pop noise and some fires are up. Should I change...
Some parts are still available for your discontinued model Tec Grill. The burner less the screen varies in price from $329.00 to $399.00. The Heat Plates start at $153.99. For more information go to
http://www.appliancefactoryparts.com/gasgrillparts/brands/tec/tec-burners.html
Hope this helps you.
Jul 03, 2011 | Tec RadiantWave Grill
I think the fuel pump on my beckett burner is clogged is there a way to clean it. Ive replaced the filters and get fuel to the burner but get no fuel up to the line feeding the nozzle
As you face the burner, mounted in the unit, the oil line feed in on the left side. There is a cap, held on by 4 7/16" bolts. Inder the cap, there is a screen. You would be best to get a screen kit, available from the same place you get your nozzle, as it will come with a new gasket.
Shut off the oil. Remove the four bolts, pull the old screen, clean the housing (I use rags and WD40) and re-asssemble. If is is really bad, you should remove the nozzle assembley and flush the oil line to the nozzle, as well.
THe oil filter, screen and nozzle should be replaced at least once a year.
Jul 06, 2010 | Heating & Cooling
I have a mid 70's Dometic RM 211 refrigerator in my camper. The screen on the propane burner has been damaged and needs to be replaced. Parts no longer exist from Dometic. What size wire mesh do you...
Hi Brian,
You don't want to use a screen that is made to fit. The original part was designed for a specific flame. That being said, colaws rv salvage may have a replacement burner in stock, and you can also try calling up a company that rebuilds cooling units for rv fridges.
Jun 03, 2010 | Dometic RM2193 Compact Refrigerator With...
How do I get to the burner?
THE BURNER IS INSIDE THE DRYER WHICH THE TOP NEEDS TO BE RAISED UP FROUNT REMOVED IF YOU HAVE VENT ON TOP FOR LENT SCREEN 99 % CHANCE ITS THE THERMAL FUSE WHICH IS INN THE BACK DRYER BEHIND THE PANEL WITH 8 SCREWS IT COMES OFF UNPLUG DRYER THERE A LITTLE WHITE FUSE EATHER OVERL ARE OBLONG CK IT CONTANUITY REPLACE IT SOUL FIX PROBLEM
May 30, 2010 | Whirlpool LGB6300 Gas Dryer
My DVD burner doesn't respond at all
Hi! I believe that the dvd burner is faulty. You will need to replace this for it may be worn for long time use. Hope this helps and have a good one!
May 29, 2010 | LG GSA-H55N DVD-RAM Burner
The display screen does not sit any viewing angle.
More than likely both hinges are broken (the screen pivots to the hinges). Nothing to do but to replace both L and R hinges.
Dec 24, 2009 | Toshiba (SD-R2412) for Satellite A10, A15,...
The dual output burner does not work. I measured the resistance across the terminals for each element and it appears that there is a break on the common side of the elements. Are there replacement elements...
Those "Dual Heat Range" burners are available. Go to Sears.com, click on "Parts Direct", enter model number, press enter, when next screen pops up look on diagram for your burner, then scroll down to find part number & price. Then search the internet for cheapest price and delivery. Those burners average 150.00 - 300.00.
Sep 23, 2009 | Maytag Admiral LER3330AAW / LER3330AAZ /...
Heat wont stay on
remove front to get to burner remove screws under lint screen on top press clips each corner of top remove tne screws each corner inside top front panel.if lint screen in door frame press clips each corner bottom panel ..replace the 2 black coils on burner
Dec 01, 2008 | Whirlpool Dryers
Coleman 5045A751 Heater Logo
140 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
