Hi. I have a Bosch precision wfg 2820 front load washing machine. The drum no longer spins round. The belt is still attached and seems to be ok. Any ideas where to look next? Thanks
  • 613 Answers
You say seems to be ok.....can you hold the belt and turn the drum? Is there more that 3/4" slack in belt when you push it side ways? How old is this machine and have you ever had it serviced?
Posted on Jan 03, 2011
Broken belt
Buy new belt for washer, pop off back plate, put new belt on.
Dec 10, 2013 | Bosch WET 2820 Front Load Washer / Dryer
In the spin cycle at high rpm's the drum is making a load noise. Is it he drum belt? If so how can I replace it? I can't find a cutsheet on the parts list.
Hi there
Before you startreplacing partsin the machine, observe weather the washing is evenly distributed in the drum when it is working.
If the washing is not evenly distributed, there is a lot of noise and the drum does not go its rounds evenly.
good luck
kolbrun
Mar 10, 2012 | GE Energy Star WCVH6260F Front Load Washer
Hi! re BOSCH washing machine WET 2820 Program will start, and then for 30 secs approx start normally, water starts to enter the drum. Then it stops, nothing happens. I have cleaned the soap dispens
BOSCH washing machine WET 2820 This video will show you how to change the door eal washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Dec 07, 2011 | Bosch WET 2820 Front Load Washer / Dryer
Our bosch washing machine is about 9 years old and won't drain properly. The "end" light flashes as if the drain is blocked but it's not. If we manually drain the machine we can get onto...
As you do not mention 'filter' I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jun 05, 2011 | Bosch Washing Machines
Our frigidaire front loader washing machine does not spin and the clothes are still wet! Model FTF1240FS2. It seems to go through the cycle and pump the water but the drum will not spin. I checked the...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 05, 2011 | Washing Machines
Water leaks in all programs
Bosch WET 2820 Front Load Washer / Dryer water
Leaking.
This video will show you how to change a door seal on this Bosch front loader washing machine .
we have all bosch repairs in our channel
Feb 27, 2011 | Bosch WET 2820 Front Load Washer / Dryer
Drum not going round
Hi Friend,
welcome to fixya....
may be the drum belt is the fault, Here are some possible causes of a washing machine belt coming off :-
1.The drum pulley is loose
2.The drum bearings have gone (collapsed) causing the drum pulley to wobble
3.The drive belt was to slack
4.A motor fixing bolt or bracket securing the motor to the tub has broken or come loose
5.Water has got onto the belt causing slippage
6.An obstruction or item of clothing temporarily jammed the drum causing the belt to spin off ,,,,,,,,,,,,
first check whether it is hard to turn the drum if not then check the above situations,,,ok
if you think that i helped you please rate it\\\\\\\\
thank u...
Apr 03, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Belt seems to tight cant attach drom to moter
To check to see if the drum is free, spin the drum by hand, there should be no resistane at all.
If there is, then it could be the drum bearings are siezed, or there could be something stuck between the inner and outer drum.
If drum is free, then try again, they are tight to fit, I assume you have right size belt?
Feb 08, 2010 | Bosch WFL 2463 Front Load Washer
Drum not spinning & springs wrong way round?
To replace the belt hold in place on motor & feed onto pulley. The springs are on correctly but it seems one of the suspension legs is not doing its job. This may have occured when turning upside down & would explain distorted door seal. Thanks again for using fixya.
Nov 29, 2008 | Washing Machines
My Hotpoint Aquarius WF210 washing machine drum is not rotating
I think the belt has come off or has been damaged.
To open the machine slide out the machine. On the back panel lower 1/3 you will see a plastic panel remove the screws and the panel will come away. Inside you will see the belt. I suspect you will need to reattach the belt of remove it and buy a replacement.
Sin é
Jan 13, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Washing Machines Logo
240 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
