Question about Sport & Outdoor - Others
My toro workman will not engage into gear. the problem is that it seems to be in neutral and will not go into gear. it was working fine one day and then started this the next.
  • 35 Answers
SOURCE: i lost my third gear
It seems in the manual transmissions the first gear to go is 3rd gear..
signs of a failing trans
Posted on Feb 11, 2009
  • 190 Answers
SOURCE: Engine stalls when engage in any gear from neutral.
CHECK THE SIDE STAND SAFETY SWITCH IS OPERATING
Posted on Mar 19, 2009
emissionwiz
  • 76630 Answers
SOURCE: gear shift moves fine will not engage gear.
then the transmission has failed or has sticking engagement solenoid in trans pan, have the fluid and filter replaced and see if that corrects the problem
Posted on Apr 01, 2009
  • 376 Answers
SOURCE: Tractor Will Not Move And Dies When Brake Is Released
I would check the wires and clean the connectors and make sure seat switch is working. If that is not working, it's like getting off the seat without holding the brake/clutch pedal down or getting off seat with blades engaged. Both will cause engine to die.
Posted on May 26, 2009
  • 14036 Answers
SOURCE: Car starts and runs fine. Wont shift out of park.
CHECK BRAKE LIGHT SWITCH FUSE AND THE BRAKE TRANSMISSION SHIFT INTERLOCK SOLENOID FUSE.IF THEY BOTH CHECK OUT OKAY.YOU HAVE A FAULTY BRAKE LIGHT SWITCH OR FAULTY BRAKE TRANSMISSION SHIFT INTERLOCK SOLENOID.
Posted on Oct 04, 2009
Where can I buy Toro Workman 3200 carburetor?
go to Toro commercial service center. They are expencsive. I have the same set up as your workman for fertilizing and spraying. Where are you located? I am in Holland,, Michigan
Dec 12, 2013 | Toro Workman 3200
Audi a3 auto reverse gear doesn't move
run fault codes and look for faulty TCM and reverse servo .
Nov 29, 2013 | Audi Cars & Trucks
I can shift into drive but it won't engage
sounds like a broken shift cable. (the connection between the shifter and the gearbox) common symptoms are the shifter move easier than normal.and does not move to any gears (not even park or neutral).
Nov 23, 2013 | 2004 Chevrolet TrailBlazer
Out of transmission fluid in my toro workman 4200 4wd
According to the service manual, the transaxle uses 8 quarts of DEXTRON III transmission fluid. It also is the source for fluid for the hydraulics.
Dec 07, 2012 | Toro Garden
My front wheels won't engage on my Toro. Belt is fine, and spool is turning. Looks like the box isn't in the right position for the gears to engage. Is there a simple fix?????
not with toro. this usually happens if cutting high grass. try taking it apart, clean it. make sure belt is not stretched out and jammed.
Sep 22, 2010 | Toro Lawn Mower With Toro Power Tools
99' camaro auto tranny wont engage
take it back to transmission shop that did the work, or have towed back on their ticket
shack
Apr 16, 2009 | 1999 Chevrolet Camaro
I lost my third gear
Dec 08, 2008 | 2002 Dodge Neon
Sport & Outdoor - Others Logo
110 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
