Question about Bryant 462AJC021BA Air Conditioner
Wires for thermostat need color code - Bryant 462AJC021BA Air Conditioner
    Genius:
  • Bryant Master
  • 1,363 Answers
Industry standard is green to fan, yellow to outside condensor, white to heat, red to rh/rc
Posted on Aug 05, 2015
HI, I have a White Rodgers model 1F89-211 thermostat. All I did was move it to the opposite side of a wall into another room and now it runs backwards. I heats on cool and cools on heat. Help?
Phillip...
The SECRET is to connect it exactly as it was (before).
The screws on the control are color coded
R,W, Y AND Green... TYPICALLY that MATCHES THE TERMINALS OF THE SAME COLOR inside you heater controller.
Yes ... Red, White... Yellow...
What you need to do is look at the picture you took... or the notes you took BEFORE disconnecting those wires...
ELSE...
Go to where the HEATER CONTROL BOARD IS...
Pull the front cover... Snap a picture for your memoirs...
and write a TRUTH TABLE
AT THE HEATER... TAKE NOTES...!!
RED SCREW = (for example red wire)
Yellow =
Green =
White =
BACK AT THE Thermostat Screws:
RED = (
SAME COLOR WIRE as at the HEATER)
Yellow = (SAME COLOR
WIRE AS THE HEATER)
Green = (
SAME COLOR WIRE AS THE HEATER)
White = (
You should be fine...
Carnac the Magnificent
Dec 07, 2016 | Heating & Cooling
Maytag Model DG309 gas dryer thermostat wiring color code schematic.
https://electronicshelponline.blogspot.com/
http://homenol.blogspot.com/
Visit this site to get some details.
Search the site by type in the "brand name" of your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 09, 2016 | Maytag Dryers
Need wiring diagram with colors of wires
Search Results
    How to Wire - Wiring Examples and Instructions
    www.how-to-wire-it.com/
    Wiring Examples and Instructions, Basic House wiring instructions, How to wire 2-way, 3-way and ... Need a little help wiring or getting something connected? ... I will show you basic thermostat wiring, thermostat color codes and wiring diagrams. ... You may scroll through the images below to search for related diagrams or ...
Dec 18, 2015 | Motorcycles
Hi, I have a baxi solo boiler WM60/4RS and a Landis & Gyr RWB252 timer but my Honeywell T6160 thermostat has nether been connected, can anybody shed light on the wiring connections please.
The color code for thermostat wiring is as follows.
The "R" terminal is power into the stat from the boiler control transformer. Normally 24 volts. The "Y" terminal is for cooling. Normally left blank for a boiler. The "W" terminal is for heat. This one used to start the heating cycle.The "G" terminal is for fan operation. Probably not used for a boiler. Check the boiler terminal board for these functions and write down the wire color on each one. Match the boiler colors to the right function on the stat. If you need more than this, let me know.
Jan 06, 2014 | Honeywell Programmable Thermostat Heater
Can't figure out how to wire RobertShaw 4220 thermostat for heat pump and electric air handler
Do you have the wiring Diagram If not you can look online for them or go to the place you purchased it I would like to tell you the Color code But not all installers use a color code Properly.
Sep 18, 2013 | Fahrenheat Built-In Baseboard Thermostat...
I have 4 wires at thermostat, g, b, w, y. The old thermostat was removed before I owned the house. I would like a wiring diagram so I can trace the wires an know how to hook up. Thx. Ken
Trace the thermostat wires into your furnace and write down which color wire ties on to which letter at the furnace terminal strip. The HVAC color code is - g (Green) = house fan b (Blue) = auxiliary w (White) = heat y (Yellow) = cooling. If you need anything, let me know. And please vote on this response. Thank you.
Roger
Apr 03, 2011 | Heating & Cooling
New Digital thermostat and it will not stay above 67. I've tried the hold and to schedule. Do you think this is a wiring issue?
Not likely, if you followed the color code written on the back of the thermostat and the furnace wires were not touched the colored wires each mean something. A simple thermostat swap and matching the colored wires with the labeled terminals, it would not hurt to check the wires and terminals just for a piece of mind. I believe the issue is in the programming of the thermostat, and it is possible to get a bad one even new there is nothing that says it is in perfect working order.
Dec 29, 2010 | Honeywell Focus 6300B 5-2 Days...
Can't match color wires to thermostat codes. I'm replacing my thermostat and I have 6 wires coming out of the wall but can't match colors to proper connections on thermostat. I have an electric heat pump.
Make sure you have a heat pump thermostat. Standard stat wire and stat wiring are as follows.
  • R to red
  • W to white
  • Y to yellow
  • G to green
  • O/B to orange
  • C to blue or W2 to blue
Your wire colors and stat brand and model number would be more helpful if this does not clarify. Repost with additional information and I would be glad to help further.
Oct 06, 2009 | Heating & Cooling
Need color code/wiring diagram info for Enterprise electric range installation of thermostat
I need the Oven knob for the front panel. The numbers have rubbed off on mine. Thanks, in advance, for your help!
Feb 22, 2008 | Kitchen Ranges
Bryant 462AJC021BA Air Conditioner Logo
55 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Bill Long
Mike Squire
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
