Question about Craftsman 15 gal Air Compressor 3 hp UMC Horizontal k Oil Free Pump
What type of oil i have to put in the oil chaimber
  • Marc Powers
    Marc Powers Mar 30, 2012
    If this unit has a UMC motor you will not add any oil. This unit is an Oil Free Air Compressor.
    Scholar:
  • 146 Answers
The UMC Series units do not take oil. These units are oil free.
Posted on Jan 04, 2011
What type of oil do I put in?
Hi Shelly, There's two types of mower oil, There's the oil for the sump (4 stroke mowers ONLY) and the 2 stroke grade is just two stroke oil (2 stroke mower ONLY) If you own a 2 stroke mower then yes you actually add the oil to the gas before you put it in the gas tank (25 to 1 ratio) but If you own a 4 stroke mower then you DON'T put the oil in the gas tank. There is (two) capes, 1 for the gas and the 2nd cap is there somewhere for the oil.... Have a look at the link below... CHEERS..
http://bpretail.bp.nl/australie/2_stroke_brochure.pdf
Mar 30, 2016 | Garden
Chevy oil filter stuck on
try a different type of oil filter wrench, the type that fits on the top of the oil filter, like a wrench that fits on a nut. Be sure the filter is really clean too, any oil on it can make the wrench slip. When you put it back on put a but of oil around the seal so it doesn't get stuck again.
Jul 31, 2013 | 2007 Toyota Sienna
I just bought a 1988 yamaha virago 750 and it was stored outside covered for over 4 yrs.Cleaned carbs and gas tank,put new plugs in,new fuel lines and checked fuel filter is ok. I have spark,compression...
good start on cleaning things BUT, you should replace pump. the pump will have the same gum **** the tank did. you can unhook lines and turn over to see how much fuel you get
Jun 14, 2011 | 1988 Yamaha FZX 750
I'm about to change my oil for my on my 1981 suzuki gs650gt and I need to know what type of oil to put in and how much. And what type and how much to put in the drive shaft.
remove the lower plastic and the filter should be behind the exhaust. but before you do that the oil type will be shown on the back of the tank.
Apr 07, 2011 | Suzuki GS 650 GT Motorcycles
Cannt get the oil filter to budge
USE OIL FILTER WRENCH USE THE SOCKET TYPE OIL FILTER WRENCH WITH 3/8 EXTENSION AND RATCHETT. YOU HAVE TO LOOSEN OIL FILTER COUNTERCLOCKWISE TRYING LOOSEN OIL FILTER WITH HANDS IMPOSSIBLE BECAUSE FILTER HEAT SEALS AFTER YOU PUT IT ON.
Oct 25, 2010 | Isuzu Trooper Cars & Trucks
I have a 5.5 Honda pressure washer, no fuel is getting to the spark plug. Cleaned carb, carb is getting fuel just not flowing into combustion chaimber. It has to be a carb problem ! What part of the carb....
The float and the valve it is connected to let fuel into the carburetor. The flow jets meter the fuel into the engine. These jets have very small holes in them and easily plug up. You might want to get a complete overhaul kit for your carburetor so you'll get new gaskets, and other wear parts .
Aug 14, 2010 | Honda Chipper Blower and Vac: 5.5 Hp Gas
I do not know what type of transmission oil to put in my 1994 suzuki RM 250. I just got it and it would help if i knew how much to put in to. Can you Help me?
you can use the expensive oil such as silkolene light gear oil or you can use 10w40 semi synthetic car oil. we have used this for 15 years of racing. never had a problem with it. never even had to change a clutch.hope this helps.
Feb 19, 2010 | 2005 Suzuki RM 250
Can i drain the transmission fluid on a 05 suzuki forenza my self?
yes. HOWEVER, whe you refill it. make sure that you put in the correct type of oil. refer to your owner manual prior to putting in any old automatice trranny fluid as some tranny's require a sopecial type of oil, put in the wrong one and you fry your transmission. If its a standard, put in the correct weight of gear oil. Not trying to scare you, but i want to make sure that your REFER TO YOUR OWNERS MANUAL for the correct type of oil to put in after you drain it.
good luck.
Sep 27, 2009 | 2005 Suzuki Forenza
Oil cange
What is the best type oil to put in my husbandsYamaha 1900cc Roasdline? I put 10w-30 in it, will that hurt it any or will that be okay?
Sep 16, 2009 | Motorcycles
Honda cfr 150 f, will start but when I turn the throttle it stall
It sounds like a fuel problem. Drain the fuel tank, take the air filter off and spray some carburetor cleaner into the throttle bore, and make sure that the air and vacuum lines are clear and undamaged. Refill the tank with fresh gas and try it again.
Apr 03, 2009 | 2004 Honda CRF 150 F
Craftsman 15 gal Air Compressor 3 hp UMC Horizontal k Oil Free Pump Logo
79 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
