Question about Coleman Northstar Dual Fuel Lantern
I cant get any petrol to pump into the mantles
  • 1,514 Answers
If the petrol doesn't come through first check that you have enough in the tank. If the tank is not full enough it won't come through. If it still fails to come through it's likely that the generator is blocked. This is the tube which the mantle sits on and it has a very narrow opening to force the petrol to convert to vapour when it's warm. Try heating it for a while and it may clear it. Otherwise you'll need to buy a new generator.
Note: while the dual fuel lanterns can burn petrol you should be aware that it gives off poisonous fumes, like cars did before they had catalytic converters. The lantern should not be used indoors with petrol. They are safe with coleman fuel. If you live in the USA, Coleman fuel is cheap but if you're in Europe it's much too expensive. Rather than buying a new generator, if you live in Europe, you could buy a parafin burning lantern like the Petromax 500 available from http://www.pelam.de/index.php?cPath=28_31&language=en&gclid=CIOe46DQnqYCFQkf4QodQxz2Zg
and other sites, or you can pick up second hand Optimus lanterns on Ebay. Both burn parafin, though they need to be primed, and provide at least as much light as the Coleman.
Posted on Jan 03, 2011
How do u put a new petrol bubble on and where to get on in bankstown
Hi Sherree:
Most small engine maintenance shops or tool & equipment rental shops should be able to get the parts for you.
Installation is a matter of methodical dis-mantling, cleaning, replacing the part, and methodical re-assembly.
heerfuls
Mar 29, 2016 | Garden
Mazda familia 323 1998,new presure pump, no power, cant start
Remove the hose from the fuel line on the carburettor or injection first **** the fuel line for a minute than full the hose with fuel and start.notes petrol pump running two long with no petrol can get hot and burn out.
Sep 11, 2012 | Mazda 323 Cars & Trucks
I have a coleman 220k lantern. I can pump it up but it doesn't seem to get any fuel to the mantels. I have read about a generator but what is it and what does it do?
Hello, W/D here.
The generator is the small brass tube located close to the mantles. Here's how the lantern works: You pump it up until you get a decent pressure, or your thumb falls off, whichever occurs first. Next, you turn the main knob to the lighting position, which is usually marked as a 1/4 turn to the right. Then, you manipulate the small valve in between the mantles until you hear a gas flow. Turn the valve until the gas flow is lessened, then light the mantles. Adjust the small valve to get the mantles glowing. Re-pump up the main tank, and close the internal stem valve by rotating the plunger in a clockwise manner. Open the main gas knob to the run position, or fully, depending on your model. Adjust the gas flow at the small valve to keep the gas from flaring up at the mantles.
The heat from the mantles heats the generator, which atomizes the gas, and maintains pressure on the tank via the return tubing. As long as the mantles are heating, the length of time between tank pumpings is greatly extended, but usually not eliminated completely.
Best regards, --W/D--
Apr 08, 2011 | Garden
I have 2 coleman with double mantle. I have only use it 3 times since I bought it. Since then, I am unable to make both of them start. I have used locally sold petrol. I am wondering whether it is due...
If kerosene is specified then because it is a less volatile fuel it wil worrk better just as when you used alcohol.
Petrol is too volatile and might not work well as the kerosene design is on a different grade and specific gravity.
I would suggest if kerosens is not available to try a mix of petrol with alcohol-50-50, Gasahol, it might work well.
Sep 24, 2010 | Coleman Vacuums
I want to know how i light and use my Coleman double mantle duel fuel lantern
fill the tank about 2/3 full. put the cap on tight, pump the air pump about 50 to 75 times to pressurize the fuel tank, you may have to turn the pump knob in a few turns to get a good pressure feel when you are pumping, then push the pump down all the way and turn the knob in until it gets snug. then you turn the gas knob on until you hear a hissing noise. turn it off and stick a large lit match in thru one of the holes in the steel plate below the lens and hold it close to one of the mantles then turn the gas on again and it should light up. let it run for a minute or so until the mantles light up brightly and then turn it on the rest of the way. I've done this hundreds of times. hope this helps and good luck. Jeepfxr
Oct 07, 2009 | Sport & Outdoor - Others
I want to mount my 42" LCD TV above the fireplace mantle. Will the heat from the fireplace damage the TV. How far should it be recessed?
it's not a good idea to mount any tv above a fireplace mantle. Anytype of excessive heat added to the tv besides what it generates itself can cause distortion and loss of use in the tv by saudering or melting of connections that you cant see. If in doubt, is there a place where youve seen a tv mounted above the fireplace mantle, and ask them about any issues they may have come across, or are they also restricted to keeping the fire very low.
Aug 24, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Coleman Northstar Dual Fuel Lantern Logo
490 people viewed this question
Top Coleman Camping, Backpacking & Hiking Experts
Jim London
Jim London
yobo007
yobo007
Are you a Coleman Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
