Flat screen turns on with the volume and channel buttons. Cannot use remote to change to input or front. Cannot reprogram channels.
  • Anonymous Oct 27, 2008
    Can you please better specify the repair suggested for dessikah's problem? My rear projection 65" is doing the same thing and I would like to repair it myself. Do you know how I can get the parts and schematic for the repair?
    Thank you,
    Tricia
    My model is a 65711.
  • 70 Answers
Check the remote first , remove the batteriesif it fixes it . then the remote might have had something spilled on it. otherwise you have a defective eeprom or micro i.c in the television.
Posted on Jul 09, 2008
I have a Sharp TV model LC-32SB24U. I cannot access the menu screen because I lost the remote control. Is there another way I can change channels without a remote?
The Sharp LC-32SB24U has menu, input, volume up/down and channel up/down buttons on the top of the TV. When you access the Menu using the buttons on the TV, the Input button is the same as the Enter key. The volume up/down buttons map to the left and right arrows. The channel up/down buttons remain up and down. The Menu button is the closest to the power button (on the right). The volume buttons are the ones on the left.
Make sure that the input is set to TV to change channels. Then you need to program the available channels, access the Menu and navigate to Setup (left/right arrows). Press Input to enter this sub-menu. Then use the Up/Down arrows to select CH Setup. Press Input again to enter. Now you can set the channel source and let the TV scan for channels that have a strong enough OTA signal or are unencrypted cable channels. These are the top two options in the Channel Setup menu. The details are available in the manual which is available here: http://static.highspeedbackbone.net/pdf/Sharp_LC37SB24U_LC32SB24U_Manual.pdf . For OTA channels, you may need to check the signal strength under the Antenna Setup - Digital option in this Setup menu. OTA Digital signals will not be tuned in if the signal strength is low. It's an all-or-none tuning; amplifiers and external antennas may help. See tvfool.com for details of transmitters and the recommended antenna for your area. (Warning: damaged amplifiers can become filters and block the signal on some channels. Replace the amplifier if it is damaged.)
If you look to replace your original remote with a universal remote, you'll need one that was programmed more than 6 months after the TV was released. That may be 12/2005 based on the manual copyright date. Look for a remote that has a Menu and Input or Source button and check all of the codes to find one that matches all of the features on your original remote. Amazon has an OEM remote for the LC-32SB24U; remotes.com also has a replacement remote available that has been programmed for the TV. (On remotes.com, search for the LC32SB24U.)
I hope this helps.
Oct 26, 2015 | Sharp LC-32SB24U 32 in. LCD TV
Blue screen need to know how to scan channels to get input to come back up
Will need to know what tv you have, but you are right it is probably your input button. if you pushed it on your remote then there should be an input button on remote. otherwise you will have to go into the tv menu and setup it up there.
if you respond with model and make of tv, might get more info.
Jul 12, 2012 | Polaroid Televison & Video
I'm hooked up tp Dish Network an hit wrong button on top for volume and now pic is gone. in lower left corner says no signal., but dish is working, just no picture on screen
Hey there, Cheri Torres with DISH Network Customer Service here. It sounds like you are going to need to change your TV back to the proper input or channel. If the TV remote is not working to change the channels you can also use the buttons on the front of the TV. First look for a button listed as either input, TV/video, source or AUX. When you press this button it will start cycling through all the inputs available, make sure to cycle through them slowly because it make take a couple seconds for the picture to come in. If you do not find a picture on any of the inputs you are going to need to try the different channels. Normally for a TV where the receiver box is the TV should be set to channel 3 or 4. Once you have found your DISH Network picture you will want to make sure to push the SAT button on the DISH remote so that it doesn't change the TV channel again. I hope you find this information useful and if you have any further questions or concerns please let me know. Thanks. :)
Oct 22, 2011 | Craig CLC501 15 in. TV
I have a GE Universal Remote RC 94948-H 1030. It only has channel and volume buttons how do I program it. I know the code but not the method of input. Its something to do with the channel and volume...
I have a GE Universal Remote RC 94948-H 1030. It only has channel and volume buttons how do I program it. I know the code but not the method of input. Its something to do with the channel and volume buttons
Feb 04, 2011 | Televison & Video
Orion TVD2710. Lost remote, can't change signal input
I would suggest you try to find a universal remote that has an "input" or "source" button and program that one to your tv. By pressing the "source" or "input" button, it will change the input to the tv. I hope this helps! -Der Strom
Apr 06, 2010 | Orion STV2763 27" TV
Input channel with no remote
You should be able to select the AV input with an Input or Menu button on the front of the TV.  If there are no arrow keys the Channel and Volume buttons may provide up-down-left-right action.
May 28, 2009 | ESA ET427E 27" TV
Tv screen has turned blue and I can't watch tv
i think by accident you have changed the input when you went to change the volume. look for a button labeled " input" or "video" select on the remote and scroll through the various choices. you should get your picture back.
Jan 21, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Mintex 37 inch wide screen. remote is working however cannot change channel, input source or volum. only turns tv off. The buttone on tv doesnot work connot change input source or volume
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
Jun 27, 2008 | Mintek DTV-373-D 37 in. LCD HDTV
Multiple issues with tv
Pressing i+ button (bottom left on the original remote) for 5+ seconds worked for me...
Feb 21, 2008 | Philips 32PF5320 32 in. HD-Ready LCD...
Televison & Video Logo
Top Televison & Video Experts
