Question about Hotpoint First Edition FEW12 Front Load Washer
I have a coin or something stuck between the drum and the casing, how do i remove the casing to remove the item
  • Hotpoint Master
  • 3,463 Answers
I would advise you to leave well alone, as the coin should find it's way into the pump filter without causing any problem.
Posted on Jan 03, 2011
I have a Kenmore 110 44932 200 washing machine. When the drum spins it sounds like there is something caught between the walls. At a high speed it make a loud noise. How do you get between the walls
SOUNDS LIKE UN HAVE SOME ITEM OR COIN ETC STUCK BETWEEN THE TUB AND WALL. YOU HAVE TO REMOVE THE TOP PANELS THEN REMOVE RETAINER CLIPS AND REMOVE THE BODY TO ACCESS INSIDE DRUM
Dec 12, 2016 | Kenmore Washing Machines
Something stuck in drum, so it won't spin.
you will have to remove the wash drum and get what ever is jammed between the 2 sections out
probably coins , buttons or items like bra wire.
Jun 09, 2015 | Zanussi Washing Machines
Coins
It might well be a coin! Coins and other items that fall from clothes pockets into the drum stay in the drum. They are too large to pass through the small drainage holes in the drum. But my granddaughter found a way! She opened the washing powder dispenser at the top of the machine and dropped three coins (that we know about) into the drawer and closed it. The water fill cycle then somehow swept the coins down into the drum. To get them out I had to dismantle the machine and remove the pump outlet assembly and poke a stiff wire into the drum and drag the coins out. The machine is a completely different make to your but I would assume a similar method would work. good luck
Dec 31, 2013 | General Electric GTWS8655DMC GER 5.0 DOE...
Loud noise during spin/rinse cycle
Probably a coin or something in between the 2 drums being thrown around. You will have to remove it somehow if it is as it will damage the drums. First check for any loose parts in the case that may just be knocking around and then try and see if you can see anything in between the drums by useing a light and looking through the holes in the inner drum. If you see anything that should not be there it will need removing. May be possible to get it out by removing the lower drain hose from the outer drum, the door seal if a front loader or the heating element. Start with the easiest to remove first.
Dec 31, 2012 | Maytag Washing Machines
Indesit WIXL 143 washing machine noise
there maybe a coin or something stuck between the two drums, when the machine spins fast it lifts the item up, unplug the appliance and remove the botton drum hose to see if you can get it out.
Apr 05, 2010 | Washing Machines
My clothes are sopping wet when the wash has finished and there is water at the bottom of the drum. I can sort it by taking clothes out, bailing out the water and then re-spinning the clothes twice to get...
Sounds like a blocked outlet pipe. It may be possible that a small item of clothing i.e. sock or baby item may be stuck between the drums and occasionally moves over the outlet from the drum causing the blockage, hence only happens once in a blue moon. To see if you can see if there is something between the drums use a flashlight to help you look through the holes in the inner drum to see if there's a stray sock or something that can be moving around between the drums and covering the outlet. If there is then you will have to remove the outlet pipe from the bottom of the drum to try and remove the item that is causing the blockage, check all the way around the drum as it may be stuck to the inner drum at the time. If no item is found between drums then the blockage may be in the outlet pipes (both sides of the pump) or in the pump. Check these also as it may even be a small button or coin creating a blockage if it is moving around.
Feb 25, 2010 | Hotpoint Aquarius WD63 Front Load...
My WD440 has trown its drive belt and something
hi
it sounds like there is a sock or something simular stuck between the drum and tank,the paddle is removable which may help you hook out the item,if you grab the drum paddle from the rear and pull it towards you it will then lift up,once you have removed the offending item,you just line up the slots on the drum with the pegs on the paddle and push towards the rear of the machine and you will here a click,this means the paddle is secure.
Aug 02, 2009 | Hotpoint Aquarius WD63 Front Load...
LG WM2077CW small item trapped behind drum
you would need to remove bottom exit rubber pipe from drum and use a flash light to free coin or screw,hope this helps
May 27, 2009 | LG WM2077CW Laundry XL Front Load...
Zanussi jetstream 1250 coin between inner & outer drum
not that easy.
remove top. remove water hoses.remove rear half of cabinet. to do this, undo securing screws along top flange, remove two screws at bottom sides hidden behind plastic plugs and two screws at bottom back. rear half of cabinet will then pull off.
remove heater - this is held with a 10mm nut in the centre which loosen and prise heater out.
you canb then see into the gap between tub and drum ane remove coin or whatever
Nov 05, 2008 | Dryers
SOMETHING stuck inside the dryer body - something like a coin... let me knwo
ok here is the best way to describe it you will need to get around the back there are two torks screws remove them and slide the top panel back to you ..OH I FORGOT unplug the machine first !!!....Ok now with the top off you will see the drum.. slowly hand rotate it until you see some screws that are lined up with the baffles inside the drum You will need to remove just a few screws on one side (the baffle that has the coins) dont take them all out or the baffle will fall inside the drum and it will be a pain to get back on9u will need 2 people) and that should do it you will need to rotate the drum around until the correct baffle ...ie ..the one with the coins in on top at the 12 o'clock position.. let me know if this works our for you
Feb 16, 2008 | Kenmore Elite HE4 Electric Dryer
Hotpoint First Edition FEW12 Front Load Washer Logo
182 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
