Question about LG Televison & Video
Hi problem with connecting my lg 42lh2000 to my lg ht303 cinema sound system have no audio from tv to cinema system please help.
  • 476 Answers
SOURCE: 37pf7531 tv
If you have a later Philips home cinema model: HTS3100, 3300, 3500, 3154, 3357, 6510 & others, the sound from the TV will go through the existing scart connection.
Just select TV on the home cinema remote control.
For any other models, use a scart - twin phono lead (red & white), from the TV to one of the inputs into the home cinema.
Scarts 1 & 2 on the TV will have different results. Try both.
Posted on Feb 18, 2008
jerryg50
  • 1667 Answers
SOURCE: no audio
I will try to explain this clearly.
Make sure that there is sound leaving from the connections on the top box.
Check that the audio cables are connected to the associated audio input for the video at the rear of the set. Make sure that there are no other shared inputs for the same input. With shared inputs, only one can be the default reference for input.
Check the menus in both the top box and the TV set to make sure that all setups are correctly done.
Jerry G.
Posted on Apr 14, 2008
SOURCE: Wharfedale LCD37F1080P and external surround sound
  1. hi here is what you do go into menu go to feature thento ext 2 out then press right blue button on remoteand find the ext you need make sure your tv volume is turned down make sure your surround sound is on and turned up wait and you will here your sound when you have the right ext i have hdmi lead in ext 5 so it ext 5 that will show in the feature menu i hope you find your problem solved allan
Posted on Sep 27, 2008
  • 33 Answers
SOURCE: sharp television and panasonic cinema system with hdmi connection
Ok, here's the deal. You can have sound being putout from hdmi coming from one of those sharp units, but it just depends on how you are connected. If you are using a digital audio output, from the tv, it wont push out the sound the way that it should. You will have to downgrade to using audio composite cables to connect to your external speaker system from the audio ouputs, not the digital audio outputs. Its not designed to push out sound from an hdmi cable. The BEST way to have this setup is to run your sound directly from the cinema to the external audio source(leaving the hdmi cable in the tv).
Posted on Dec 12, 2008
SOURCE: No sound through the Panasonic cinema surround sound on TV
Had a similar problem mate. I solved it by connecting the tv to the PT460 system with a scart lead. You then have to have the AV channel selected on the PT460 system to listen to the tv. You will always have to have the AV channel on the PT460 selected to listen to any sound transmitted through the tv - be it playstation/xbox or any other device that you may connect in the future with HDMI leads or otherwise. Hope this helps
Posted on Jan 04, 2009
Tring to connect my samsung tv to my samsung home cinema and having problems
Hi,here is my simple solution...
to listen your TV on your Stereo system thru your
samsung home cinema receiver,
** you need to connect "Audio Output " RCA jacks or "Optic cable output" of your TV
** to "AUX input " or "TV" OR "Any input" of your receiver ( except Phone ) or "Optic Cable input"
** than just switch to respective mode on
samsung home cinema RECEIVER corresponding your RCA or Optic connection..
There you go..Your TV sound is on the
samsung home cinema Receiver..By this means whatever you watch on the TV (TV tuner, satellite , Xbox ..etc.) ,it's sound will come thru your stereo..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 25, 2011 | Samsung Audio Players & Recorders
I have a sky+ hd box connected to an lg 42LH300 tv through hdmi and an LG HT805SH home cinema through optical cable. Whenever i turn sky over i lose sound and have to turn cinema on/off to sound returns ...
One of the way to connect the whole system is using only HDMI cable version 1.3a. There is audio return channel built into the cable.So you do not have to connect the optic cable.
Sky box to TV using HDMI
LG HT805 to TV using HDMI. Even the Sky box audio will come back to the LG-HT through the audio return path.
Mar 08, 2011 | LG Televison & Video
I have an LG TV with an LG HOME CINEMA SYSTEM problem is: watch dvd/blue ray - video fine sound fine (through speakers) watch tv / sky -- video fine sound None throughspeakers on...
There are two things that I can suggest.
1-Test your optical cables to make sure they a good on a known working source because they are very fragile and break very easily.
2-Try to eliminate the use of optical output from tv to receiver. There may be a problem from the HDMI to optical conversion at the tv. Instead, try running the audio directly from the source to the receiver, and let the tv deal with video input only.
Hope this helps,
Good Luck.
Jan 07, 2011 | LG Audio Players & Recorders
How do i get my ps3 to run through my lg surround sound
Connect your yellow and red lead from the PS3 to the surround system, connect them to aux input. (the white lead is not needed). Then in the sound settings on the PS3, go to audio multi-output and change it to on. On your remote for the sound system press the input button until aux appears on the front of your LG HT303SU, and thats it, happy gaming.
May 18, 2009 | LG Televison & Video
Can't get tv sound from home cinema system speakers
you need an optical cable going from the TV to the home cinema for an audio output, it worked for, had the same problem!!
Dec 04, 2008 | Panasonic Home Theater System System
I have a samsung cinema system rts he10t and a samsung lcd tv le32a556 and i am trying to get the sound from the tv to the cinema system i have a hdmi cable and the red and white phono cable connected but...
make sure you have the audio cables connected to the OUTPUT on the tv & the INPUT on the surround sound(from your desciption sounds like you have them reversed)hope this helps,thanx for using fix-ya,please rate all replys
Nov 17, 2008 | Audio Players & Recorders
How to hear sky tv's voice from home cinema system?
PUT A SET OF PHONO CABLES FROM AUDIO OUT ON SKY TO AUX INPUT ON YOUR SAMSUNG.SWITCH SYSTEM TO AUX INPUT SET SOUND 2 PROLOGIC 2,AND HEYPRESTO SURROUND SOUND I HOPE.
HOPE THIS HELPS.
CABLE GUY.
Jun 26, 2008 | Audio Players & Recorders
Getting audio from LG TV to play through Samsung Home Cinema System
May 20, 2008 | Audio Players & Recorders
TV sound to Cinema system?????????????
Thi is not possible so I exchanged the TV for another one, This TV does not have AUDIO OUT function.
Mar 28, 2008 | Panasonic Audio Players & Recorders
Televison & Video Logo
65 people viewed this question
Computer Repairing
Computer Repairing
