Question about Champion G5NG853S Household Juice Extractor
WONT RUN - Champion G5NG853S Household Juice Extractor
    Problem Solver:
  • 9 Answers
Is it all put together? if if is not all put together properly it will not power up. if the whole thing is put back like the picture and it doesn't work perhaps it is your motor?
Posted on Jan 09, 2011
Wont turn on
check thermal fuse inside tiny as a aspirin non resettable though
Feb 25, 2014 | Juiceman JM480S 1.1-HP 2-Speed All-in-One...
Jack lalanne power juicer mt-1020-1 wont turn on
Hi Have you checked obvious things like fuse or loose wiring in plug?
Jan 01, 2014 | Jack Lalanne Power Juicer 250 Watts
Dash juicer wont turn on
Just fixed this problem!
Take bottom off juicer. The 4th screw is an "odd" one...I drilled the center out and used a flat head.
When you look up inside the juicer, you will see a silver lever arm. It touches the arm lock mechanism (so the juicer will only run when the arm is engaged).
The lever arm should be behind the black lever arm part on the side. When I opened mine up, the silver level arm was on top of the black post thingy. I took a screwdriver and pushed it off the black post thingy, so it the very bottom of the silver lever is behind it. (I can no longer see the entire silver lever easily when it is in the correct position.)
Totally fixed it.
I think it bounced out of the correct spot when I juiced some hard veggies or when I moved it, it hit the counter pretty hard.
Anyway, good luck....I am not a mechanic so sorry if the language is non-technical.
Oct 05, 2012 | Juicers
While juicing it shut off, and wont turn on.
PUSH RED RESET BUTTON ON BOTTOM.
Jul 12, 2009 | Juicers
Santos 28 wont switch on
Problem with internal micro switch,no power suply or locking handle not activating safety switch
Jul 08, 2009 | Matfer SANTOS Juicer
Brand new breville juicer vfj005 cow design,it wont work,no book
In all juicers there are hidden interlock switches called interlocks for ur protection. Put all the parts properly, so that these switches sense them. then it should work.
zahid@uic.edu
Mar 05, 2009 | Breville Juicers
Breville JE95XL juicer
I used needle nose pliers, it took a bit of patience but I got the screws out. I think I might replace them with regular screws. My juicer does not run either. Let me know if you find the problem with yours.
Dec 26, 2008 | Breville JE95XL Juicer
The pulp collection receptacle has a tiny clear plastic button on the bottom. If this has broken off (it happens often) the machine won't turn on. The button must be present to depress the safety switch at the bottom of the machine. If everything else is properly assembled and the machine won't turn on, this is probably the cause. Check the bottom of the pulp collection receptacle to see if the button has broken off. (picture #2) If so, replace it with a piece of pasta or a tiny piece of wood. Sounds silly, but it works. The safety switch at the bottom of the machine must be depressed before the machine will run.
Nov 04, 2008 | Jack Lalanne Power Juicer 250 Watts
NutriSource juicer
The support number is:
866-290-1851
Oct 01, 2008 | Back to Basics NS1000 Nutri Source Juicer
Overtemp switch keep tripping
REMOVE BOTTOM AND TRY ADJUSTING
RESET BUTTON BY TWEAKING SMALL
SCREW ON BUTTON HOUSING. TURN
EITHER WAY TILL YOU HAVE LONGER
RUN TIME.
Sep 04, 2007 | Omega 9000 Juice Extractor
Champion G5NG853S Household Juice Extractor Logo
65 people viewed this question
Top Champion Juicers Experts
David Payne
David Payne
ray gallant
Are you a Champion Juicer Expert? Answer questions, earn points and help others
