Question about D-Link AirPlus DI-524 Wireless Router
We have used this router once, then after that..we cant use it anymore.. there's no power on router no matter reboot/ reset..
    Brigadier General:
  • 10,406 Answers
> we have used this router once
If it is "brand-new", then take it back to where you bought it, and exercise the WARRANTY to get it repaired/replaced.
Posted on Jan 03, 2011
  • 1 more comment
  • ennyl08yevie Jan 04, 2011
    the problem is, it is brought in denmark.. and i am here in philippines. it's a gift from my auntie
    i mean it was bought in denmark
  • ikkenom Jan 04, 2011
    Go to any "local" computer-store, and see if they will exchange it, or if they will tell you how to contact the nearest D-LINK subsidiary, to exercise the warranty.
Can i hook up wrt120n to laptop without hooking up to cable modem to fix?
Try this: Unplug EVERYTHING(related to both the router and modem). BEFORE you plug in power to anything, connect all of your ethernet. So, first ethernet goes from modem to router. Make sure they are in their proper places. Next, take another ethernet cable and attach that from modem to computer. NOW, power everything up. Google the linksys router splash page login. Im sure it'll be something like: 192.168.1.1 or 192.168.0.1 or something along those lines. From there, you should be able to set up your wireless. Once thats all good, unplug just your computer and everything should be fine. If that doesn't work, its either time for a new router or you're having wifi card issues.
Apr 28, 2012 | Linksys WRT120N Router
Why wont my wireless work anymore?
Try rebooting the router. Login into the router to see if the wireless is turned ON and set to FULL power. If this does not work, The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can ssets-up form scratch.
Oct 24, 2011 | D-Link RangeBooster G WBR-2310 Wireless...
Why i cant reset my linksys wrt54gx 2ver even though i already press the reset button in 30 seconds?
Hi trenzfall89,
I see that you are resetting your Linksys Wireless Router.
You mentioned you pressed it but it will not reset, if that is a brand new Router, then most probably the plastic covering the reset button is still ther you should press it to go in the Router and get to the Reset Button, the pin that you are using should go in the Router at least to determine that the reset button is really getting pressed on the Router.
Hold it down 15 seconds will be fine also make sure that by doing the resetting the router should as well be turned or Powered ON and not powered OFF to make the reset feature to happen or work on the Router...
If still the Router will not reset then this is probably that the router is not anymore functional nor responding properly anymore, you may need to just get a new router in this case.
I hope this help.
Have a nice day,
mvincentc
Jun 10, 2011 | Linksys Wireless-G WRT54GX Router...
After my computer stands untouched for about 30min I suddenly cant connect to the Internet using IE ( eventhough my connection says that im still online, but cant open any webpages ) sometimes I play poker...
To check the status of this sequence, you can simply log in to the routers interface and click the STATUS TAB.
If this sequence never fully completes or doesn't complete properly, try power-cycling both the modem and the router at the same time. Please remember to reconnect the power to the modem first and then the router. Please allow a few moments for the devices to initialize and "sync" up.
Also consider to reset the router to factory settings.Here is how:
Step 1 With the unit on, place a paper clip into the hole on the back on the unit labeled Reset.
Step 2 Hold paper clip down for 10 seconds and release.
Note: Do not repower unit during this procedure.
Step 3 The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset.
Resetting the router does not reset the firmware to an earlier version. It will change all settings back to factory defaults.
Note: The factory defaults username is admin, and there is no password.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 20, 2010 | D-Link DIR-615 Wireless Router
Wireless light is not on
To restore the factory default configuration settings without knowing the administration password or IP address, you must use the Default Reset button on the rear panel of the router. 1. Press and hold the Default Reset button until the power light blinks on (about 10 seconds). 2. Release the Default Reset button and wait for the router to reboot. If the wireless router fails to restart or the power light continues to blink or turns solid amber, the unit may be defective. If the error persists, you might have a hardware problem and should contact technical support.
Nov 27, 2009 | NetGear RangeMax WPN824 Router
Lights have frozen on my router i got it to work again but things havent been the same i now cant connect to my friends on xbox live anymore. Its gotten worse now because i used to be able to connect with...
Check with the router website if they have a newer firmware for this product. Update it if thats possible. Try resetting the router once or twice. ( you have to set it up from start again if you reset )
Either of this should help . if it still keeps freezing, could be a bad one .
Thanks Ranjit
Sep 24, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
I cant reset my password. i want to reset this
If you have forgotten your password the only option is to reset it to the factory default using the reset button on the back on the router (little pin hole between power socket and WAN socket).
  1. Leave the power on, do not disconnect the power
  2. Press the reset button and hold (use a paperclip)
  3. Keep the button pressed for 10 seconds
  4. Release the button
The router will now reboot itself and will be reset to factory defaults which are username: admin / Password: Blank (ie. no password)
Jul 05, 2009 | D-Link AirPlus DI-614+ Wireless Router
I cant reset my Motorola SBG900!
Ok in the back of this unit or bottom there is a reset button or hole that you need a pin needle to access. Press it in for 15sec and let it reboot. Once it reboots, open a web page and type in 192.168.100.1 or 192.168.0.1 This will bring up a log in page. The login is admin and the password is motorola.
May 24, 2009 | Arris SURFboard SBG900 (49402201900) Modem
Cant call anymore (iphone 3g)
go to settings Reset all -- > erase all
it takes 2 - 3hrs to reset the phone to Original .. once it got fixed try to Jailbreak with redsn0w
Apr 23, 2009 | Apple iPhone 3G
D-Link AirPlus DI-524 Wireless Router Logo
16 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
