Question about Wave Industries OLY-OL3000 Globe Phone
Will not power up, need replacement wall plug
I believe that the wall plug went bad because I tried the wall plug from another item that we have at home and the globe id is working. Where can I get a replacement wall plug?
    Problem Solver:
  • 6 Answers
Radio Shack can hook you up. Take your old transformer to them and they will help you out.
Posted on Aug 11, 2008
Tip
Laptop will not turn on, laptop will not power on, laptop will not start
Make sure your laptop battery has a charge. Plug it into the wall outlet for 30+ minutes and then try powering it on. When you plug it into a power source, usually the laptop will have a light indicating that it is charging. Look for a light. If the light does not light up, try a different wall outlet. <br />If it still does not charge, you may have a bad power cord, a bad laptop battery, the wall outlet may be bad or the laptop itself is damaged and will need to be serviced by a technician or replaced.<br /><br />Through the process of elimination you can narrow down possible causes.<br />-Try a different wall outlet(or by testing another device make sure the wall outlet is good)<br />-Try a different power cable.<br />-Try a different laptop battery.<br /><br />If none of the above help then you may need to have your laptop repaired(internal damage) or replaced.<br /><br />If your laptop is under warranty you should contact your laptop manufacturer or warranty policy holder to have it repaired or even replaced. <br /><br />If it is not under warranty you should look for local computer repair shops or technicians. <br /><br />-G33k<br />
on May 22, 2011 | Computers & Internet
No power. I went to the computer store and they used their own plug to override the battery. They also tried main battery replacement. Both items did not work to power up my computer. Before it went...
Step 1:
With unit off, and unplugged, remove battery from bay.
Step 2:
Plug unit into AC adapter and turn on.
Step 3:
If unit turns on and working well...need to replace battery with new one.
Step 4:
If unit turns on, but still giving you issues -- take in for repairs.
Jan 15, 2013 | Acer Aspire 5253
My power cord seems to not be working with this computer. I have tried all the outlets in my house and nothing is charging my laptot.
I'd call HP and request a new power adapter. I've had a few of them go bad before and it's just a short in the cord. Your plug might be loose also...but a good place to start is by calling HP and getting a new cord.
Mar 12, 2011 | HEWLETT-PACKARD Hewlett Packard HP Black...
Tower switch dose not turn on.i took out power wire from the wall plug when i went to trip 5 weeks ago
Make sure the power cord is securly plugged into the Power Supply Unit in the back of the PC and also in the wall outlet. Look for a switch by the cord plug on the pc that will have a straight line and a circle on it. Make sure it's switched to the ON position (straight line). Try and turn on your pc.
If this does not work still, try a different AC outlet on another wall or in another room. Also try a different power cord for the PC. If none of these work and your machine will still not start up or you don't hear any fans going when you press the button, it might be a bad Power Supply Unit (PSU). I have seen PSU's blow out just by plugging or unplugging the power cord because it can create a spark. If you have a bad PSU, you will need to contact someone local to replace it or you can take your unit to a Best Buy or local computer store and have them give you a price on a new PSU.
Dec 14, 2009 | Sony VAIO VGC-RB42G PC Desktop
The compyter has no power at all.
please replace your battery and try it again ....... and if it does not work, return it to the shop where you bought it ....... i believe you can have this solved
May 18, 2009 | Toshiba Satellite A215-S7422 Notebook
No power to TV. Will not turn on.
replace the power supply about 60.00 dollars from viewsonic
Jan 15, 2009 | ViewSonic N3251w 32 in. LCD HDTV
Compaq intel pentium 42.8ghz512mb
How old is your computer? Did you recently have a power outage or anything? Most the time if a computer won't turn on, something in it went bad OR an outlet is bad. Try this:
1. Make sure that the power switch is on, the switch in the back (on the power supply itself) is turned on, and everything along those lines is functioning.
2. If that doesn't work, and it will not power on AT ALL, make sure the cords are plugged firmly in place, including the surge protector and/or the power cord itself.
3. Try resetting the surge suppressor and/or plug the computer into a different outlet in the surge suppressor. Try other items in that surge suppressor (or even in the wall outlet, if that's what you're plugged into) to make sure that the outlet itself is working.
4. If your computer is plugged directly into a working wall or surge suppressor outlet, try a different power cord.
5. If your surge suppressor works, your wall outlet has power to it, and you are using a known-good power cord in the computer, you will have to go into more in-depth investigation as something inside the computer likely went bad. It could be the video card, motherboard, CPU fan, power button, or the power supply itself. Start by testing the video card and the power supply by (one at a time) swapping out a known-good component for the one you suspect may be bad. If it won't turn on after that, try swapping out the next and try it again. If it still will not work, it could be something more serious such as the motherboard or power button.
it could be a bad power supply or a bad motherboard. Other problems might cause issues, such as a bad video card.
Jan 16, 2008 | Computers & Internet
Hp 1315 all in one
The all-in-one product does not turn on If the all-in-one product does not turn on at all, try the following actions in order to determine the cause:
  1. Unplug the power supply from the wall outlet.
  2. Unplug the power supply from the back of the printer.
  3. Remove the product cable from any power strips or surge suppressors, and plug it directly into a grounded (three-prong) wall outlet.
  4. Wait at least 20 seconds, then, plug in the supply back into the wall outlet.
  5. Plug in the power supply back into the printer.
  6. Press the power button to turn the printer on.
  7. For models that have an external power supply module, verify that the power supply module is plugged in correctly. Some power supply modules have a green LED built into the connector end or on the power supply module. This LED will be lit if power is present. If the LED is not lit, replace the power supply module.
  8. Plug the power cord into a different electrical outlet. If the all-in-one product has an ADF with an external cable plugged into the back of the product, use the following procedure:
    1. Turn off the unit.
    2. Unplug the power cable from the wall outlet.
    3. Unplug the ADF cable from the back of the product.
    4. Plug the ADF cable to the back of the product.
    5. Plug in the power cable to the wall outlet, and turn on the power.
      1. If no change, the problem is not the ADF.
      2. If the problem clears, turn off the all-in-one, unplug the power cable, and reconnect the ADF.
      3. If the error returns, the ADF is defective. Contact HP Customer Care to get the ADF replaced.
  9. Disconnect the computer parallel cable from the back of the all-in-one product and try to turn on the product again. The computer might be grounding out through the parallel port. If this corrects the issue, check the grounding of the computer and outlet.
Jan 08, 2008 | HP PSC 1315 All-In-One InkJet Printer
Transformer
Several things have happened. 1st have you tried plugging the monitor in the wall and not in the surge protector. 2nd does your power button or LED light uo when you power it on? You have stated the transformer is bad due to lighting strike. Have you replaced the transformer? Your monitor should be coverd under the surge protector warranty. Please answer questions and we will go from there.
Jan 03, 2008 | Computers & Internet
Wave Industries OLY-OL3000 Globe Phone Logo
76 people viewed this question
Top Wave Industries Lands Phones Experts
Are you a Wave Industries Lands Phone Expert? Answer questions, earn points and help others
