Question about KitchenAid KEBC107 Electric Single Oven
AFTER RUNNING THE SELF CLEAN OPTION THE OVEN WILL NOT HEAT UP. DID IT BURN OUT THE THERMAL FUSE?
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
yes that could have happen, or even the heating element could have become defective.
this does not happen much.
if you need any more question, you need to provide model# and serial#.. on the door sticker
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 03, 2011
Oven won't heat
You may have a blown thermal fuse in series with the heating elements. If the oven exceeded the maximum allowable temperature during self-clean, the fuse will open. See this discussion:
Oven Failure After Self Clean and F1 Errors
Aug 22, 2014 | KitchenAid Ovens
I turned off self clean now i put it on to bake bake light and also the warming oven light comes on no heat in oven
It is possible that it tripped a thermal fuse. If it is a Whirlpool design they are prone to having this happen after a self clean cycle.
Apr 20, 2014 | Ovens
After self-cleaning, oven will not heat. I waited at least an hour before I tried to pre-heat the oven and it will not heat.
There is a thermal fuse on the back of the oven that has blown, it is in series with the broil and bake elements so when it goes out neither element will work. You will have to pull the oven and take the back off. the fuse will be behind the rear panel. It usually has to red wires going to it. Once the fuse is replaced the oven should work fine. It is fairly common for this fuse to blow during the clean cycle due to a lack of air flow around the oven.
Aug 28, 2011 | Whirlpool RBS245PDS Electric Single Oven
I have a Whirlpool Gold self-cleaning oven w/convection. Following a self-cleaning cycle the oven will not heat up. Is there a certain amount of down time that has to go by before it will function again...
The self-clean cycle has blown a fuse in the rear of the oven. That thermal fuse must be replaced. Go to www.appliancepartspros.com and enter your model number. Find the thermal fuse on the diagram and then you can orfer the fuse from them.
Aug 27, 2011 | Whirlpool Ovens
OVEN WILL NOT HEAT UP AFTER WE USED THE SELF CLEANING OPTION
Most ovens have a thermal fuse on the back. This is a safety device which kills the power to the bake/broil elements if the oven overheats. Self-clean has been known to trip these devices in which case it needs to be replaced. Not a user-serviceable part, but not difficult to replace either.
Jun 26, 2010 | Whirlpool Ovens
I have a Kitchenaid oven model KEBC107KSSO. After using the auto clean, broiler and oven does not heat. Control panel works fine.
The thermal fuse on the back of the oven is out. Usually happens if the oven is installed incorrectly or the blower is too small to cool the back of the oven down while in self-clean mode.
I'd call KitchenAid (whirlpool) and ask if it needs the blower kit to fix it. Have your model&serial numbers handy.
In case it does not need the blower kit, the thermal fuse part number is 9759242, and it can be purchased here (use coupon "New10" for 10% off). Read my other post for the instruction how to get to the thermostat.
Oct 14, 2009 | Ovens
I used the self clean option and now my oven will
There is a thermal fuse inside the rear panel of the oven that frequently blows when using self clean option. This is where I would start looking.
Sep 30, 2009 | KitchenAid KEBC101 Electric Single Oven
Whirlpool 27" wall oven. no heat after self clean
Self cleaning features are not recommended by most appliance technicians. The ovens are not constructed satisfactorily to expel the 1000 degree heat, Therefore the thermal fuses blow as well as other parts failures.
Remove the oven. Remove the rear panel. Replace the thermal fuse in the back of the oven. Use Easy Off next time.
May 12, 2009 | Whirlpool RBS245PDS Electric Single Oven
Oven won't heat
Unplug the power cord for thirty minutes, this should reset the oven.
If this still does not work do the following:
Press clean and then cancel. This will reset the appliance.
If the error does not clear , then during the self cleaning cycle, the high temperature has probably damaged the temperature sensor probe, and it must be replaced.
Dec 03, 2008 | Whirlpool RBD305PD Electric Double Oven
KitchenAid KEBC107 Electric Single Oven Logo
112 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
