Question about Kenmore 62802 Electric Dryer
Dryer is dead
My dryer will not do anything it was fine and them nothing. We have power to every where what should we check next
  • 958 Answers
You can check the belt. it could be broke.
i hope i was able to solve your problem..please rate me...tnx.. drcool299
Posted on Jul 09, 2008
My new holland mini excavator is dead nothing no lights or nothing it was running fine just died and everything went out no response from anything it's just dead
clean battery connections and ground connection to the frame and motor if no power after this check voltage in battery fuses ect
Mar 22, 2015 | Mini Cars & Trucks
Put in a new battery, it was dead the next morning, whats using the power
I was having the same issue with my car not sure if yours is the same issue but check out the alternator amp fuse
Feb 22, 2013 | 1990 Ford F250
Wired outlet incorrectly and breaker tripped. dryer will not come on. there is power in the outlet. no beeps or anything, completely dead. model number gleq2152es
hello if it striped the breaker theres a dead short somewhere in the dryer something on the power supply board could have shorted to ground check the glass fuse on the power board of the dryer if blown make sure you use the same rated fuse also check the capaitor next to the motor these can go short circuit hope it helps
regards
shaun
Jan 04, 2011 | Frigidaire GLEQ2152ES Electric Dryer
LER7620LW0 dryer does nothing...........worked fine on last load.........door switch makes clicking noise...........what should i try next
If the dryer is doing nothing at all, sounds like you lost power to it or the door switch has failed even if you hear a clicking sound. Check to see if you have power at the outlet where the dryer is plugged in. Use a hair dryer or other portable device. If there is no power there, check the circuit breaker for that outlet. It may have tripped.
Please vote or leave a comment.
Mr Tin Man
Nov 28, 2010 | Dryers
Dryer wont turn on. Breaker in breaker box is fine. No light inside dryer. What's wrong?
Dryers run off 220v, and sometimes only one leg of the breaker trips. So you need to flip the breaker all the way off, and then back on. Sometimes the breaker feels off but is not fully reset. Make sure you completely trip it off then back on. Does the dryer light work now? Is there any indication that it's getting some power? If the breaker is fine and your still not getting power, then the next step is to make sure you have power coming to the plug behind the dryer. At this point you should only continue if your comfortable working with electricity. Once you move the dryer you can check the outlet with a meter, or other circuit tester. If you got power here, then you'll need to start checking things on the dryer. you can remove the plate where the cord goes into the dryer and look for loose or burnt wiring there. If that looks ok, then you'll need to start taking the dryer apart; front panel, top, back, etc, as needed to access the wiring and controls. From here you can trace the wiring from the supply to the controls and to the motor, etc. look for anything burn, If nothing looks out of place you can start checking temp sensors, or fusable links. If this is above your head, then stop where your not comfortable and have checked by a service technician.
Sep 20, 2010 | Whirlpool LEB6300 Electric Dryer
Having problem with my Electric Maytag. I push the start button and nothing happens.. The model bumber is pyet344ayw..
Have you checked the circuit breaker? I would start there. Dryers run off 220v, and sometimes only one leg of the breaker trips. so you need to flip the breaker all the way off, and then back on. sometimes the breaker feels off when it's not. make sure you completely trip it off then back on. Does the dryer light work? is there any indication that it's getting some power? If the breaker is fine and your still not getting power, then the next step is to make sure you have power coming to the plug behind the dryer. At this point you should only continue if your comfortable working with electricity. Once you move the dryer you can check the outlet with a meter, or other circuit tester. If you got power here, then you'll need to start checking things on the dryer. you can remove the plate where the cord goes into the dryer and look for loose or burnt wiring there. If that looks ok, then you'll need to start taking the dryer apart; front panel, top, back, etc, as needed to access the wiring and controls. From here you can trace the wiring from the supply to the controls and to the motor, etc. look for anything burn, If nothing looks out of place you can start checking temp sensors, or fusable links. If this is above your head, then stop where your not comfortable and have checked by a service tech.
Sep 20, 2010 | Maytag Dryers
My GGQ 9800 gas dryer won't start. It was working
Things to check first on a no start dryer.
Check for power at outlet.
Inspect power cord.
When you try to turn it on do you hear anything?
Check the door switch(does it click when pressed in?)
The next item to check and most likely replace on a completely dead dryer with power and a good door switch would be the thermal fuse located inside the cabinet.
Please let me know if I can help with anything else
Apr 08, 2010 | Whirlpool GGQ8831L Gas Dryer
Electric dryer is totally dead WEC6430A - has
Hello, Remove the back panel from the dryer and test the thermal fuse, it looks like this: 908c006.jpg With and ohms meter take wires off and test for condinuity...if no condinuity replace it, Hope this helps. Good Luck! Mike
Aug 15, 2009 | Whirlpool Dryers
The dryer runs but does not heat. Thoroughly cleaned.
The duct fuse must have continuity in order for power to get to the gas assembly even though she may run she won't heat if the fuse is blown. 53481c0.jpg
If that is good and you have power to the gas assembly nothing will happen if the flame sensor is dead. If the sensor is good then the next thing to check is the ignitor. MORE
Mar 12, 2009 | Whirlpool LGR3624JQ Gas Dryer
Kenmore 62802 Electric Dryer Logo
44 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
